oil pressure gauge - JeepForum.com
post #1 of 2 Old 05-20-2003, 03:00 AM Thread Starter
ppd1108
1978 CJ7
oil pressure gauge
I had my dash apart on the 72 CJ. It has an aftermarket oil pressure gauge that is mechanical ie. it has a tube that carries oil from the engine to the gauge itself. I noticed that while the engine is running there is about 3 to 4 inches of air in the line that carries the oil to the gauge. Does the gauge meassure the pressure of the air in the tube or does it need the oil to be inside the gauge? If the air in the line is not supposed to be there how do I bleed the line?
Thanks.
ppd1108 is offline
post #2 of 2 Old 05-20-2003, 08:27 AM
fuzz401
1978 CJ7
most of the time it has some air in it to bled it out you have to crack it enough with the motor running and can be some what of a mess
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
Oil Pressure gauge 1skyking Jeep CJ Forum 8 01-14-2010 05:58 PM
oil pressure gauge ?'s brypten Jeep CJ Forum 3 01-14-2010 12:09 PM
Oil Pressure - near zero 258 mechanical gauge whittlecj Jeep CJ Forum 22 09-10-2008 10:11 PM
Oil pressure gauge shoboat90 Jeep CJ Forum 8 11-20-2005 01:22 PM
oil pressure gauge mike4089 Jeep CJ Forum 2 11-13-2005 09:07 AM
