Official AMC V8 swap thread - Page 10 - JeepForum.com
post #136 of 494 Old 01-06-2008, 06:54 PM
Bahama Blue
headers
I have an 83 with a 360. Sounds like our Jeeps are the same with the exception of the trannies.. I have a T5.
I ran hedmen headers from quadratec. They run inside the frame to a custom exhaust and out the back. It is very neat and the headers bolted up nicely.
This may sound silly but are you absolutely sure that your frame side engine mounts are on the correct sides? One is alot larger than the other and if they are switched around then the headers will not fit.
I know this because I did it and had this problem. I am using mounts from another CJ though that had a 304 in it. 304 engine and frame side mounts work on a 360 too.
The larger frame side mount has to be installed on the passenger side.
I can't say for certain but it does sound like your engine mounts may be the problem. If you like I will take a picture of my engine with the headers and mounts and email it to you.
Jamie
Originally Posted by speeddemon651
I have a Offical Header Fitment question !
I've got a 83 CJ7 was a 6 and just finished bolting in the AMC 360. I'm running the 176 trans / dana 300 with midified drive shafts to the correct length. I'm using the M.O.R.E. bomb proof engine mounts. With that said, I just bought a awesome pair of stearling coated Headman long tube Headers(part #99208 I believe) , When I first mocked them up they looked fine , but now I can see with them firmly bolted down, Its a total no go. They rest on the rear leaf spring mount on the passanger side and on the driver side I'm hitting my slave cylinder and will not come anywhere near bolting up. I called M.O.R.E and asked what headers they would go with and they said "not sure, and to try the forums". So guys I've heard hooker, Dynomax, and certain Headman headers will work. Does anyone know exactly what headers ill fit my application ? I really don't want to run Fender Well Headers. My plan was to keep the exhaust nice and tight inside the Fame rail's with small mufflers and turn-downs before the rear Diff. I'm also looking for the most performance I could get out of these headers. My 360 has a mild cam, nice intake and 4barrel. Thanks for your time
Bahama Blue is offline
post #137 of 494 Old 01-07-2008, 11:56 AM
speeddemon651
I retract the Previous part number I gave for the headers, they are (99200)'s Headan CJ5, CJ6, Cj7, 72-86 AMC V8 290-401. I'm positive my engine mounts are correct, In the first five minutes of putting them in I bolted them up on the wrong side and realized something wasn't right here. I already pulled the headers back out too, otherwise I would post pictures of them in the jeep. I really wanted to go long tube headers, but I guess shorty will have to do. Does anyone run hooker headers ?
speeddemon651 is offline
post #138 of 494 Old 01-08-2008, 08:09 AM
speeddemon651
Does anyone have any pictures if the Starter solenoid / alternator wiring. It looks like the V8 starter I just got is a one wire starter? I'm currently trying to sort the wiring out from my 6 banger to amc 360 swap. I also just put in the Hei Distributor , anyone know which wire I want to use for the power wire for it?
I also checked again last night and for my engine mounts I do currently have the larger/ taller mount on the passenger side and the shorter mount on the driver side.
post #139 of 494 Old 01-08-2008, 08:14 AM
fuzz401
1978 CJ7
starter should be the same for a 6 as a 8
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #140 of 494 Old 01-08-2008, 08:30 AM
speeddemon651
Thanks that is a start, I would have had a very straight forward job with this but when I got the jeep the 6 banger was no where to be found and the 360 was in the back seat. thanks
post #141 of 494 Old 01-09-2008, 07:57 AM
speeddemon651
Ok I can get my headers to barely fit, If I switch the holes I had the slave cylinder mounted in. The first picture you can see how close my header is to the passanger side rear spring mount.
#1
I guess I have the wrong clutch Fork, my current one is too low, does anyone know which model Year and model FORK I need ? I believe the trans is a 176 ? The picture below is the current fork I have in and a picture of it in the truck. Do I have to pull my trans to get the fork out to swap it ?
#2 I have several wires and plugs that I'm not exactly sure what to send them to. On the solenoid LEFT side I have the battery and Alt Cables, the left top Post I was told it was the Ign. feed wires. Right side top Post Ign Mod. feed, and right lower Post starter Cable. I'm currently running a HEI and just need a power red/w stripe to power it, where should I pull it from ?
These are the current wires I have hanging
purple Long
Purple -has been cut to behind the carb
Brown
Black
Orange
Yellow
Blue
3 red wires
Red/white stripe large diameter
Red/white stripe small diameter
Please Help
post #142 of 494 Old 01-09-2008, 08:46 AM
berliner
1976 6 cyliner w/ T5 to V8 swap
T5 transmission with the 6 cylinder, will the 304 or 360 bolt up to the same housing? Need some light on this issue.
berliner is offline
post #143 of 494 Old 01-09-2008, 11:16 AM
jp360cj
1977 CJ7
If it's a 232 or 258 it will have the same bolt pattern as the AMC v8's
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, CJ T18/D20, Chevy D44/EB 9" rear, Trutrac f/r, 4.11, SOA, 1.25 lift shackles, 35x12.50 BFG KM2s, Shackle Reversal
jp360cj is offline
post #144 of 494 Old 01-24-2008, 09:55 AM
Hybrid Jeep
1976 CJ5
Hey guys-
I found an AMC 360 from a 1988 Jeep Grand Wagoneer. Will it fit in my 1976 Jeep CJ5?
Just want to make sure before I buy the engine!
Thanks guys.
Hybrid Jeep is offline
post #145 of 494 Old 01-24-2008, 09:57 AM
fuzz401
1978 CJ7
any amc 360 / 390 / 304 / 401 will fit with the right motor mounts
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #146 of 494 Old 01-24-2008, 10:07 AM
Hybrid Jeep
1976 CJ5
Thanks for the quick reply.. will it bolt up to my T18?
post #147 of 494 Old 01-24-2008, 04:23 PM
fuzz401
1978 CJ7
amc has the same bellhousing bolt pattern on the 360 / 390 / 304 / 401 / 258 / 232
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
fuzz401 is offline
post #148 of 494 Old 01-28-2008, 08:12 PM
limegreenCJ7
Hey I'm new to this Forum And This Question Has Probably Been asked lots but will an amc 304 or 360 bolt up to my Borg Warner T5 transmission, and since I think the answer is yes, what kind of modifacations would I have to do to transmision?
limegreenCJ7 is offline
post #149 of 494 Old 01-28-2008, 08:20 PM
limegreenCJ7
ok nevermind... I just got the answer from reading the page
post #150 of 494 Old 01-30-2008, 03:43 PM
jonazbell
79 cj5. is there any modification need when using a 2.5" lift with 3/4 shackle lift. i am thinking of the front end being tilted forward or anything to that effect with this application. a shackle reverse is being used in front as well.
jonazbell is offline
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
