Official AMC V8 swap thread - Page 11 - JeepForum.com
post #151 of 494 Old 02-24-2008, 01:45 PM
NHwheelin
1991 XJ Cherokee
stumped
hey I just bought an 83 cj-7 renegade with a 304. The guy I bought it from told me the engine and tranny came out of an 80 cj. My problem is I am trying to figure out what type of tranny it is. It is a 4 speed man. But thats about all I can tell you. Just how I can identify what tranny it is i.e. t4, t177 ect. Thanks for the great thread.
NHwheelin is offline
post #152 of 494 Old 02-24-2008, 06:04 PM
Bard
You are going to have to either get the casting number off the side of the tranny or figure out what shifter you have. Here is a good write up for you to look at to identify it.
http://www.jeeptech.com/trans/
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
Bard is offline
post #153 of 494 Old 02-25-2008, 10:59 AM
NHwheelin
1991 XJ Cherokee
Thanks for the input. That link has alot of other info I needed aswell. Keep the wheels on the ground and the mud in the air
post #154 of 494 Old 02-25-2008, 11:43 AM
clarkmr641
Cj7 Amc swap again, tranny ??
I recently purchased a 84 CJ 7 and have 360 I'm going to swap in. My question is i want to use the th400 tranny and BorgWarnern 1339 t case that came out of my 77 wagoneer in the CJ. Is this setup going to be to long to use in a CJ or has anyone els used this setup? Just wondering if anyone has any good info for me or any problems I may run into, or should I look for a different tranny and t-case setup.
Thanks to anyone who can lend some help.
Mike
clarkmr641 is offline
post #155 of 494 Old 02-28-2008, 08:46 AM
JeepnBlake
I just had a quick question for the guys that have done this is it easier to pull the engine w/tranny and t-case or just engine and trans? hints?
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #156 of 494 Old 02-28-2008, 03:48 PM
Rollbar
1984 CJ8
I pull just the engine & then I pull the trans/t-case. Of course I am using a lift for the trans.
<----Click
<---- Click
Rollbar is offline
post #157 of 494 Old 03-02-2008, 06:01 AM
NoNeck
360 swap. Flywheel Q's...
I've read all 11 pages and my question is danced around, even asked ,but not answered anywhere I see. I have an 84 CJ7 with a 6 cyl with a bad bottom end noise I am looking to replace. I have been on the fence with just a stock 6 replacement or a 360 from a Wagoneer. I was all set to do the 360 swap and then it dawned on me that I will need a flywheel as they were usually autos. I see the 360's are externally balanced. What is involved with aquiring a flywheel for a manual trans? Can I just buy a new flywheel and bolt it on? Or does the whole rotating assembly need to come out and be balanced with the new flywheel? This may make or break the swap so I'd like to know before I get into it. I will need motor and frame mounts, new exhaust etc... as you all know so I don't need any unforseen costs. Any guidance woudl be most appreciated. I am new here but will likely spend a good deal of time here in the near future. I will properly introduce myself when I get a little more time, but thanks!
NoNeck is offline
post #158 of 494 Old 03-02-2008, 11:07 AM
jp360cj
1977 CJ7
You can just buy a new or reman flywheel and bolt it on. One bolt hole is actually offset from the rest of the pattern so it can only bolt up one way. This means it will be properly balanced, but they can be a bit pricey, especially if you don't have a core.
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #159 of 494 Old 03-03-2008, 03:12 AM
NoNeck
Great. Thanks for the info.
NoNeck is offline
post #160 of 494 Old 03-03-2008, 04:13 AM
360wrangler
i beleive I have a set of these if any one is interested
"build it to break it, if it breaks it wasn't built well enuf"
360wrangler is offline
post #161 of 494 Old 03-03-2008, 05:50 AM
fuzz401
1978 CJ7
your flywheel has to be for a 360 - each motor has its own flywheel - you will need the frame mount for the cj like in the pic and you will also need the block mounts for a cj the full size jeep will not work
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #162 of 494 Old 03-03-2008, 09:22 PM
NoNeck
How much for the mounts?
I see the flywheels on Ebay for $115. I am still wrestling with the idea (and cost!)
Suggestions for exhaust? I love loud stuff especially Flowmasters , however I think that may get old quick in a topless Jeep, so I was considering some generic turbo type mufflers and headers. Any guidance on headers? I see 2 types, fenderwell and "regular" I guess you could say. Can someone explain the difference and suggest one or the other? Thanks!!!!
NoNeck is offline
post #163 of 494 Old 03-03-2008, 09:27 PM
ajeepman
I have a 84 cj7 had the 258 now swapping to the 360. My question is what headers can I run with a T999 or T727 tranny? I have both transmissions and not sure which one I'm going to run behind the 360. I want my exhaust to run out the back but would be ok with it turning down at the rear axle. Anyone with pics of headers on a auto tranny cj7 please send them to tonyd1976@aol.com
ajeepman is offline
post #164 of 494 Old 03-04-2008, 06:33 AM
fuzz401
1978 CJ7
these are fenderwell headers
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #165 of 494 Old 03-04-2008, 07:33 AM
NoNeck
Hmmm. Great shot! I can see where they may offer some clearance issues on a regular Jeep. Would you suggest those, or regular headers or just factory cast iron manifolds (where I am leaning towards)
NoNeck is offline
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 07:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 07:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 09:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 06:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 08:59 AM
