Oil leak from distributor - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Oil leak from distributor
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Rough Country Jeep Suspension Deals at Rockridge 4WD!Looking to re-gear?! CRAZY DEALS ON YUKON GEARS right here
Unread 01-19-2014, 07:13 PM   #1
Ironhorse2021
Hi all,
I did a search but didn't find my answer. I have oil leaking from the drain hole below my distributor cap (in the alum body). I removed the shaft from the housing and was expecting to see a seal of some kind. Instead there are just the two bushings. Some minor wear in the shaft but nothing too bad. Looks like oil is traveling up the shaft into the dist body. Why is this happening ? What is the fix ? Thanks for your help.
Ironhorse2021 is offline   Reply With Quote
Unread 01-19-2014, 08:20 PM   #2
Truck633
GO ONE MORE!!
Truck633's Avatar
Excessive blow-by in the crankcase. I battled the same problem with my old 258. If I recall, someone on here had mentioned a better PCV valve, however it didn't work on my case. I had to rebuild! (it was time anyway)
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is online now   Reply With Quote
Unread 01-19-2014, 08:28 PM   #3
LumpyGrits
Clean/replace your PCV valve and see if that fixes it.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote
Unread 01-20-2014, 03:29 AM   #4
86cj74.2L
86cj74.2L's Avatar
Is the play in your distributor up and down or side to side?
Side to side is bad.
When mopar came out with the 4.0 version of the 258 they went to a fixed orifice crank case ventilation system.
It may help. I know I put one on my Saturn and it helped oil usage and idle quality.
86cj74.2L is offline   Reply With Quote
Unread 01-21-2014, 06:51 PM   #5
Ironhorse2021
Thanks for all the input. I've checked the Pcv valve at its seems to rattle freely but will replace it anyways. I do have a breather in my valve cover along with the pcv so I can't see how I could have crank case pressure problems ???
I have a little side to side slop in the dist shaft so maybe some bushing wear is the problem. A friend is giving me his old dist so I can compare them.
Unread 01-21-2014, 07:37 PM   #6
LumpyGrits
There should be ZERO play(up/down, side to side)in that dizzy shaft.
LG
Unread 01-21-2014, 07:43 PM   #7
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Is your dizzy a reman'd Motorcraft by chance? If so, I had the same problem with one straight from the box. A replacement didn't have the same problem.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 01-21-2014, 08:29 PM   #8
86cj74.2L
86cj74.2L's Avatar
As a reminder there is also a gasket between the distributor base and the engine block.
