Oil Leak ??? - JeepForum.com
post #1 of 2 Old 09-08-2011, 12:15 PM Thread Starter
Frenimy
1981 CJ7
Oil Leak ???
I have an oil leak and it is either the rear of the oil pan or the back of the valve cover as I have learned is also common. The problem I see is that I cant see behind the valve cover or get a hand behind it to check it out. Does anyone know a tip or trick that will help get the valve cover and firewall apart a little bit to get in a check to see which end of the motor is leaking?
Thanks
Chris
1981 CJ7 I6 258, NP435, Dana 300 Twin Sticks, AMC 20 & Dana 30 with Lockers, On board air, 33" X 12.50" tires
Frenimy is offline
post #2 of 2 Old 09-08-2011, 12:39 PM
MrWonderful73
Have someone with small hands, wife, girlfriend, child, midget....reach behind the valve cover. Being a Jeep its probably leaking from both places.
MrWonderful73 is offline
Tried to fix oil leak, now oil leak is worse and engine is running rough rak09 Jeep CJ Forum 21 11-23-2010 10:18 AM
Transfer Case leak & Diff. leak MDH20Ski Jeep CJ Forum 6 09-18-2010 08:46 PM
Vacuum Leak/Gas Leak ravinhuxley Jeep CJ Forum 2 03-09-2005 08:18 AM
304 Oil Leak ozarkcj7 Jeep CJ Forum 10 10-14-2004 01:46 PM
Oil Leak BigMike20 Jeep CJ Forum 0 09-12-2004 03:19 PM
