Oh where oh where has my horn relay gone - JeepForum.com
post #1 of 7 Old 01-16-2011, 03:41 PM Thread Starter
turbogus
1978 CJ5
Ack! Looking at the wiring diagram I thought I knew where the horn relay was. I went to the side of the steering column and found the black line with tracer but wouldn't you know, the line dissapears over the steering column. I didn't have time to remove the steering column shroud to search for the relay, can anyone tell me where that little bugger resides?
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #2 of 7 Old 01-16-2011, 04:33 PM
mylittlecj5
1974 CJ5
I'm not sure on your year, but if you disconnect the horn and press the button, you should be able to hear the relay clicking. It could be under the hood, so listen with the hood up!
Default Jeepers Club #10
mylittlecj5 is offline
post #3 of 7 Old 01-16-2011, 04:41 PM Thread Starter
turbogus
1978 CJ5
Mine's a '78 CJ5, thanks for the tip!
turbogus is offline
post #4 of 7 Old 01-17-2011, 04:21 PM
Redmanchew
Redmanchew's Avatar
1982 CJ7
on my 82 7 it was behind the dash above the headlight switch just kind of hanging around. the relay is pretty good size about 1 1/2" cubed and mine was gray with a black plug and a big honking red wire.
oops seen that you found it in another post..
1982 CJ-7 2003 4.3 chevy vortec, 4L60E, Clocked Dana 300 35 x 12.5 x 15 KM2 on Cragar 399's. Vanco Brake Booster. Power steering conversion. Warn front and rear bumpers with swing away. Moser 1 piece rears. Rear OX.
Support your local MS foundation. You don't know how much this disease sucks until it affects someone you love.
Originally Posted by twoleos617 View Post
To reiterate for the 1,067th time, when towing...
remove rear axle, xfer in N, trans in 5th, remove neg batt cable, key to Run and go??
Redmanchew is offline
post #5 of 7 Old 01-17-2011, 06:14 PM Thread Starter
turbogus
1978 CJ5
Yeppirs, but I still thank you for your help! When I replaced that relay last night I was dismayed that the old one looked rather new and mfd by same maker (lower slovobia) I wonder if they come higher than 20 amp. If it fails again I'm going to use a Standard (Brand Name Standard) relay as their electrical components are superior, especially their Blue Streak line.
turbogus is offline
post #6 of 7 Old 01-17-2011, 06:25 PM
MMPSM
1959 CJ6
Try in the Ebrake area. Mine was hiding there.
MMPSM is offline
post #7 of 7 Old 01-18-2011, 09:08 AM Thread Starter
turbogus
1978 CJ5
Thanks MMPSM, found it and got it replaced. Now that I see Standard auto electric products makes these too, if it fails again I'll go with them.
turbogus is offline
Horn relay dd4bama Jeep CJ Forum 15 07-05-2015 12:11 PM
Horn relay eng49ine Jeep CJ Forum 2 11-15-2009 08:45 AM
Horn Relay 47redwillys Jeep CJ Forum 4 08-30-2009 02:49 PM
Horn Relay On 1986 CJ7 dhood Jeep CJ Forum 10 04-24-2008 09:22 PM
Horn Relay location-wire colors Totallymetal Jeep CJ Forum 7 08-30-2007 11:23 PM
