Oil Filter Part Numbers for 6 Cylinder 258 - JeepForum.com
post #1 of 24 Old 08-10-2011, 02:11 PM Thread Starter
JH80CJ7
Junior Member
JH80CJ7's Avatar
1980 CJ7
After doing a search for this here on the forum with limited success. I am posting here looking for the proper oil filter part numbers for filters for use in my 80 CJ7. It has an '82 6 Cylinder 258. I am getting info for Fram PH25 & FFPH3506. I have read here that the Fram filters have really dropped in quality. I would like the right filter that has a quality anti-drainback valve to help reduce dry starts. Once I get the right PN I am looking to order several to keep on the shelf. Thanks in advance.
JH80CJ7 is offline
post #2 of 24 Old 08-10-2011, 03:00 PM
twoleos617
Fram= crap
i stick with Bosch or Mobile1 depending on the specials running at the time
WIX filters also get pretty good reviews.
i find that some parts stores will swap filters in some of there monthly oil/filter specials just to get the buisness.
this way, i can get a filter or oil for whatever vehicle will be next in line for its oil change. this way, i always have one extra waiting for its time to be used when im ready and the next purchace wont be so costly.
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #3 of 24 Old 08-10-2011, 05:19 PM
james04si
james04si's Avatar
1977 CJ5
I get the Napa gold from fleetfilter.com . It is a wix filter with the napa logo. My year calls for the 1258 but for 82+ it shows 1522. looks like the difference is the 1258 is shorter and fatter where as the 1522 is a little longer and skinnier. Both show to have the antidrainback valve and the same thread size so either should work.
james04si is offline
post #4 of 24 Old 08-10-2011, 06:14 PM
hp_lovecraft
1981 CJ5
My engine is also a '77. I've always used The PH25 because its the only one that seems to fit.
Napa had given me the 1258, but it hit the engine mount. Maybe I'd have better luck with the 1522?
Note: I'm beginning to suspect that my engine mount itself might be bent, or damaged? Might be worth replacing at this point, as it would mean I have more choices then the PH25.
hp_lovecraft is offline
post #5 of 24 Old 08-10-2011, 06:25 PM
WindKnot
1977 CJ7
I also have a 1977. I use a NAPA ProSelect 21258 and it works and fits great.
Safety Bypass valve, steel spring, metal baseplate. It's my understanding that there is a "long version" as well. I'm also told it's a WIX filter.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #6 of 24 Old 08-10-2011, 06:38 PM
WindKnot
1977 CJ7
Mine clears the MM easily. Does yours have a wide radiussed relief cut from the mount? Mine does. If it didn't it would definitely interfere with a filter.
WindKnot is offline
post #7 of 24 Old 08-10-2011, 06:41 PM
james04si
james04si's Avatar
1977 CJ5
I didnt have that problem then it slowly got closer and closer until the filter was touching the mount. I ended up replacing the mounts with polyurethane mounts and have plenty of space again. Sounds like your mounts rubber material has seperated like mine did.
post #8 of 24 Old 08-10-2011, 07:00 PM Thread Starter
JH80CJ7
Junior Member
JH80CJ7's Avatar
1980 CJ7
Lots of good info. I have also heard that the K&N HP-2003 is an option for various years L6 and and V8 models. Any thoughts on that filter? Gonna do the search on that NAPA filter. I was at a "NAPA" parts store earlier today and they told me no more NAPA gold filters? Name change maybe? I didn't get into with the counter guy.
JH80CJ7 is offline
post #9 of 24 Old 08-10-2011, 09:57 PM
james04si
james04si's Avatar
1977 CJ5
yeah there may be a name change. I remember the first order they were black and now they are white. It still shows up on their website as napa gold. Ill take a look at what the box says when I get home.
post #10 of 24 Old 08-11-2011, 10:56 AM
james04si
james04si's Avatar
1977 CJ5
Sorry I didn't get back last night. Just checked and they are still called nap gold. Even checked napas site and it says napa gold there too.
post #11 of 24 Old 08-11-2011, 11:59 AM
VACJ7
VACJ7's Avatar
I use WIX 51522 which also comes in a 12 unit Master Pack (51522MP). You can get a case of 12 on ebay for 10.00 and free shipping.
VACJ7 is offline
post #12 of 24 Old 08-11-2011, 12:50 PM
Renegade82
1982 CJ7
NAPA gold oil filters are made by WIX. I could always remember that number because of the 258 in it. It used to be 51258 but now it's just 1258. Napa's is the same number now also.
Renegade82 is offline
post #13 of 24 Old 08-12-2011, 02:01 AM
james04si
james04si's Avatar
1977 CJ5
Have you actually bought a case of the 51522MP through ebay for that price? I would assume that is actually for a single filter as the actual case of 12 from anywhere else is going for $50+. If you have purchased it from ebay for that price for a case that is an awesome deal on the filters.
post #14 of 24 Old 08-12-2011, 05:23 PM
VACJ7
VACJ7's Avatar
I have not bought that case on ebay yet, but the part number matches the WIX part number and pic exactly.
VACJ7 is offline
post #15 of 24 Old 08-12-2011, 05:44 PM
SLO_Ken
Wix 51522MP Oil Filter
I did a "buy it now" last night, and paid immediately via Paypal. This morning I had an email from Paypal saying the seller had cancelled my purchase and refunded my payment. I sent a response to the seller asking for an explanation. No word yet...
SLO_Ken is offline
Need part numbers for offset air filter housing for MC2100 Ken4444 Jeep CJ Forum 20 04-24-2011 09:31 PM
Junkyard TBI, ECM part numbers? Jon In Tucson Jeep CJ Forum 9 02-07-2011 06:03 PM
MC2100 Part Numbers godfather1138 Jeep CJ Forum 5 07-09-2008 05:40 PM
Factory OE Part Numbers MuddyMules Jeep CJ Forum 18 07-11-2006 06:32 PM
What Parts/Part Numbers For My SOA? Military Jeeper Jeep CJ Forum 1 10-14-2005 09:39 AM
