Official AMC V8 swap thread - Page 7 - JeepForum.com
post #91 of 494 Old 10-02-2007, 10:52 AM Thread Starter
BLS33
Chief of the brain police
BLS33's Avatar
The T4 should bolt to any AMC V8, if I'm not mistaken it was behind some 258's.
BLS33 is offline
post #92 of 494 Old 10-08-2007, 09:51 PM
speeddemon651
I have a 84 CJ7. I bought it with a attempt to swap in a 360. The engine was barely bolted down but everythng was there. To start off the jeep in the front end, AMC 360 engine , M.O.R.E. bomb proof engine mounts, "CJ bell housing", Centerforce dual friction clutch, stock 4 speed 176 or 4 ( not sure), stock dana 300, stock axles/ drive shafts.
My problem is the engine is mounted and when I get the bell housing on, trans and transfer case and go to put the skid plate on and connect the drive shafts, The lower skid plate mounts up about 2 1/2 - 3 inches to far toward the rear to even come close to bolt up, and the drive shafts are too long to bolt up in the rear and too short t bolt up in the front. MY first thoughts were that the bell housing must be the wrong one and had been left on from the wagoneer the 360 came out of. I bought another bell housing off ebay for a cj7 and the guy said its te correct one for the amc V8 to fit in a cj7 and they were exactly the same. So at this point, I'm not sure what it is? Does anyone have any ideas ? anyone else ran into this problem. I know that answer is going to be a stupid one but at this point just need some direction, Anyone have a measurement on how deep their amc 304 cj bell housing is ?
speeddemon651 is offline
post #93 of 494 Old 10-09-2007, 05:26 AM
supraman1990
supraman1990's Avatar
1980 CJ5
sounds like either your engine is too far back, or they swapped tranys. You could of originally had a 4 banger, which would mean the engine is now farther back in the bay making the shafts as you say, or he could of swapped trannys to a longer one.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #94 of 494 Old 10-10-2007, 10:07 AM
drespecki
1983 CJ7
I am dropping in a 360 into a 84' cj7 that had the 4 banger also...is the stock location of the mounts okay for the 360 and a tf999? or should it be moved forward a bit? I really would like to use the stock holes in the frame from the original mount location.
It only hurts while you're breathing..
drespecki is offline
post #95 of 494 Old 10-10-2007, 10:30 AM
jfrdog
Jeepin' til I die!
jfrdog's Avatar
1980 CJ7
I swapped in a 304 and used M.O.R.E. bolt-in engine mounts, seem to work well. Don't know if they have what your looking for or not or if you want to fab your own. Hope the 360 works for you!!!
Still A n00bIe NOT!!!
80' CJ-7 w/ an a AMC 304 V8 with 5.25" SL (4" leafs and 1.25" Shackle lift), 1" BL and 36's Super Swamper TSLs
jfrdog is offline
post #96 of 494 Old 10-16-2007, 11:00 PM
drespecki
1983 CJ7
Anyone know if the location of the 4 cylinder motor mount holes will be okay for the 360 motor install?
post #97 of 494 Old 10-22-2007, 07:13 PM
atom73
atom73's Avatar
1977 CJ5
360 for a 304
I am doing a 360 for a 304 swap in my 77 CJ5. One of the questions I have is about my tranny, its a T-18 4speed man. Since I am going to have the engine out, should I go ahead and do the tranny too? The way I figure it, now is the time to throw a new tranny in and make sure that is up to snuff too. I am buying a "turn-key" HO 360 so I can save some time with not having to do a re-build. If I do the tranny too then I could conceiveably install the two components at the same time and ensure the drive train is solid. should I also do the clutch and how difficult is the clutch to do with all the other stuff I am planning. The engine swap should be pretty straightforward, and the tranny as well since it will accept the 360 like it did the 304. Anyone see any pitfalls?
Mike
atom73 is offline
post #98 of 494 Old 10-23-2007, 03:39 PM
jp360cj
1977 CJ7
speeddemon651....
I'd have to agree with supraman that it was probably an original 4 cylinder. I'd give you the measurements on where my frame mounts are, but my Jeep's about 100 miles away right now. If someone does have these measurements you could figure out if that's the problem. Also, i don't know if the v8s and I6s are supposed to use the same holes in the frame, but that's what i did and it fit fine.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #99 of 494 Old 10-23-2007, 03:42 PM
jp360cj
1977 CJ7
Oh and 1 more thing, to all of y'all going with the 360....excellent choice, amazing seat of the pants feel, lots more power than a 304, and just plain cooler than a 350.
jp360cj is offline
post #100 of 494 Old 11-05-2007, 07:53 PM
atom73
atom73's Avatar
1977 CJ5
Flexplate and flywheel
Could someone talk more about "Flexplates" and getting the flywheel balanced. What is the flexplate? and how does one balance a flywheel, why is that necessary if I am swapping a 360 for a 304, and where are the flexplate and flywheel? Excuse my ignorance.
Mike
atom73 is offline
post #101 of 494 Old 11-05-2007, 08:17 PM
jp360cj
1977 CJ7
The flexplate and flywheel are essentially the same thing. It bolts to the back of the crankshaft. It looks like a big gear on the back of the motor. The starter turns the flywheel/flexplate to turn the motor. Typically, it's referred to as a flexplate on an automatic tranny, and a flywheel on a manual. the flexplates are usually thinner than the flywheels.
The flywheel/flexplate helps balance the rotating assembly, and the 360s need the weight distributed differently than the 304 to balance it. This is why you can't use 304 flywheel. As far as balancing one, I don't know of any way to do it. I think you have to buy a flywheel for the 360.
jp360cj is offline
post #102 of 494 Old 11-06-2007, 03:27 PM
atom73
atom73's Avatar
1977 CJ5
Cool, thanks. What specifically is the connection between the engine and tranny on a manual trans (mine is the T18). How is power delivered from the crankshaft to the transmission (then down the driveshaft)?
Mike
atom73 is offline
post #103 of 494 Old 11-06-2007, 06:22 PM
spk454
1983 CJ8
clutch pressure plate is bolted to the flywheel with clutch disc sandwiched in between. The disc is splined and turns the trans input shaft (which is supported by the pilot bushing inside the crank). So when the throwout (release) releases the clutch fingers the pressure plate/flywheel assembly turns the disc, which turns the tranny input shaft. Clear as mud?
spk454 is offline
post #104 of 494 Old 11-06-2007, 07:27 PM
atom73
atom73's Avatar
1977 CJ5
Actually yes it is clear. So when I pull the motor, I need to pull it forward enough to get the pilot bushing off the trans input shaft. Once the motor is free of the shaft it can come straight up out of the engine bay (providing there is nothing else in the way). Right?
Mike
atom73 is offline
post #105 of 494 Old 11-10-2007, 12:59 PM
spk454
1983 CJ8
if you're separating motor from bellhousing (not pulling as a unit) the clutch pressure plate will have to clear the shaft last (about 6" aft of pilot bushing). you will also need to remove the clutch fork to allow the throwout to come forward.
spk454 is offline
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
