Official AMC V8 swap thread/Need more
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
#2 |
WTF is that?
Axles will be OK, worry about that later. Google Nutter bypass and you will get 1000's of results. Search on here as well! Lot's of info.
1984 CJ 7, SBC 350TBI, 700R4, D 300, AMC 20, D30, 35" Mickeys, 3.54 Gears, 4" susp. Lift, 2" body lift. AMC 20 Write Up In Progress - 4.56 gears, Aussie Rear Locker, Moser 1 Piece Axles Coming Soon - CV Shafts, Welded Tubes, trusses |
#3 |
The HEI is a single wire from the ignition side of the key. You can purchase a continuous duty relay and use it to power the dist. Power from the battery, power to the dist, power from the ignition side of the key to the I terminal of the relay. While you are waiting, you can run your old points dist. Neither the HEI or the stock 304 carb require the electronic ignition module, so the Nutter bypass doesn't come into play. you will want to get a wiring diagram of the 84 so you can decide which wires you want to pull.
If you are going to keep the stock axles, you will want to go to one piece in the rear. Not sure about your driveline question. If they are the wrong length, take them to a driveline shop and have them re-tubed. |
#4 | |
#5 |
WTF is that?
Stock shafts have 3 inches of travel. So once your all set, take some measurements to see the length you need, then measure your shaft at mid travel. That gives you 1 1/2 inch travel in each direction. I would say you need at least one inch of travel. It's failry cheap to have them cut down or extended. I paid $55 to have mine cut down and a buddy paid $86 to have his extended.
#6 | ||
#7 |
Does anyone know the answer to the question I posted on jeepdaddy2000's comments? |
#8 | |
A starter solenoid is a high amp, short duration relay. While it can work, it's life expediency is relatively short compared to a low amp long duration continuous duty relay. These are usually available on the fog light rack of your local Wal-Mart. |
#9 | |
#10 | |
WTF is that?
#11 | |
#12 |
WTF is that?
Any driveline or machine shop will be able to handle that for you. Just look around, there's bound to be several in your area.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
