Oil Pressure - JeepForum.com
post #1 of 11 Old 06-17-2013, 09:17 AM Thread Starter
firefighter4x4
1981 CJ5
Oil Pressure
I have an 81 CJ5 with a 4cyl and my oil pressure is between 20-30 psi on startup and when i am driving it can get down to 15-17 psi. The oil level is fine. Also when at high RPM, if i am driving up a inclined highway my lifters was start making clicking noises. Shoul my oil pressure be around 38psi? Also what could cause this?
firefighter4x4 is offline
post #2 of 11 Old 06-17-2013, 10:35 AM
LumpyGrits
Do NOT trust the OEM gauge!
Get a direct read mech. gauge.
How many miles on engine? What weight oil?
LG
LumpyGrits is offline
post #3 of 11 Old 06-17-2013, 11:37 AM Thread Starter
firefighter4x4
1981 CJ5
Engine has 62,000 on the gauge but jeep had been towed alot. I use 5w-30. Any recomendations on oil gauge?
post #4 of 11 Old 06-17-2013, 11:49 AM
LumpyGrits
Why such a 'lite' oil?
Go to at least 10W-30 or 15W-40 oil.
I have 118K+ miles on mine and use Castrol 20W-50 all year.
VDO gauges are good.
LG
post #5 of 11 Old 06-17-2013, 11:58 AM
Jawbox
Go 15-40w... You might want to pull the pan though! I've got a 151 and when I pulled the pan I found my pickup was really clogged. It's a pretty easy job and worth replacing the oil pump and pickup at the same time. Also, do the mechanical guage... autometer makes some that match pretty well. If you do a mechanical gauge, I suggest a copper line.
Jawbox is offline
post #6 of 11 Old 06-17-2013, 12:12 PM
LumpyGrits
Autometer=China made POS!
All USA made here.....
http://www.marshallinstruments.com/
LG
post #7 of 11 Old 06-17-2013, 10:20 PM
james04si
james04si's Avatar
1977 CJ5
LG
Pretty sure only the econo line autogage are from China and the regular auto meters are manufactured in Illinois. I have autometer gages and love them.
james04si is online now
post #8 of 11 Old 06-17-2013, 10:55 PM
wellmax
might try the 15w40 shell rotella oil
if the problem continues the add a bottle of lucas oil stabilizer
that 5 weight oil is too thin
wellmax is offline
post #9 of 11 Old 06-17-2013, 11:47 PM
LumpyGrits
Source
LG
post #10 of 11 Old 06-19-2013, 09:31 AM
Jawbox
I missed something in the original post. If you get more lifter noise as you run, I'm feeling more sure you've got oiling problems! Do get a mechanical gauge, but I'd really say it would be a good idea to take an afternoon and throw in a new oil pump and pickup. When you replace the oil, use the 15-40 rotella.
It's a pretty easy and cheap job.
Jawbox is offline
post #11 of 11 Old 06-19-2013, 09:53 AM
wellmax
I have a 1984 jeep with 4 cylinder 150 ci engine, I know it is a different engine than yours.
but, I had a new long block installed, after about 5k miles one of the valves started to stick,
when it did the motor made a bad clicking noise.
an old dude at the napa store told me there was only two things I could do:
1. try marvel mystery oil, he said many times that oil will help keep the valve loose. (1 qt.- half in the oil crankcase and half in the fuel tank.
2. if the mmo does not work, then you only have the following option: pull the head and have it reworked.
I had changed the oil, was running synthetic oil, that help some, but did not completely solve the sticky valve problem.
the day I added the mmo to the crankcase and gas tank the valve was sticking and making a bad noise.
believe this or not:
within 30 seconds of adding the mmo to the motor oil, the clicking stopped and I only heard it for just a few seconds one other time a few months later.
that was 3 or 4 years ago and have never heard the clicking noise again.
I change oil in the old jeep about every 2 years, as I do not drive it much.
but always use synthetic oil 10w40 and add 1 qt of mmo to tank and crankcase.
knock on wood, so far, so good,
its worth a try before to have the motor or head torn down for rebuild.
some do not like synthetic oil, but I believe it has better lube properties than dino oil, if you are having lube related problems, as you are.
wellmax is offline
