Oil Pressure for my 304 pegs the guage 80+ psi ?? - JeepForum.com
post #1 of 17 Old 10-07-2013, 09:28 AM Thread Starter
myridge
1979 CJ7
I put my CJ7 back together after 5 years of sitting in pieces in my garage and when I fired it up it pegs the gauge at 80+ psi, When I turn the ignition on it zeros out then once running it pegs. I am not complaining if its high higher is better than lower but can I trust it?
Its wired to using the solid purple wire to the sensor.
1979 cj7 304, TH400, Quadratrac
myridge is offline
post #2 of 17 Old 10-07-2013, 10:06 AM
LumpyGrits
What gauge are you using?
IF, it's the OEM Jeep gauge. Don't believe it.........
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #3 of 17 Old 10-07-2013, 12:01 PM
PantherChicken
1976 CJ7
Strangely enough my Jeep has the same issue. I just purchased the jeep a few months ago, and the oil pressure gauge, if it moved at all, just fluttered around aimlessly. As part of the sale, the PO gave me a new-in-box sending unit.
I replaced the sender this weekend, and now the guage sits right at 80psi whether the engine is idling or revved up. I assumed I just got the wrong sending unit, and it's not 'calibrated' to work with my gauge. The good news is that I know I have oil pressure now ;-)
(I'm running stock 304 V8 with stock gauges, the jeep is a 76 CJ7)
PantherChicken is offline
post #4 of 17 Old 10-07-2013, 12:14 PM Thread Starter
myridge
1979 CJ7
Yeah me too, Stock Gauges and NOS sending unit.
myridge is offline
post #5 of 17 Old 10-07-2013, 01:07 PM
MoneypitCJ5
1977 CJ5
I'd get a mechanical gauge and try to verify the oil pressure. If it is 80+ I bet there are problems with the relief valve or the oil filter. I think its supposed to pop off at about 70 psi.
1973 VW Karmann-Ghia first car
2009 Challenger R/T 6MT, Flowmaster, inTune daily driver
1977 CJ5 304, 3MT - under construction
And many in between!
MoneypitCJ5 is offline
post #6 of 17 Old 10-08-2013, 08:43 AM
PantherChicken
1976 CJ7
It's much more likely that there is a simple electrical issue or a mismatch between gauge and sender, IMHO.
post #7 of 17 Old 10-08-2013, 08:45 AM Thread Starter
myridge
1979 CJ7
I think you may be right. I have all sorts of electrical gremlins going on right now. I checked under the dash and its using the purple wire to the post on the guage and again under the hood.
myridge is offline
post #8 of 17 Old 10-08-2013, 10:18 AM
LumpyGrits
The ele oil psi gauge that AMC used in our CJ's is a well known POS.
I had 3 sending units die while under warranty.
Don't trust'em, ever.........
LG
post #9 of 17 Old 10-08-2013, 12:30 PM
Rollbar
1984 CJ8
Here ya go-have them in my CJ8 and no problems. Twenty nine bucks.
http://www.summitracing.com/parts/sum-g2925/overview
<----Click
<---- Click
Rollbar is offline
post #10 of 17 Old 10-08-2013, 08:07 PM
WSS
WSS's Avatar
1972 CJ5
Tried and true Stewart Warner gauges. All mechanical, no senders.
WSS is offline
post #11 of 17 Old 10-08-2013, 08:18 PM
LumpyGrits
The Stewart Warner gauges made today are NOT what they once were.
The SW's in my Jeep are 25+ yrs old and are the best. The ones today are NOT.
http://en.wikipedia.org/wiki/Stewart-Warner
Today, if I wanted gauges. Here, is who I would deal with.
http://www.marshallinstruments.com/c...erformance.cfm
LG
post #12 of 17 Old 10-08-2013, 08:31 PM
WSS
WSS's Avatar
1972 CJ5
The SW's my Jeep are 25+ yrs old and are the best. The ones today are NOT.
LG
The only new one I have is the water temp. The rest are period correct for the Jeep.
I can't believe you of all people quoting wikipedia?
WSS is offline
post #13 of 17 Old 10-08-2013, 08:52 PM
LumpyGrits
Yeah I know
BUT, this time they are 100% correct.
That is the ONLY reason I used'em.
Still, SW's of today are in name only............
LG
post #14 of 17 Old 10-08-2013, 09:01 PM
WSS
WSS's Avatar
1972 CJ5
In the field (of heavy equipment) they are still highly trusted and used. I have never had anything but good luck with them. I would prefer American made of course but being made in another country does not make it a bad product. Obviously my opinion, so buy and use what you trust.
Way back, they were literally made like a fine watch, by the hands (no CNC!) of very skilled craftsmen. Now it is just a guy who loads a pallet and pushes the send button. LOL
WSS is offline
post #15 of 17 Old 10-09-2013, 06:33 AM
gmakra
Seems to me that there is a lot of chatter brands of gauges but what if the relief valve on the oil pump is jammed closed and the gauge is reading correctly?
I would put any old gauge on the engine and verify the PSI and then come up with a plan of action.
gmakra is offline
