Oil Leak out of nowhere... - JeepForum.com
post #1 of 4 Old 10-04-2011, 05:35 PM Thread Starter
BoulderCJ
Hey guys -
I drive about 35 miles Mon-Thurs to my master's program up here in Colorado. Pulled into the quickie mart in Boulder, got a drink, started down the road to Denver, steering felt REALLY funny, then corrected itself. Made it to Denver, got out, looked at the jeep, and it was leaking oil like a stuck pig.
I figure that these two events must be related since the Jeep never did this before. I am intimately familiar with it as I do all the work and can't make it make sense.
Long story short I have to get back to Boulder tonight and any advice would help.
BoulderCJ is offline
post #2 of 4 Old 10-04-2011, 05:42 PM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Call a tow truck and a cab.
Where is the leak coming from?
Matt
Matt1981CJ7 is offline
post #3 of 4 Old 10-04-2011, 06:49 PM
ejeeperguy
1982 CJ7
Pics would help. Also you said steering went funny is possibly power steering fluid.
ejeeperguy is offline
post #4 of 4 Old 10-04-2011, 09:05 PM
BagusJeep
1981 CJ7
Hydrauic fluid is quite distinct in smell, texture and taste to engine oil. I suggest you put some on your fingers and have a good old look, smell and lick.
If it is pushing a lot of fluid it will be the engine or the steering (unless you have an auto).
If just a power steering hose check which one. If a high pressure hose forget it for now. It may also be the seals in the steering box.
Depending on how your belts are run you could just take off the PAS belt. Do not run the pump with no fluid, it will not like it.
Quite easy to drive with no PAS, just lean a bit more on the wheel.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
oil leak , steering
CJ5 oil leak marcuscj5 Jeep CJ Forum 9 07-26-2011 12:24 PM
Tried to fix oil leak, now oil leak is worse and engine is running rough rak09 Jeep CJ Forum 21 11-23-2010 10:18 AM
Transfer Case leak & Diff. leak MDH20Ski Jeep CJ Forum 6 09-18-2010 08:46 PM
Oil leak mossman Jeep CJ Forum 5 08-09-2010 05:53 PM
Vacuum Leak/Gas Leak ravinhuxley Jeep CJ Forum 2 03-09-2005 08:18 AM
