Oil pan gasket rant / question - JeepForum.com
post #1 of 5 Old 06-29-2013, 12:52 PM Thread Starter
ferday
1981 CJ7
The PO used a MASSIVE amount of (clear?) silicone on the oil pan gasket, it's taken me hours to clean the surface properly.
Rant over, is there some areas that I should be silicon on when I put the new gasket on? I have the one piece felpro, the surfaces are pretty good with no major dents or scratches. Any hints to put the gasket on? Should I run a really thin RTV to hold the gasket in the pan for install?
The RMS was a cakewalk compared to this silicone mess
Thanks! I'm frustrated right now, it's 30C outside and I wanna drive my jeep lol
ferday is offline
post #2 of 5 Old 06-29-2013, 12:58 PM
walkerhoundvm
1981 CJ8
Thought about you with the floods last week.
The site for RMS repair also details where to put the black RTV: http://www.neow.net/rms2.html
Basically, it's best to put a thin bead anywhere the oil pan curves - the front and back dips and their shoulders. It's possible the PO did that because that was the only way he could get it to seal - i.e. your oil pan is a little warped or your block hasn't got straight edges.
walkerhoundvm is offline
post #3 of 5 Old 06-29-2013, 03:42 PM
james04si
james04si's Avatar
1977 CJ5
There is no need to use any sealant on the 1 piece felpro gasket or most gaskets for that matter. The gasket alone will seal as long as you have clean flat surfaces on both the oil pan and the block.
james04si is offline
post #4 of 5 Old 06-29-2013, 03:48 PM
LumpyGrits
All I ever used was a bit of Avaition form a gasket to hold things in place for put'n the pan and stuff back on.
LG
LumpyGrits is online now
post #5 of 5 Old 06-29-2013, 04:30 PM
skizriz
1978 CJ7
I believe the instructions that came with my felpro called for rtv at the rms and timing chain cover.
Its about the only thing that doesnt leak on mine.
skizriz is offline
