Official AMC V8 swap thread - Page 17 - JeepForum.com
post #241 of 494 Old 07-29-2008, 02:52 PM
connor014
Have any of you done this and live in CA? If so any advice to pass smog??
connor014 is offline
post #242 of 494 Old 07-30-2008, 04:05 PM
Tree Chicken
It was skimmed over 2 pages back, but has anyone done this swap into a CJ3B? Currently the F-Head with T-90 and the 18 behind it, but I found a 360 from a 73 and was wondering if this was doable at all.
Tree Chicken is offline
post #243 of 494 Old 08-06-2008, 01:00 AM
aje3721
Once more with the flex plates for a 360 and 999
I read through all the posts and have myself thoroughly confused. Here is my configuration: I have an 84 CJ7 with the 258, TF999 and the 300 Tcase. I have a 74 360 out of a Waggy with the TH400 and Qtrac. I considered using the TH400 but decided on the 999 because it's already there and mated to the 300. Now, do I use the flex plate from the 258 or the 360? Will the torque converter from the original setup work with what I have to do because the one from the TH400 obviously won't work? I'm getting my notes together and making my parts list so I can start this project this fall or winter. Thanks in advance for the assistance with a topic that I'm sure has been covered before!
aje3721 is offline
post #244 of 494 Old 08-06-2008, 06:16 AM
fuzz401
1978 CJ7
the 360 the balance of the motor but will have to be one from a 80 or up that had the 727 tranny and you will also have to pull the thin ring out of the back of the crank or you wont be able to get your 999 converter to fit the crank
should work with the right flex plate
you will need the cj v-8 block mounts and the pass side frame mount amd run the gas line to the driver side for the 360
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #245 of 494 Old 08-06-2008, 12:23 PM
ajeepman
I have the exact set up you are going with and Fuzz is right. My motor was out of an 85 waggy with the 727 so I was ok on the flex plate. I kept my 999 and 300 and it all bolted right up except one of the 4 holes on my torque converter was about 1/16" off center. I used the flex plate from the 360/727 and the converter from the 258/999 so definitely stick your flex plate up against the converter before you mount it to your motor and make sure all 4 bolt holes line up. You can buy the flex plates from your local auto parts store.
02 TJ Silver 4.0 5-speed
4" procomp susp w/ 3" BL
ajeepman is offline
post #246 of 494 Old 08-08-2008, 09:52 AM
83seejay7
1983 CJ7
So what is the correct way to get the 360/999 to bolt up with all 4 bolts? I'll be using the flexplate from the '87 Waggy that is donating the 360.
1983 CJ-7
AMC 360 w/ T999 Auto
33" TrXus MT's under 5" of lift
4.10s w/ a Detroit SofLocker in the back
Herculined Tub
83seejay7 is offline
post #247 of 494 Old 08-08-2008, 11:30 AM
ajeepman
Just to be clear I am talking about the 4 bolts that go through the flex plate and into the torque converter. Not the bolts that go from the 360 block into the transmission bell housing. Try lining your flex plate up with the converter and see if the 4 line up before you install anything. If not you may need to get a flex plate from a 360 that was bolted to a 999 or buy a new one from an auto part store. My flexplate was from a 360/727 set up.
ajeepman is offline
post #248 of 494 Old 08-08-2008, 11:56 AM
83seejay7
1983 CJ7
Of course. I was referring to the bolts between the flex plate and the torque converter
I wasnt' sure if the 360/999 combination had it's own flex plate - didn't know that combination ever came from the factory.
1983 CJ-7
Herculined Tub
post #249 of 494 Old 08-08-2008, 05:01 PM
ajeepman
I wasn't trying to be smart.....just making sure I was being clear is all on which bolts
Below is a link to a post by JeepHammer in your other thread. Looks like they were an option on other models. He would be the one to get this info from and he may even have a spare flexplate to sell you or atleast get you pointed in the right direction.
http://www.jeepforum.com/forum/showp...71&postcount=8
ajeepman is offline
post #250 of 494 Old 08-09-2008, 12:34 PM
83seejay7
1983 CJ7
No, I didn't think you were being smart at all. I just wanted to confirm that you and I were talking about the same thing.
I really appreciate the input. I'm looking forward to getting it all together soon.
Thanks!
1983 CJ-7
Herculined Tub
post #251 of 494 Old 08-16-2008, 10:38 AM
dndracing
location
I am about to do this swap in a 1984 cj7 with a I6 to 360. I had the t-5 tranny. my question is will the transfer case cross member bolt right back in the same spot or does it move forward or back? I see there is several different locations tapped into the underside of my frame for the cross member to bolt to. thanks
dndracing is offline
post #252 of 494 Old 08-18-2008, 09:33 PM
plain76cj5
If you will be using the T5 and the Dana 300 setup, everything should go back in the same location as with the 258. The location of the skid plate and which skid plate you would need (76 to 79, or 80 to 86) would be determined by your tranny and transfercase.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA.
Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000.
plain76cj5 is offline
post #253 of 494 Old 08-19-2008, 06:36 AM
dndracing
I had the t-5 to a dana 300 but swaped that out for a np 435 and a dana 300. but that all bolted back up into the same spot. so im assuming that this will also.
post #254 of 494 Old 08-20-2008, 02:48 PM
Kman1983
1983 CJ5
Are CJ exhaust manifolds and Waggy/Jtruck exhaust manifolds the same? I notice that when I look up a y-pipe for '76-'79 CJ 304 it has a note that says 3 speed only. So I assume it won't work with the T18/Dana 20. Anybody used one of these y-pipes with a T176/Dana 300? My '83 CJ5 has the 258,T176/Dana 300. I also have a T18/Dana 20(and skidplate) out of a '78 or '79 CJ7. I already upgraded to a 3 core radiator. I have 2 360's one came with an auto and Dana 300(2 bbl) and the other came out of a J truck and is mated to a T18/Dana20(4 bbl).
Kman1983 is offline
post #255 of 494 Old 08-26-2008, 09:08 AM
dndracing
will a 2 brl holley projection for a chevy 350 fit a amc 360 very easily?
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
