Official AMC V8 swap thread - Page 13 - JeepForum.com
post #181 of 494 Old 03-13-2008, 09:30 PM
jfrdog
Jeepin' til I die!
jfrdog's Avatar
1980 CJ7
Little stumped
I'm finishing my 258-304 swap and never saw what the throttle cable setup looked like. I need a bracket or something idk... Going outside to finish the new slave cylinder for the clutch now (T4). Anyway I have the cable for the 304 but nothing to hook it to. Does anyone have a pic and/or link to where I could find this very important part? Lol
P.S. I have the motorcraft 2100 carb if that help any
Thanks!!!!!
Still A n00bIe NOT!!!
80' CJ-7 w/ an a AMC 304 V8 with 5.25" SL (4" leafs and 1.25" Shackle lift), 1" BL and 36's Super Swamper TSLs
jfrdog is offline
post #182 of 494 Old 03-13-2008, 09:36 PM
NoNeck
Drop me an email tommorow to remind me. My motor is sitting on the stand with what I believe to be the stock factory bracket and cable.I should be able to snap you some good pics. noneck@comcast.net is my direct email
NoNeck is offline
post #183 of 494 Old 03-13-2008, 10:39 PM
jfrdog
Jeepin' til I die!
jfrdog's Avatar
1980 CJ7
Awesome! Thank you!
jfrdog is offline
post #184 of 494 Old 03-14-2008, 03:32 PM
NoNeck
I have those pics. Email me and I will send them to you....
NoNeck is offline
post #185 of 494 Old 03-14-2008, 06:02 PM
fuzz401
1978 CJ7
http://www.jeepsunlimited.com/forums...d.php?t=885183
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #186 of 494 Old 03-19-2008, 07:35 AM
ajeepman
Hey guys....I'm almost ready to drop my 360 in place of the 258 but was looking at the throttle linkage and think I may have a problem. I rebuilt the engine and went with a non egr edelbrock performer intake and 1405 carb. It doesn't look like the stock throttle cable set up is going to work. The motor is on the stand so I haven't tried yet but just seems I will need an adapter of some sort. Anyone done this carb swap and know of any issues or am I making this into a bigger deal than it is?
ajeepman is offline
post #187 of 494 Old 03-19-2008, 11:53 AM
yooper055
1973 CJ5
Too bad i wasn't payin attention to this site last summer! I dropped a 360 into a 73 cj5 that originally had a 258. I remember needing parts off of most of my "parts" jeeps to accomplish. needed block cj mounts from 304(motor came outta a chief). Also needed a reman flywheel to go from auto tranny to manual. Remember having to use a chevy input shaft(10 spline) to line up the clutch( can't find a AMC dummy spline!!!!). had 3 diff length cj throttle cables to choose from- used the one that fit the best. I also remeber having to make a heck of an adjustment to get the clutch to release. Had a set of fenderwell headers and turbo tubes off a 304 cj that work well except have issues being to close to rear tire. homebrewed my own wiring harness using pieces off the chief's harness. other rhen that it went pretty smooth! This jeep has amazing power and is loads of fun. i would recommend it to anyone!
hey fuzz- haven't i seen your jeep before? JP mag or somethin?
'45 MB
'73 CJ5, 360, 33's, 3" lift
'77 CJ5, 304, 31's, plow rig
'80 FJ40
'93 stock YJ
yooper055 is offline
post #188 of 494 Old 03-19-2008, 04:25 PM
fuzz401
1978 CJ7
yes in JP MAG
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #189 of 494 Old 03-19-2008, 10:31 PM
ajeepman
1. I had a set of fenderwell headers delivered today and found out you need to cut some of your inner fenders to make them fit. Not to happy about that , I think I'm going to go with the hedman street headers instead of the fenderwells. Have an auto tranny , any pros or cons?
2. < I went with performer intake and carb > Looked at the throttle cable set up today and it seems I will need to run a new cable from the pedal to the carb with the correct carb end unless there's an adapter for the edelbrock linkage to acept the stock cable end that snaps over the little ball on the linkage.
3. Does anyone know the fitting size for the fuel pump. I cannot find anything and the parts store has no clue. I want to run a braided line from the mech fuel pump up to a filter. Thanks for all the help guys. Hopefully I can get it done this weekend.
ajeepman is offline
post #190 of 494 Old 03-19-2008, 11:30 PM
NoNeck
What brand headers?
NoNeck is offline
post #191 of 494 Old 03-20-2008, 05:35 AM
fuzz401
1978 CJ7
1 all you cut is the flat spot on the bottom of the inner fender and move your brace up some
2 you can buy the ball for the carb at any speed shop - look at your old carb it may be bolted on some were
3 you want # 6 AN fittings for the fuel line in braded - braded like is not cheap - pump is most likly 1/4 pipe threads
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #192 of 494 Old 03-20-2008, 07:29 AM
ajeepman
Thanks Fuzz!
The headers are hedman. Just not sure if I wanna go fenderwell or full length yet. I'd rather not do any cutting unless the pros are for the fenderwells. I ordered the full length last night from sumit just in case so they'll be here tomorrow. My main reason for not wanting to go with the fenderwell type is I'd like my exhaust to dump out the back and not right below me. I have the 360 to an auto tranny 999 for now until I decide to rebuild the 727 or go to a built 400 and that all mates to the 300 tc. I'm going to compare the best I can before I choose one but if you guys from experience know of any pros or cons to either set up please let me know in the next couple days. Thanks again for spending the time to share all your experience!!!
ajeepman is offline
post #193 of 494 Old 03-21-2008, 07:37 PM
billymadison
I am in the market for a new Edelbrock Performer intake but it lists 2 models. One model is the EGR and the other is the Non-EGR. I was wanting to know whick one to get? How can I tell if I have exhaust gas return or not? Or do I need it? I have went through all 13 pages and searched but came up with nothing. I have not installed the 360 yet (still getting all the parts together) Thanks!
billymadison is offline
post #194 of 494 Old 03-22-2008, 01:32 PM
ajeepman
I'm in Florida and don't have to pass inspections so I went non EGR but from what I understand EGR is needed for states that have inspections. The easiest way to tell if you have egr is you will see a big round saucer looking thing behind the carb on the intake. I can post a pic of the performer intake and 1405 carb installed if you like.
ajeepman is offline
post #195 of 494 Old 03-24-2008, 06:20 PM
spk454
1983 CJ8
NoNeck, here is the exhaust clip, sorry so late, lost my camera. AMC 360 2.25" duals, edelbrock shorty headers, turbo mufflers...
spk454 is offline
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
