oil leak - JeepForum.com
post #1 of 3 Old 05-01-2002, 12:49 PM Thread Starter
Gemelos
Gemelos's Avatar
1976 CJ7
Angry oil leak
i've got an oil leak on the input shaft of my power steering box(1976 cj-7).looks like the oilseal of the stub shaft is blown. am i in trouble or is this an easy repair? any exprience, all help is welcome.
greeting <img border="0" title="" alt="[Frown]" src="frown.gif" />
Gemelos is offline
post #2 of 3 Old 05-01-2002, 10:14 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
Post
There are two ways you can do this. first the short cut tricklace the box in a vise, remove the snap ring from the front of the seal. Take two long thin wood or sheet metal screws and CAREFULLY screw them into the seal, being sure not to nick the housing or stub shaft.grasp the screws with 2 pair of pliers and carefully pull the dust shield and seal from the housing.The second way is to remove the stub shaft adjuster plug and remove the seals with it off the box. Be sure to follow the dissambly/assembly procedures to properly adj. the preload while reassembling.
bazinga
jeepdaddy2000 is offline
post #3 of 3 Old 05-02-2002, 07:49 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Arrow
Unfortunately a very common problem with Power Steering in CJs
4wheeler4CJ is offline
AMC 20 Leak, Need some help DT5150 Jeep CJ Forum 12 08-15-2008 05:02 PM
Another LEAK.... JeromyCJ7 Jeep CJ Forum 8 02-16-2007 08:36 AM
Bad Oil Leak Jeepman065 Jeep CJ Forum 10 09-22-2005 09:33 PM
Vacuum Leak/Gas Leak ravinhuxley Jeep CJ Forum 2 03-09-2005 08:18 AM
O-o-o-oil leak. djfuzzy Jeep CJ Forum 2 06-24-2004 08:23 PM
