Oil Pan Removal - Is there a trick? - JeepForum.com
post #1 of 4 Old 01-08-2012, 12:37 PM Thread Starter
bigdee2
I'm having trouble removing the oil pan on my 78 CJ-7 304 V-8. I can get it down from the bottom of the block, but the oil pick-up seems to keep hanging the oil pan up. Any suggestions?
bigdee2 is offline
post #2 of 4 Old 01-08-2012, 02:21 PM
TKFireman
1980 CJ7
You may have to tilt it to get it to clear one motor mount first,which will give you a little more wiggle room to aline the pick up with the hole in the pan the pick up goes through. I had to keep tilting and wiggleing the pan until I got it just right to come down when I did it. It is also possible that the pickup rotaed a bit over time to one side or the other, but I wouldn't want to turn it if I could help it, it should be sealed to the block, wouldn't want to brake that seal.
"If your gonna be dumb, you gotta be tough"
TKFireman is offline
post #3 of 4 Old 01-08-2012, 02:56 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
also, the bell housing plate needs to come off, there's a tab on it that it will snag on
if you havent resealed an amc v8 oil pan before, do your research on how, its def a very touchy thing to get just right
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #4 of 4 Old 01-08-2012, 03:01 PM Thread Starter
bigdee2
Success
Got it off - I removed the pasenger side motor mount and used a jack to support that side of the engine - that motor mount kept hanging up the pan by like a quarter inch. Came right off then. Thanks.
bigdee2 is offline
Body Alignment Trick.... Exposed Jeep CJ Forum 14 04-09-2009 01:15 PM
Trick to getting a t5 Shifter off? elks96 Jeep CJ Forum 3 03-16-2009 09:40 PM
new trick when soldering a gas tank? Thorwon Jeep CJ Forum 15 02-13-2009 10:26 AM
E brake cable trick for you ReconRabbit Jeep CJ Forum 2 04-25-2008 09:03 PM
Wiper arm removal, what's the trick? PhatBasturd Jeep CJ Forum 3 01-16-2008 08:09 AM
