Offroad Light Wiring - JeepForum.com
post #1 of 11 Old 12-27-2013, 02:11 PM Thread Starter
ocblaze
1979 CJ5
Hey y'all,
Sorry if this is a stupid question but today I was installing my new wiring harness for the offroad lights and have run into a stumbling block. I have everything wired up except for the 12-volt powered wire that goes to the switch.
First: My wiring manual says you can tap into your headlight wiring but I don't want to mess up the headlight wiring and be stuck without lights potentially later down the road.
Second: Does anybody have a good link to how to use a wire tap? I've never used one and since the kit only came with one I don't want to mess it up!
Just so you know this little project of mine snowballed into 4 hours of dash wiring cleaning, organizing, and removing of junk as well as removing the 4-wheeler winch that had a broken cable on it . So this 1 hour project turned into a 6 hour cleaning and organizing but at least the Jeep is much less likely to burst into flames randomly now ! Thanks for the help y'all.
ocblaze is offline
post #2 of 11 Old 12-27-2013, 02:23 PM
82JeepCJ7
1982 CJ7
Some of the cheaper light wiring kits do not include a solenoid. I would wire one in if it did not come with the kit. I went down and bought a buss strip. I have one for constant 12v and another for switched 12v. That way if I want to add something to the system, I am not trying to hack into current systems just to find a 12v source.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #3 of 11 Old 12-27-2013, 06:45 PM
LumpyGrits
I would wire in a relay and take the load out of your switch
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #4 of 11 Old 12-27-2013, 08:16 PM Thread Starter
ocblaze
1979 CJ5
I did wire in a relay and a solenoid. I just don't know which wire to tap for power for the switch. I will eventually put in ground and switched power buss bars but that isn't part of today's plan.
ocblaze is offline
post #5 of 11 Old 12-27-2013, 08:26 PM
lucdog
lucdog's Avatar
1980 CJ5
Originally Posted by ocblaze
i did wire in a relay and a solenoid. I just don't know which wire to tap for power for the switch. I will eventually put in ground and switched power buss bars but that isn't part of today's plan.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #6 of 11 Old 12-27-2013, 08:32 PM
LumpyGrits
Relay and solenoid. How many amps are you pull'n for these lights?
LG
post #7 of 11 Old 12-28-2013, 09:38 AM
ScroungerLee
Do you mean a wire tap like this:
If so the proper way to use it is to throw it out.
ScroungerLee is offline
post #8 of 11 Old 12-28-2013, 11:30 AM
Dngrs1
1979 CJ7
Ah, the 'scotch-lock'. Nice when the plastic gets dry and brittle and falls apart.
I may be getting old or daft or both but what is the purpose of a solenoid in light wiring?
I would rather have a tool I don't need, than need a tool I don't have.
Dngrs1 is offline
post #9 of 11 Old 12-28-2013, 11:33 AM
LumpyGrits
Don't use it!
Learn to solder, and use heat shrink tubing.
LG
post #10 of 11 Old 12-29-2013, 04:57 PM
Shinook
1979 CJ7
I often wonder why more people don't do this to their cars.
I recently rewired our sailboat and must have used a dozen different bus bars and terminal strips, the result is very clean with no taps or bundled wires. If I want to add anything, it's just a matter of wiring it to the bus bar. It seems logical to me to do it the way you did, especially for accessories.
So, why don't more people use it?
Also, why are none of the wiring harnesses using tinned wire
Shinook is offline
post #11 of 11 Old 12-29-2013, 05:57 PM
GlennLever
GlennLever's Avatar
Please do not use the wire tap, they corrode, fall apart, do not make good connections and break wires.
You should not use the existing headlight circuit as a power source.
Use a bus bar for both the power source and grounds directly from the battery using relays.
There are lots of good threads on here, yes I know the search function doews not work well, try using Google to search.
I attempted to write some information after reading threads here
http://www.jeepforum.com/forum/f8/cj...l#post13354201
http://www.jeepforum.com/forum/f8/cj...l#post13425120
http://www.jeepforum.com/forum/f8/cj...l#post13433362
http://www.jeepforum.com/forum/f8/cj...l#post14168684
Glenn R. Lever
Rochester, New York 14617-2012
My Web Site
My restoration thread here on the Jeep forum
GlennLever is offline
