Oil From PCV Valve... - JeepForum.com
post #1 of 6 Old 01-09-2010, 12:11 PM Thread Starter
poppatello
I have oil that seems to becoming from the or around the PCV valve. I'm thinking replace it? New Air filter on other end of valve cover. The PCV valve attaches to a hose that runs to the carb...
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 6 Old 01-09-2010, 12:15 PM
Coiz
1979 CJ7
The valve itself should rattle when you shake it to know it is functioning. If it is leaking oil from around the seal, then I guess you would have to replace it.
BTW: Cool avatar.
Mike
Coiz is offline
post #3 of 6 Old 01-09-2010, 12:18 PM Thread Starter
poppatello
Thanks...
I just want to make sure it isn't something else that could be causing the blow by...
Paved Roads
post #4 of 6 Old 01-09-2010, 06:44 PM
SecretSquirrel
1980 CJ7
If oil is coming from around the PCV valve it may be something else. Could be the gromet it mounts in, or internal egnine issues.
SecretSquirrel is offline
post #5 of 6 Old 01-09-2010, 08:07 PM Thread Starter
poppatello
If it's an internal engine issue. What do I look for?
Paved Roads
post #6 of 6 Old 01-09-2010, 09:01 PM
wellmax
check the obovious, cracked rubber gasket, stopped up pvc valve.
But you should be getting a good solid vac on the pvc line back to the carb.
The pvc valve on my 84 4 banger is tee off to the brake boster.
be sure the other hole in top of valve cover (incoming air) is not stopped up and you are getting clean filter air into the valve cover. The air that goes to my valve cover comes from a connection inside the carb air filter. so the air going to the valve cover is clean filtered air.
If all is working properly you should have so much vaccum pull that you should not be getting much oil leakage.
so check your vac pull.
wellmax is offline
Replacements for Liquid Check Valve/Roll Over valve jpd1899 Jeep CJ Forum 143 08-25-2015 09:07 PM
Changing valve cover gaskets/valve covers gtrpup2 Jeep CJ Forum 20 03-28-2013 07:35 PM
Brake Combination Valve/Proportioning Valve Question Wrangler1642 Jeep CJ Forum 1 01-17-2011 04:43 PM
Deceleration Valve/Anti-Backfire Valve David Augusto Jeep CJ Forum 2 01-30-2009 07:09 PM
Gas check valve and anti roll over valve ? NCHornet Jeep CJ Forum 1 10-10-2006 06:18 PM
