Official AMC V8 swap thread - Page 8 - JeepForum.com
post #106 of 494 Old 11-16-2007, 01:47 PM
atom73
atom73's Avatar
1977 CJ5
I will be removing the engine this weekend. Should I replace the clutch disk or plate now that the engine will be out. Seems to me that I should go ahead and replace that since it is a wear part and I will have access to it. What do you think?
Mike
atom73 is offline
post #107 of 494 Old 11-17-2007, 12:16 PM
atom73
atom73's Avatar
1977 CJ5
I think very few people read these posts/360 motor mounts Bombproof
I think there are only a few guys here that read this part of the forum. I still think its a great idea, got my 304 out this morning with no problem thanks to this section, I will however re-post this in the regular forum just because the higher vis may get me a good reply. I will be replacing the 304 that I took out this am with a HO 360 that I am having put together and I want to use heavy duty motor mounts due to increased hp and heavier projected use. I want to go with the MORE BPs but am looking for a less expensive place to order them, anyone out there have any luck finding them for a AMC 360 1977 CJ5 for a decent price? Also, do I need to buy the rubber bushings too or do the mounts come with everything.
Mike
atom73 is offline
post #108 of 494 Old 11-17-2007, 12:34 PM
fuzz401
1978 CJ7
if you dont want to go with the more mounts just get the urthane mounts for the factory set up thats all I use on mine and I flash the converter to 4000 rpm at launch at the drags and get a 1.75 60' and a 12.05@108 mph with 33x10.50x15 slicks and they have held up good for me - I have been useing my factory mounts now for 30 years and only lost 1 mount with a 304-360-401 since 1979 just a thought
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #109 of 494 Old 11-18-2007, 07:15 AM
atom73
atom73's Avatar
1977 CJ5
Thanks for the reply Fuzz, I will give it some thought. Not neccessarily sold on the MORE mounts yet.
Mike
atom73 is offline
post #110 of 494 Old 11-27-2007, 01:50 PM
jeffarcher401
1979 J-Series Truck
just to add my $.02 MORE makes some really good and quality stuff. My shackle reversal kit was great. The stock motor mounts I'm using are in my opinion bombproof
jeffarcher401 is offline
post #111 of 494 Old 12-05-2007, 07:30 PM
710 Cap
Awesome thread guys. After posting a thread a week or two back of thinking about rebuilding my 258, I am now in the market for a 360. I have an 85 CJ7 with a 258, T176, Dana 300. (I didn't know this until someone told me..LOL.)
85 CJ7. Dual dipsticks, overhead ashtray. Chrome muffler bearings, twin turbo deucenhoffit's, 4 in the floor, 5th under the seat. :)
710 Cap is offline
post #112 of 494 Old 12-08-2007, 08:50 PM
BlueFalcon
1980 CJ7
Ive currently got a 304, but was looking at rebuilding a 401 and dropping it in. Would I get much increase in the 401 vs my 304? This would be the biggest thing Ive ever done with the jeep. Also, is there a website or anything that could teach me about engines? cause im clueless when people start talking about cams and boring and all that terminology, but I really want to learn it all.
BlueFalcon is offline
post #113 of 494 Old 12-10-2007, 09:22 PM Thread Starter
BLS33
Chief of the brain police
BLS33's Avatar
Are we talking stock configurations or modified engines?
BLS33 is offline
post #114 of 494 Old 12-11-2007, 08:21 PM
BlueFalcon
1980 CJ7
pretty stock 304, but if I did a 401, then I would do stock/performance. with what I could afford. If not then Id upgrade my 304. I think I'm gonna go with a 401, I just need major guidance on what Im doin. I am going to a junkyard soon. Whats a good way to check the engine if its decent or not? and more importantly, if its an AMC 401?
Tim
post #115 of 494 Old 12-12-2007, 07:44 AM
LSUtiger
1980 CJ5
Hey Tim,
I have been looking for a 401 around here for awhile now. If you look at a junkyard, the block will be stamped above the driver's side motor mount. Look at your 304, it will have 304 stamped in the same place. I think that it will be much easier and cheaper to find a 360. A running 401 is going to cost about $1000. And it will probably need to be rebuilt. A 360 will cost around$300. Really it is the availability, I have been looking for a year. If you find 2 let me know. Good Luck.
Brady
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #116 of 494 Old 12-13-2007, 12:23 AM
BlueFalcon
1980 CJ7
Will do, Im gonna check some junkyards over near houston. Thanks for the info on stamp location. Will do my best to try and find 2. Im not in any big hurry so Im gonna keep 401 at the top for a while. geaux tigers
Tim
post #117 of 494 Old 12-13-2007, 09:16 AM
LSUtiger
1980 CJ5
This on ebay but it is a little expensive for me. Maybe if it was running. I also want the dogleg ports instead of the rectangular ports. http://cgi.ebay.com/ebaymotors/ws/eB...sid=p3907.m32f
LSUtiger is offline
post #118 of 494 Old 12-13-2007, 06:46 PM
BlueFalcon
1980 CJ7
whats the difference between dog leg and rectangular
post #119 of 494 Old 12-14-2007, 05:37 AM
fuzz401
1978 CJ7
rectangular were used up to 69 and these motors have 7/16 head bolts
dog leg were from 70 up and use 1/2 head bolts
dog leg flow better then the rectangular ports
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #120 of 494 Old 12-14-2007, 08:41 PM
BlueFalcon
1980 CJ7
Got it. Thank you much sir.
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
