Official AMC V8 swap thread - Page 4 - JeepForum.com
post #46 of 494 Old 07-30-2007, 01:23 PM Thread Starter
BLS33
Chief of the brain police
BLS33's Avatar
So are you saying you run a 304 with a flexplate balanced for a 360 and don't have any issues?
BLS33 is offline
post #47 of 494 Old 07-30-2007, 01:25 PM
jpfaris
1979 CJ7
yes exactly
79 CJ7, 304, TF727, D300, FULL WIDTH D44's, 4.56:1, SPOOL LOCKERS, SOA, OUTBOARDED, SHACKLES REVERSED, HOMEMADE D-SHAFTS, 38.5" BOGGERS
jpfaris is offline
post #48 of 494 Old 07-30-2007, 04:42 PM
muddmonky
im swaping out my i-6 for a v8 and was wondering what the hp difference is between the 304 and 360 and if that difference is worth it to get a 360.
its going into a 1980 cj7 with stock drive train
muddmonky is offline
post #49 of 494 Old 07-30-2007, 06:24 PM Thread Starter
BLS33
BLS33's Avatar
Stock engines? What years?
BLS33 is offline
post #50 of 494 Old 07-30-2007, 07:36 PM
muddmonky
ya preatymuch stock and i didnt know that the year made a difference
i guess what ever years will slide right in.
post #51 of 494 Old 07-30-2007, 08:08 PM Thread Starter
BLS33
BLS33's Avatar
Any year AMC V8 will bolt right in. The reason years can make a difference is that smog laws can differ from other years meaning some engines may have smog controls and some may not also other things like 4bbl or 2bbl carbs and what not.
http://jeeptech.com has some numbers on both engines.
BLS33 is offline
post #52 of 494 Old 07-31-2007, 06:28 AM
Coptrdoc
1982 CJ7
What about 390 Heads will they work on a later model 360? If I find the dogleg heads will I need special Headers or will they fit over the DL exhaust port? AMC is new to me so forgive me for all the ???? Thanks Stu
Orange 82 CJ-7, Holley, I6, T5, Dana 300, Amc 20, Dana 30,
1.5 Bodylift, AGR Superbox 2, HB Bumpers & Rockers
33" FS Destination MT's
Work In Progress
Coptrdoc is offline
post #53 of 494 Old 07-31-2007, 08:24 AM
muddmonky
i could care less about smog control but i would like a 4bbl if posible
post #54 of 494 Old 08-04-2007, 08:16 AM
havrda
Are all 360's the same
Will a new crate engine from mopar fit right in replacing a 258 in my 1984 cj7?
http://www.mopar.com/m_perf_subcatCh...=1186236886188
havrda is offline
post #55 of 494 Old 08-04-2007, 04:59 PM
plain76cj5
No, all 360's are not the same. Ford, Mopar, and AMC have all made 360 cu in V8's. They are totally different motors. Nothing will interchange between them.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA.
Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000.
plain76cj5 is offline
post #56 of 494 Old 08-04-2007, 08:25 PM
havrda
Ok thanks.
Ok thanks a lot. Any good sources for amc 360's?
havrda is offline
post #57 of 494 Old 08-04-2007, 08:55 PM
plain76cj5
If you want a ready to run crate engine with a warranty, look at Jasper.
If you want a core motor to rebuild or possibly a good running used engine, look at fullsize Jeeps. The AMC 360 was used up until 91 or 92 in fullsize Waggys. You can usually pick up a rebuildable core for little $$.
post #58 of 494 Old 08-12-2007, 03:30 PM
h2oman
oil pressure issues!
Just completed my 360 swap in place of the blown 258. I got everything running on Friday, & aside from a tranny line leak, the only issue I have is with the oil pressure guage spiking all the way to the right when running. I hooked the original oil pressure wire from the 258 to a similar looking module right near the oil filter. My 360 was from a 79 Waggie & in now in a 76 CJ7. Is my wire just grounding out somewhere, or do the 2 diff. models report oil pressure at 2 diff. volts, thusly freaking out my CJ guage? The guage worked great with the 258 until the motor threw a rod, & the 360 while in the wagoneer always showed moderate to slightly low pressure. The guage also doesn't peg when the ignition is tripped, only when the motor is running. Any help is appreciated, thanks!
1957 willys wagon----shhhh, you can hear it rusting....
1969 POWER WAGON-318, 36" tires, 60 rear w/ lock, D40 front, 4 spd manual trans., 4.10 gears
1976 CJ 7, 360, auto w/ quadratrac
1978 cj-5-mated to a 94 wrangler in a strange experimen
1979 cj7, best $5000 jeep that $13,000 can buy
2006 POWER WAGON-'nuff said.'
h2oman is offline
post #59 of 494 Old 08-13-2007, 07:15 AM
plain76cj5
It sounds like you are using the factory CJ oil pressure gauge. I would recommend hooking up an aftermarket mechanical gauge and see what your oil pressure is. The factory gauges are usually way off.
post #60 of 494 Old 08-20-2007, 09:23 AM
fuzz401
1978 CJ7
frame mount AMC I-6 to V-8
I-6 3 slots / V-8 2 slots
CJ - V-8 block mount
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
