Official 4.0 swap thread - Page 5 - JeepForum.com
post #61 of 429 Old 04-22-2008, 03:20 PM
bulljeeper
bulljeeper's Avatar
http://www.4x4wire.com/jeep/tech/engine/fi40swap01/
you might find a couple answers to your questions about the swap here
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
lOd Rear Tire Carrier
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
Spyder Customs Crusher Corners
bulljeeper is offline
post #62 of 429 Old 04-22-2008, 09:46 PM
bulljeeper
bulljeeper's Avatar
so i am getting ready to start the project. i am going to the Pull-A-Part junk yard withink a week or so and was wanting that my list of parts was what i needed. i know the 4.0 block, head, intake, (and everything that mounts on the front ::fan alty P/S A/c) ALL the wiring and computer(s) connected to the fuel injection. i wanted to make sure that there wasnt anything else form the junk yard that i need.....
By the way, at a pull-a-part junk yard a complete 6 cyl motor is $160 without a cre. so i want to make sure that i get everything i need while i am there the first time to save any money that i can....
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
post #63 of 429 Old 04-23-2008, 06:21 AM Thread Starter
supraman1990
supraman1990's Avatar
1980 CJ5
The 5spd in the Cherokee will work as long as it is a 4wd AX15 and not a 2WD, as they aren't a transmission that you can convert back and fourth. Everything should be in the Cherokee, yes.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #64 of 429 Old 04-23-2008, 06:22 AM Thread Starter
supraman1990
1980 CJ5
I almost did the pull a part thing, and actually did get my harness there. Only thing I don't like is you have no idea about internal condition of a motor you pull there.
96% complete.
post #65 of 429 Old 04-23-2008, 08:09 AM
bulljeeper
bulljeeper's Avatar
yeah, i plan on doing a rebuild, otherwise i would be more cautious about it.
is there any years that i should not get, or just anything from 91-08?
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
post #66 of 429 Old 04-23-2008, 10:48 AM Thread Starter
supraman1990
1980 CJ5
My preference is a 91-98 motor, as that is the better flowing head with less restrictions. 99+ has the better intake, and if you see any of the later intakes snag them, they go for a premium on Ebay and can be adapted to the earlier head. 2000+ motors are the bad head casting that is prone to cracking.
96% complete.
post #67 of 429 Old 04-23-2008, 03:40 PM
bulljeeper
bulljeeper's Avatar
sorry to completely bust you for knowledge but i was wondering if you had more information about the CPS and the VSS.
where on the bellhousing does the CPS mount. is that something that i could do myself? in order to get novak to do the work on it would i have to ship it to them.
and where does the VSS mount to, and how much are they?
also how much can a CPS be gotten for?
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
post #68 of 429 Old 04-24-2008, 01:00 AM
bulljeeper
bulljeeper's Avatar
i have also done a nutter bypass if that will matter.
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
post #69 of 429 Old 04-25-2008, 06:22 AM Thread Starter
supraman1990
1980 CJ5
I wouldn't do the CPS yourself, either get the Hesco dampener or send it to Novak, just a little space is a lot of timing on those things. The VSS mounts where your speedo cable goes now. You can get the ones from Hesco to run your speedo and function as the VSS for like $160, or they came in 91 Wranglers.
96% complete.
post #70 of 429 Old 04-28-2008, 09:54 PM
bulljeeper
bulljeeper's Avatar
which one would have more power?
258 and
fuel injection
or
242 and
fuel injection?
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
post #71 of 429 Old 04-28-2008, 10:45 PM
coas
258 and
fuel injection
or
242 and
fuel injection?
The 259+4.0L head will be better at low-mid RPM and the 4.0L at high RPM. Both with stock camshaft.
84 CJ7 , Dana 44 rear D30 front, 258, 4.0 head, MPFI, e-fans, T176, Dana 300, 31x10.5x15 and Mustang hydroboost.
My esnips folders:
coas is offline
post #72 of 429 Old 04-28-2008, 10:55 PM
bulljeeper
bulljeeper's Avatar
do you know if i could still use my HEI dissy if i brought in the MPI? (using the 258 block)
if not is there any sort of way to adapt the hei to work with the MPI
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
post #73 of 429 Old 04-29-2008, 12:26 AM
coas
No, unless you use the megasquirt ECM, but that's another story.
Anyway, why would one want to use this distributor at the first place??
My esnips folders:
coas is offline
post #74 of 429 Old 04-29-2008, 12:43 AM
bulljeeper
bulljeeper's Avatar
cause its new.
i think i am leaning more towards using the 4.2 block.
i like the low end and i know that any real power problems will be solved by the fuel injection. i also have the 4.0 head that has been modified to work on the 258. so that would save more time and money right there.
my planned setup will be:
Fresh 258 block, stock (maybe a small cam)
Recent 4.0 Head and Headers
The Wiring System from 4.0 (including Computers and Ignition)
The hesco CPS kit
Intake
Various Sensors and stuff
the E2000 pump and accesories.
A/C for OBA
is there anything offhand you can think of that will make the not work...
If i put in a cam with some lift, will that throw off the fuel injection? or will it accomidate for it?
also would i have to swap to a 4.0 flywheel and bellcrank?
258 Inline 6
HEI Distributor
4.0 Head Swap
MC 2150
Soon to be:
4.0 Motor
All New Wiring
Gauges
OBA
post #75 of 429 Old 04-29-2008, 01:05 AM
coas
With that setup it's better using a larger injectors or adjustable fuel pressure regulator.
If you use the CPS relocation kit then you don't need the 4.0L flywheel unless you swapping the AX15 too.
Using an aftermarket cam might cause a bit of trouble installing the distributor but nothing serious..
Do not use ECM or harness from Grand Cherokee unless you have to, try looking for manual setup, it will be easier.
Start looking for a VSS..
Click on the JEEP link in my sig. for F.S.M'S.
My esnips folders:
coas is offline
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-31-2016 12:57 AM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 07:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 09:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 06:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 08:59 AM
