oil leak - JeepForum.com
post #1 of 2 Old 05-25-2004, 05:14 PM Thread Starter
83 cj-7 258
83 cj-7 258's Avatar
oil leak
After i returned home from crusing; I noticed a oil leak. I checked the oil level and it was a little above the low line. I crawed under the jeep and it looked like it was leaking for underneath the motor mount. Is the oil pan's gasket that's leaking, It's a 258. If it is is it hard to replace the gasket. THANKS!
83 cj-7 built Chevy 350, sm420, dana 300. Superlift 4in lift, 33x12.50 mikey thompson mtz.
83 cj-7 258 is offline
post #2 of 2 Old 05-25-2004, 05:58 PM
lord_byron
lord_byron's Avatar
First make sure its actually the oil oan and not the valve cover, oil filter, or oil sending unit leaking. If you do replace the gasket, get the one piece rubber job, get the block and pan really clean, and put the gasket on dry. I just went throught this, so if you have any questions let me know. btw, you have to pull the passenger side motor mount to get the oil pan off, and if its never been off before, it can be a real PIA to break it loose -- mine was practically welded to the block make sure to torque the pan bolts to spec, and you might want to replace your rear seal while you are in there. Here are some links that may help: btw, the oil pan bolt specs are wrong in one of the articles (its not 10 ft pounds for either size bolt); I don't remember them right now, but if you need them I can get them out of my factory manual.
http://jeepin.com/features/rearmain/index.asp
http://www.neow.org/rms1.html
http://www.sierrajeep.com/aluminum.htm
lord_byron is offline
AMC 20 Leak, Need some help DT5150 Jeep CJ Forum 12 08-15-2008 05:02 PM
Another LEAK.... JeromyCJ7 Jeep CJ Forum 8 02-16-2007 08:36 AM
Bad Oil Leak Jeepman065 Jeep CJ Forum 10 09-22-2005 09:33 PM
Vacuum Leak/Gas Leak ravinhuxley Jeep CJ Forum 2 03-09-2005 08:18 AM
O-o-o-oil leak. djfuzzy Jeep CJ Forum 2 06-24-2004 08:23 PM
