Official 4.0 swap thread - Page 7 - JeepForum.com
post #91 of 429 Old 05-17-2008, 09:04 AM
CJHVN
If I were you, I would not recommend the stroker.
The 4.0L is fine the way it is and a huge improvement over the carbed 258. The 4.0L is also a fairly easy swap and is pretty simple in stock form. As I understand it, there are a lot of modifications and trial and error to get the stroker to run well.
I rebuilt my 94 YJ engine, swapped it in, and I'm happy with it. I now have a strong running fuel injected engine. I'm happy.
Again, just my opinion.
Now, if I could just get my distributor indexed correctly......it's not easy to do this alone...
85 CJ-7, 4.0L, twin stick/clocked flat Dana 300, SOA, 36" TSL's, 30/44 locked, Warn X8000i
92 XJ, 4.0L, AW4, Dropped NP231, 30/8.25, 4" DPG Hybrid lift, 33" MT/R's, JKS trackbar, JKS discos, OME Nitro Shocks, stinger bumper, Warn X8000i, etc. (work in progress)
CJHVN is offline
post #92 of 429 Old 05-17-2008, 10:47 AM
BioTex
1979 CJ7
What is indexing a distributor? Is this a result from the swap, or just a nice thing to do?
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #93 of 429 Old 05-17-2008, 03:42 PM
CJHVN
I removed the distributor from the engine when I rebuilt it. It is very tricky getting installed "exactly" right. If it's a tooth off or 172 degrees off, it will run like CRAAAAP and you will pull all of your hair out trying to figure out what's wrong!
So, to answer your question....yes. It's a result of the swap. Unless you never remove the distributor and don't rotate the engine at all.
CJHVN is offline
post #94 of 429 Old 05-17-2008, 09:24 PM Thread Starter
supraman1990
supraman1990's Avatar
1980 CJ5
I didn't pull my dizzy. Honestly, I'm going to stroke mine, they make kits that you can drop right in.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #95 of 429 Old 05-17-2008, 10:29 PM
DirtEater
1982 CJ7
I have a local shop that wants $4500 otd to do a 4.0 swap in my CJ. The engine will have around 100K on it. Is this a fair price to pay for a swap out the door? Keep in mind this is SoCal, and it all has to be smog legal.
On the other hand, I can get my engine rebuilt locally for about $2100 installed. Howell kit for another $1200, plus around $500-600 to have it professionally installed(cuz I'm sure to screw something up). This would all be a total of about $3900. Not sure about doing the 4.0 head with this because I'm concerned about passing visual and sniffer smog.
So, like many others here considering their options, I haven't made up my mind which route to take.....
Terry ~ USN Ret. 30Sep07 : )
1982 CJ7 4.2L ~ T-999 ~ Dana 300 ~ SOA Conversion
Dana 30/AMC 20 with Truetrac - one piece axle - 4.10's
33" Toyo M/T's on Pro Comp Xtreme Series 1069
Borla header and Catback Exhaust System
Jeeperman bumper w/ Ramsey Patriot 8000 - Jeeperman tire carrier/bumper
DirtEater is offline
post #96 of 429 Old 05-18-2008, 08:08 AM Thread Starter
supraman1990
1980 CJ5
The 4.0 will actually do quite a bit better on smog than the 4.2, with the newer design and MPI. As far as doing the head, unless you know what your looking for, the heads look nearly the same. You would have to pull the intake and look at the ports to tell any difference. I think $4,500 is a little steep myself. I did my entire swap for less than $750, and the only part that I don't think would be smog legal is the fact that I don't have a cat. The 4.0 honestly doesn't have that much emissions equipment. I know it doesn't have EGR, and I am reasonably sure it doesn't have emissions either, so the cat is all their really is. My advice to you about all the smog would be to hop on to www.cjoffroad.com and find a member who has completed the swap in the Nazi republic of California and check with them about any smog issues.
96% complete.
post #97 of 429 Old 05-28-2008, 05:51 PM
BioTex
1979 CJ7
help thinning harness
I have the complete harness from my donor cherokee laid out. Where do I begin? Anyone have pictures of how to thin the harness? Seems I saw a writeup once, but can't find it again. I have most everything labeled. Please help...
Currently:
BioTex is offline
post #98 of 429 Old 05-28-2008, 08:24 PM Thread Starter
supraman1990
1980 CJ5
Honestly, get your FSM for your year, and start cutting. You need to study the FSM and make sure you know what your cutting before you do. I had to put a wire or two back in when I screwed up my self.
96% complete.
post #99 of 429 Old 05-30-2008, 09:07 AM
BioTex
1979 CJ7
need wiring diagram for 91 XJ
Before I shell out $55 for the whole FSM for my donor 91 Cherokee, does anyone have the wiring diagram portion you can send me so I can thin my harness?
Since I have the whole car, maybe I can trade you something you need from it before I send it away.
Not sure how many pages, or how big it is, but I need good enough resolution so I can read the wire colors.
Currently:
BioTex is offline
post #100 of 429 Old 05-30-2008, 09:29 AM
CopperCJ7
Isn't it true that with a stroker motor, you must run super unleaded gas? And with a stroker motor, you have to run heavier duty things, like the water pump, the coil, the plug wires, motor mounts, etc.
Guns don't kill people... Bad trail spotters do.
What CJ owner doesn't want to hack up his harness for the next owner to have fun with?
Originally Posted by Broseph View Post
The thread will derail quicker than a walrus on a Crisco-soaked Slip 'n' Slide.
CopperCJ7 is offline
post #101 of 429 Old 05-30-2008, 09:41 AM Thread Starter
supraman1990
1980 CJ5
Depends what compression you run on the gas isue. If you run lower than about 9.5:1 you don't have to run premium. As far as the other heavier duty stuff, not really. You can run all factory if you want. However, if you are shelling out the cash to do a stroker, you can shell out the $100 for a bkool pump. Now, something I would upgrade is the injectors and the regulator, as without more gas the more air you are getting is useless.
96% complete.
post #102 of 429 Old 05-30-2008, 09:42 AM Thread Starter
supraman1990
1980 CJ5
Honestly, I used more than just the wiring section. Plus, it helps to have the whole book when it says a wire name that you are border line on, you can turn to the section it is referenced to and figure out exactly what it is.
96% complete.
post #103 of 429 Old 05-30-2008, 02:59 PM
BioTex
1979 CJ7
Bought one
OK, I gave up and purchased one from E-bay. The guy cut me a better deal, so Problem solved.
Currently:
BioTex is offline
post #104 of 429 Old 05-30-2008, 03:04 PM
BioTex
1979 CJ7
Higher compression problems?
Some of the research Ive been doing tells me that with the 4.0 head swap, I will have around 10:1 compression. Is this true?
If so, I'm worried about my bottom end. I decided not to rebuild the 258 block, since it has only 98,000mi., and doesn't use oil. It still runs strong, but might be getting borderline for a 10:1 compression. Would a thicker head gasket help, if so, how much? I really don't wan't high compression. What are the options?
Currently:
BioTex is offline
post #105 of 429 Old 05-31-2008, 11:14 AM Thread Starter
supraman1990
1980 CJ5
I'm sure a thicker gasket would lower it, slightly. As far as the compression ratio, I am not real sure. Since I did the entire swap I'm not real knowledgeable about the head swap. I'm sure someone that has done it will chime in.
96% complete.
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-30-2016 11:57 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
