Official AMC V8 swap thread - Page 6 - JeepForum.com
post #76 of 494 Old 09-03-2007, 06:51 PM
CJfreak
1975 CJ5
Thanks alot BLS33, Cleaned 'em up and switched 'em out and it dropped right in.
Whats that bar that goes from one frame rail to the other right under the oil pan and connects using a couple motor mount bolts? Is it only used with V8's?
'75 CJ5 w/304/T150/D20/D44's/3.07/33" Thornbirds/Glass Body...
CJfreak is offline
post #77 of 494 Old 09-03-2007, 07:19 PM
fuzz401
1978 CJ7
it help tie the frame together there used on 6 & 8's
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #78 of 494 Old 09-03-2007, 07:25 PM Thread Starter
BLS33
Chief of the brain police
BLS33's Avatar
Good stuff! Glad to hear ya' got it in
BLS33 is offline
post #79 of 494 Old 09-04-2007, 05:25 PM
Mike78cj7
1978 CJ7
Bellhousings
I have a T-18A that i plan to put in my cj7 along with a 360. The problem is i don't have a bellhousing. From what I've read all amc bellhousing will bolt up to a 360. But will my t-18 bolt onto the bellhousing that's already on the jeep? The tranny in it right now is a T-4.
Mike78cj7 is offline
post #80 of 494 Old 09-04-2007, 07:58 PM
vtjeeps
vtjeeps's Avatar
transmisions
ok i have two options t18 with a dana 20 .. or a t176 and a 300 .. what would be the best options in gearing and all around durability .? i know the t18 is stronger but the 176 has a little better gear for the road.
The insurance company said its high RISK but i said no no its full width ...
vtjeeps is offline
post #81 of 494 Old 09-04-2007, 08:17 PM
supraman1990
supraman1990's Avatar
1980 CJ5
18 is granny geared, 176 is a little more forgiving. Dana 300 is hands down the better transfer case, lot more after market support.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #82 of 494 Old 09-08-2007, 04:37 PM
puggles
Great thread, very informative.
Some where in this Forum they were talking about a crated 360 for about $2100.00
does anybody know what the site was?
Again great thread
puggles is offline
post #83 of 494 Old 09-09-2007, 11:37 AM
ROCKREADYXJ
any have problems bolting the skid to the trans. I used the more kit and original t-4 and d-300 but it is still off just a little bit. tried reading the post again and no one mentioned it. Thanks
ROCKREADYXJ is offline
post #84 of 494 Old 09-21-2007, 12:03 AM
noflacko
noflacko's Avatar
I feel left out...
I keep reading that any AMC block will fit any AMC tranny. But no one ever talks about the little 150 4banger. I know, I know, not a real engine, but it chugs right along...when I do decide to do anything to it do I build a 304 or 360? Should I just plan on rebuilding my 150? I'm happy dealing with lower HP but What are my REAL options?
I could bore the 4 cyl, I have found a header for it, new carb etc. but what I need to know is will the bigger AMC motors fit my drivetrain? I can build an engine but I can't afford to swap out the whole driveline...
Great thread BTW!
noflacko is offline
post #85 of 494 Old 09-21-2007, 05:14 AM
supraman1990
1980 CJ5
I may be wrong, but it seems to me like the 150 is the Iron Duke, and that is has a Chevrolet bolt pattern. Hence it will bolt right up to an 350 or other small block Chevy motor.
96% complete.
post #86 of 494 Old 09-21-2007, 12:55 PM Thread Starter
BLS33
BLS33's Avatar
The "Iron Duke" is the 151, which if memory serves does have a Chevy bell housing, although it was made by someone else, Pontiac I think. Are you sure you have the 150? If you do have the 151 swapping a SBC may not be the best idea because your tranny is probably pretty light duty.
BLS33 is offline
post #87 of 494 Old 09-21-2007, 07:32 PM
noflacko
noflacko's Avatar
I'm certain...I have been given parts for both and only the 150 parts work...the 151 is different all over. Valve cover gasket, distributor, etc...
Light duty makes sense for my trans but what will go on it? Am I just stuck with rebuilding my 4banger? Fine with me, I'm just fishing for options (that I can afford)...
I can even find cams and headers for it so it's no biggy, just asking for input.
As is, though, no hills or deep mud...
noflacko is offline
post #88 of 494 Old 09-22-2007, 02:26 PM Thread Starter
BLS33
BLS33's Avatar
What transmission do you have? Should be either the T-176 or T4.
BLS33 is offline
post #89 of 494 Old 09-23-2007, 12:58 AM
noflacko
noflacko's Avatar
T-4
New clutch etc when I bought it so it's fine for a while...116,000mi on engine with only basic maintenance and parts replacements so I know it needs help...
factory all over w locking fronts
Other threads suggest 4.3 Chevs...what are my engine options for mating to my trans?
bumpity-bump
noflacko is offline
post #90 of 494 Old 10-02-2007, 10:47 AM
noflacko
noflacko's Avatar
T-4
bumpity bump
noflacko is offline
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
