Official 4.0 swap thread - Page 25 - JeepForum.com
post #361 of 429 Old 08-15-2013, 11:17 AM
Gigemags05
1980 CJ7
I spoke with the people at hesco and they suggested it might be the IAC valve so I changed it with no luck.
I reset the computer and its throwing
12
33
35
36
55
The only one that could really effect me is 35, which is:
35 Cooling fan relay circuit open or shorted
35 idle switch motor fault - check connections
But I've checked all connections and they seem fine.
Should it be throwing codes 33 and 36 even though I have no ac or turbo?
The gentleman at hesco says he thinks I might have a bad pcm because its throwing codes that don't apply to my jeep. He said if I have a functioning speed sensor that my computer should learn. I assume my speed sensor is functioning. It's brand new. If it wasn't functioning would the speedometer still work?
Have any of you had issues with the original 4.0 pcm not working properly after the swap?
I just don't want to drop $400 on the hesco pcm if its not necessary.
Gigemags05 is offline
post #362 of 429 Old 08-15-2013, 11:38 AM
NelsonATC
1980 CJ7
35 is a cooling relay switch, which I don't have connected in mine either, as I have my own electric fan control wired up. This will show up when I pull codes on mine. This makes me think you're using some form of XJ harness/PCM, because the wranglers never had Electric fans.
33 shows up on mine as well, and I don't have ac. This shows up on most YJ and XJ's iI have pulled codes from, and many of them don't have air conditioning.
I've never seen 36 come up before, but I don't think that it's a problem. I classify that along with the air conditioning code that came up.
Even if you are not throwing a check engine light, there are still codes in the system if you check them. My jeep as it stands right now, is running fine, even though the above codes would show up if I decided to pull them.
How long is your jeep running before it dies? Is it running for a few seconds? A few minutes? Half an hour? At full operating temperature? When it's cold?
I'm typing this on my phone right now, so I can't look back through the thread to see if you've already answered it. If you have, I apologize for asking again.
Mike
1980 CJ7
NelsonATC is offline
post #363 of 429 Old 08-15-2013, 11:54 AM
Gigemags05
1980 CJ7
Yes, my pcm is from a cherokee.
It'll run fine for a while then die. Sometimes before operating temp and sometimes after. It'll start right up again and might run for awhile or it might die again quickly.
post #364 of 429 Old 08-15-2013, 12:10 PM
NelsonATC
1980 CJ7
Okay, that helps a little:
I had a similar problem about two months after my swap. I ended up tracing it back to the coolant temperature sensor. Once I replaced that, the problem went away. It's a cheap part, so it maybe worth a try.
If you do go the PCM route, there is no need to spend $400 to get the Hesco unit. I would find someone that sells used Jeep parts in your area, and see if they have one. I got mine for something like $40. For what it's worth, all of the "new" units out there are really rebuilt factory units, or so I am told.
Mike
1980 CJ7
post #365 of 429 Old 08-15-2013, 01:02 PM
Gigemags05
1980 CJ7
You mean the sensor that the gauge plugs into on the back of the head?
Or the sensor in the thermostat housing?
I'll definitely give that a shot.
Can anyone direct me to a link or any info on checking the pickup tube/ fuel sock in the tank? Is it possible that its partly clogged?
post #366 of 429 Old 08-15-2013, 04:12 PM
NelsonATC
1980 CJ7
Thermostat housing.
Mike
1980 CJ7
post #367 of 429 Old 08-17-2013, 04:32 PM
Gigemags05
1980 CJ7
I replaced the coolant temp sensor with no luck.
I put a fuel pressure tester on it and its holding around 35-40 at all times, even when it's dying.
Is there any chance I have the cps gap too wide or too narrow?
I'm out of ideas on this thing.
post #368 of 429 Old 08-17-2013, 04:41 PM
Skerr
We just broke into the 4.0 world so I don't know much! If it is pointing to the CPS, could it be loose? We gapped ours with cardboard from a cereal box.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #369 of 429 Old 08-17-2013, 04:48 PM
Gigemags05
1980 CJ7
It's on nice and tight. It starts up and runs fine so I'm doubting its the gap, just grasping for straws.
post #370 of 429 Old 08-17-2013, 04:56 PM
Skerr
And I am throwing them at you!! Good luck.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #371 of 429 Old 09-15-2013, 09:20 PM
sfeather11
1982 CJ8
EGR or not?
Hi all, started this swap project about 6 years ago, then kids came along. Well, finally getting back into it and had a question. I've got my '95 head sitting on my '82 block. I re-used my 258 intake and am using the exhaust manifold from the 4.0. I am undecided on whether to use the Howell TBI kit or an MC2100 carb. Has anyone else with this intake/exhaust manifold setup hooked up their EGR? If so, what tube did you use? I cannot use my original since the 4.0 head is a little taller. Do I actually even need EGR? What would be the effects if I just plugged the holes?
Peace!
sfeather11 is offline
post #372 of 429 Old 09-16-2013, 08:12 PM
sfeather11
1982 CJ8
Hi all, disregard the above post. After searching a bit I found an awesome thread about EGRs. After reading, I decided I will not be hooking it up, so the question is moot!
Peace!
post #373 of 429 Old 12-24-2013, 09:33 AM
captkhaos
1980 CJ7
Hello,
I've read every (well almost every) post of the 398 of them on this thread but have not found the answer I am looking for. Yes, I did a search. I have a 1980 CJ7 with a 258 and have a 4.0 head ready to go. The only thing stopping me is the exhaust header. I have had 3 engines in this Jeep during the 30 years I've owned it and had headers on all of them. Besides the cam, the header seems to make the most difference. I have found very little reference here about headers (or cams) but I don't want to start the swap until I have the right one... especially if I'm gonna pay $500 + for a Borla etc. Can anyone PLEASE give me some advice on a known working header for a 4.0 in a CJ7?
BTW, My 258 (4.2) runs great with a Crane RV cam, Crane ignition and a cheap Hooker header. The Carter BBD is a POS and the 258 really came alive with a Holley 350 cfm 2 bbl. Very easy install. The 4.0 head requires 390 cfm though so I went with a Weber 38/38. I'll consider TBI after I get it running with the new head. Trick Flow makes the 7/16" bushings for the head bolts. Expensive though. I'll look into the copper pipe idea. Thanks for all the help. Merry Christmas!! Dan
captkhaos is offline
post #374 of 429 Old 12-24-2013, 09:41 AM
billybooster2
1983 CJ8
Originally Posted by captkhaos View Post
Hello,
I went with this one from kospeed on ebay. Runs great, not Borla but less $$$ too! Have you upgraded the injectors to the '703' 4 hole pintle (Dodge Neon)?
http://www.ebay.com/itm/91-99-JEEP-G...item27c7e46838
billybooster2 is offline
post #375 of 429 Old 12-24-2013, 09:43 AM
Kman1983
1983 CJ5
I'm still running the stock 4.0 header on my CJ5. Welded the crack up years ago and it has been fine.
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl
"Good Girls and Dirty Jeeps" a song by Opal Justice
Kman1983 is offline
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-31-2016 12:57 AM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 07:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 09:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 06:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 08:59 AM
