Oil pan question?? - JeepForum.com
post #1 of 6 Old 01-08-2012, 12:20 AM Thread Starter
neemcj
Oil pan question??
Ok, gotta replace oil pump. Can I do it with motor in place on 84 258 and how big a job?? Any input would be great. Thanks.
"Neem"
neemcj is offline
post #2 of 6 Old 01-08-2012, 02:48 AM
hp_lovecraft
1981 CJ5
No need to remove motor. Just pull the oil pan, and then the oil pump.
One of the bolts is really hard to get to Some unhook one engine mount, and raise the engine slightly to reach it. Or use a very small wrench. I used the small wrench, but replaced the bolt with an allen-head so next time will be easier.
I had to also remove the front drive-shaft, and cross-bar to get the pan out.
hp_lovecraft is offline
post #3 of 6 Old 01-08-2012, 06:11 AM
CrazyHorse6
1979 CJ7
That's exactly right. Messy job but not too difficult. Don't mess with a cork seal on the pan - use the blue rubber one piece from felco.
CJ7, 258, Dana 20 T-case, Dana 30 & AMC 20, TFI Ignition upgrade, MC 2150 carb, YJ tub mod
CrazyHorse6 is offline
post #4 of 6 Old 01-08-2012, 01:11 PM
hp_lovecraft
1981 CJ5
That 2-piece cork seal was tough. The way its setup is you have to have it sitting on the block first, then set the pan onto it. Fine if you have the engine upside down on a mount....
What I did was put a very thin bead of RTV on the gaskets so they would stick to the block. That actually helped since it takes some work to get the pan into position.
post #5 of 6 Old 01-08-2012, 03:56 PM Thread Starter
neemcj
Thanks guys, It didn't looks too bad but I wanted to get some input from someone that had replaced one in the truck.
"Neem"
neemcj is offline
post #6 of 6 Old 01-08-2012, 08:52 PM
gosupes
You will have to remove the pass side motor mount to get the pan off. Make sure you have the right pickup tube for the pump. They made a couple of designs, search on here, been discussed before.
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
New lift question - shackle angle question *Thunder Jeep CJ Forum 2 10-09-2009 08:53 AM
Timing question & adjusting carb question. jatepper Jeep CJ Forum 8 02-22-2009 08:29 PM
Computer question and FUEL INJECTION question MontyWilco Jeep CJ Forum 4 10-11-2006 09:21 PM
