Official 4.0 swap thread - Page 23 - JeepForum.com
post #331 of 429 Old 07-14-2013, 07:59 PM
NelsonATC
1980 CJ7
What are you running for a fuel pump?
Mike
1980 CJ7
NelsonATC is offline
post #332 of 429 Old 07-14-2013, 08:03 PM
Skerr
E2000... you familiar with that one?
Kerrdog
Go Fish! <*////><
Skerr is online now
post #333 of 429 Old 07-14-2013, 08:07 PM
NelsonATC
1980 CJ7
That's what i'm running. Works fine and holds good pressure
Mike
1980 CJ7
post #334 of 429 Old 07-14-2013, 08:11 PM
Skerr
I was impressed how quickly it picked a prime. I think I'm getting more than 35# of pressure at the fuel rail. I don't remember what the desirable pressure is off the top of my head...
Kerrdog
Go Fish! <*////><
Skerr is online now
post #335 of 429 Old 07-14-2013, 08:14 PM
NelsonATC
1980 CJ7
I think I am running 39 right now. That said, I am running a 4.6 stroker w/ a ported head and 24lb injectors. I've been experimenting with various pressures and have been as high as 45psi without any pump issue. I THINK stock OBD1 is around 39psi
Mike
1980 CJ7
post #336 of 429 Old 07-14-2013, 08:22 PM
Skerr
Something like that. I know when I purged the relief valve it shot across the engine bay! That was AFTER I discovered I had connected the pressure to the return and vice-versa!!! Couldn't understand why I wasn't getting fuel! Thought my fuel rail was bad!
Kerrdog
Go Fish! <*////><
Skerr is online now
post #337 of 429 Old 08-02-2013, 01:38 PM
Gigemags05
1980 CJ7
I completed this swap using the hesco cps relocation kit. Now, I think my cps is going out. Does anyone know if I can use an after market cps from the parts store or do I have to replace it with a hesco cps?
Gigemags05 is offline
post #338 of 429 Old 08-02-2013, 03:01 PM
SLO_Ken
Does your sensor look like this?
Or like this?
Both are for a '97 - '02 Wrangler. Available from RockAuto.com, or your favorite local parts store...
SLO_Ken is offline
post #339 of 429 Old 08-02-2013, 03:13 PM
Gigemags05
1980 CJ7
My sensor looks like this:
The sensor itself looks like the OEM one, but the mounting bracket portion is different. I think it might still work, though.
I was more concerned with wether or not they perform the same. Do they have the same voltage, etc.
post #340 of 429 Old 08-02-2013, 03:24 PM
SLO_Ken
That looks an awful lot like the second picture in my post above... except the connector may be different.
here's another image from a different angle
If you can handle cutting and splicing the old connector onto a new sensor (if needed), I'd say go with an aftermarket sensor. They will perform the same.
SLO_Ken is offline
post #341 of 429 Old 08-02-2013, 03:31 PM
SLO_Ken
or, even better, get one from a '94... The connector looks like a match
SLO_Ken is offline
post #342 of 429 Old 08-02-2013, 03:41 PM
Gigemags05
1980 CJ7
Perfect. Thank you for the info Ken!
post #343 of 429 Old 08-02-2013, 10:42 PM
billybooster2
1983 CJ8
The hesco has an oval mounting hole. Su358 is the wells part number. The circle doesnt fit/ reach i dont think
billybooster2 is offline
post #344 of 429 Old 08-03-2013, 10:20 AM
SLO_Ken
yeah, that's the one!!
Another comment. I've read on the XJ and TJ forums that sometimes the aftermarket CPS sensors don't want to work properly. When they replace them with an OEM sensor from the dealer, the work perfectly.
SLO_Ken is offline
post #345 of 429 Old 08-03-2013, 06:33 PM
billybooster2
1983 CJ8
The wells is a good part. But ive heard same about cheapy stuff...i test my spare then put it in my trail kit.
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-30-2016 11:57 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
