Oil in air cleaner - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Oil in air cleaner
Great prices on seating!--Oconee Off-RoadTJ 5.25" Speaker Adapters - NalinMFGTJ, YJ & LJ Drop Down Tail Gate Conversion Kit
Unread 08-12-2013, 08:41 PM   #1
Burnie
Junior Member
Oil in air cleaner
I don't think this is normal but after I drive my 84 cj with a 258 there is oil residue in the air cleaner which is stock. Where should I start?
Burnie is offline   Reply With Quote
Unread 08-12-2013, 10:24 PM   #2
MrElPoderozo
1979 CJ7
Tired piston rings?
I don't know how many miles are on the engine but sound to me like you getting something we call blow-bi (don't know if I spelled that right ) that's when the piston ring are very old OR they were installed with to much gap and they are allowing oil to pass between the piston and the block,that oil gets push back down to the oil pan in form of a mist and comes out trough the breather into the carburetor cover. I would do a compression test to begin with,this would tell you whats going on with your engine if compression test its ok then check the PCV valve. Sometimes the jeep its running good but its putting too much oil into the carburetor cover and you have to try to get it out of there cause you don't want oil mixed air and gas,so some people try the oil breather catch can method and just empty it out once in a wile, its cheaper then rebuilding the engine and at least will give you a chance to save up for it,like I said I don't know your situation but that's what I would do if I was you.That's all I can come up with for now,good luck!
MrElPoderozo is offline   Reply With Quote
Unread 08-12-2013, 10:40 PM   #3
LumpyGrits
Blow-by cause the engine is 'tired'.
Go to a thicker oil. I run Castrol 20W-50 year round.
LG
LumpyGrits is offline   Reply With Quote
Unread 08-12-2013, 10:41 PM   #4
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Check your PCV system.
Go here to learn more about it.
Matt
Matt1981CJ7 is online now   Reply With Quote
Unread 08-14-2013, 12:24 AM   #5
Burnie
Junior Member
Thanks I'll check the PVC system first then I like the can suggestion if the PVC doesn't fix the problem.
Unread 08-14-2013, 04:52 AM   #6
waterdowg
How much oil? Do you have a filter attached to the PCV breather tube?
waterdowg is offline   Reply With Quote
Unread 08-14-2013, 04:10 PM   #7
Burnie
Junior Member
Yes bUt it's pretty soaked from original owner it all needs to be changed out, PVC breather etc. thanks
Unread 08-14-2013, 07:18 PM   #8
UBERK
1976 CJ7
...I like the can suggestion if the PVC doesn't fix the problem.
As in a "catch-can"..? An air seperator from HD or Lowes can be rigged to work for <$20, however keep in mind thats just a band-aid and doesnt cure the problem.
UBERK is offline   Reply With Quote
Unread 08-14-2013, 08:16 PM   #9
CJ51973
Valve cover passages can clog. Use Matt's diagram and make sure everything is clean. I had an old Subaru that I made tee deal in the line going to the breather so the oil would settle in a mason jar. Then I would just pour it back in.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline   Reply With Quote
Unread 08-14-2013, 08:29 PM   #10
WNC-84CJ7
I bet an old air compressor condensation trap could possibly function in this capacity if positioned right. A mason jar under the hood sounds...beyond rednecky and possibly tough to do in a CJ. Don't get me wrong- I love rednecky when it works!
"No free man shall ever be debarred the use of arms. The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government"
-- Thomas Jefferson, 1 Thomas Jefferson Papers, 334
WNC-84CJ7 is offline   Reply With Quote
Unread 08-15-2013, 04:40 AM   #11
waterdowg
I would change the oil, pcv filter and pcv valve. Then start from there to see how bad it really is. Then check it on a regular basis to see how bad it is. Your going on something from the PO. You don't know what they have done in the past to casue or fix the issue.
Unread 08-15-2013, 11:10 AM   #12
Burnie
Junior Member
Yep who knows what they did, so I'll change out PVC sys and breather and watch, I am planning a trip to my dads in Utah, from Ca in 10 days, I am trying get my dad up to some mountains, a bucket list thing he is 80, so I am hoping all goes well. Thanks for all the support.
Unread 08-15-2013, 11:45 AM   #13
Matt1981CJ7
1981 CJ7
A leak anywhere in the crankcase can cause oil in the breather, even if the PCV is working.
Did u read the link I posted?
Unread 08-15-2013, 01:37 PM   #14
Burnie
Junior Member
Yes I am checking everything, thanks I'll let you know what I find or what happens
Unread 08-15-2013, 01:48 PM   #15
bigjoe
1977 CJ7
Sounds like the issue my 83 Chevy PU has. My shop said most likely a cracked oil ring or worn out ring. I did the catch by-pass trick. Truck is not worth doing much more then back yard YaHaaa fixes.
Seems like everyday is a Monday.
77' CJ-7 84' CJ-7 83' Chevy K10
bigjoe is offline   Reply With Quote
