Official 4.0 swap thread - Page 21 - JeepForum.com
post #301 of 429 Old 05-08-2013, 07:37 PM
billybooster2
1983 CJ8
Pm me. I have a css and adapter for u. Pm me for price.
billybooster2 is offline
post #302 of 429 Old 05-15-2013, 09:55 AM
CJHVN
Anyone have any good tips on thinning the wiring harness? There are a lot of wires not being used. I'd like to clean them up. I have a FSM, but I'm an electrical wiring retard. Feel free to talk to me like I'm an idiot.
Also, I'm still having some running issues. I'm either going to figure it out or swap in a 350 and be done with it. But, I'd prefer to keep the 4.0L. I'm sure it's a distributor thing. It just sputters and pops under throttle. Timing light says everything is fine. But the throttle response says otherwise.
HELP!
85 CJ-7, 4.0L, twin stick/clocked flat Dana 300, SOA, 36" TSL's, 30/44 locked, Warn X8000i
92 XJ, 4.0L, AW4, Dropped NP231, 30/8.25, 4" DPG Hybrid lift, 33" MT/R's, JKS trackbar, JKS discos, OME Nitro Shocks, stinger bumper, Warn X8000i, etc. (work in progress)
CJHVN is offline
post #303 of 429 Old 05-15-2013, 10:12 AM
NelsonATC
1980 CJ7
I did this about six months ago. What I did, is got a couple of wiring diagrams, marked them out, to determine which wires need to go in which ones need to stay. Wires that go to sensors that are needed in the swap Obviously need to stay, along with grounds. Everything else can be traced back to the Computer, and cut. I left enough wire at the harness to reconnect any wires that I may have screwed up on.
Just take your time, and leave enough wire harness ends to patch them back in if you screwup. Good luck!
Mike
1980 CJ7
NelsonATC is offline
post #304 of 429 Old 05-15-2013, 10:33 AM
CJHVN
Thanks. I think that's my plan. It's always nerve racking when you start cutting wires.
The damn thing is running right now. Not well, but running. I don't want to screw anything up.
If I can figure out the wiring harness thinning and the timing issue, I'm going to be a very happy camper!
CJHVN is offline
post #305 of 429 Old 05-15-2013, 10:39 AM
SLO_Ken
Originally Posted by Skerr View Post
Anybody have a diagram of the '97 XJ fuse/junction box... specifically the pin outs?
http://colorado4wheel.com/manuals/Jeep/XJ/
The FSM for the 99XJ should apply to your 97 OBDII. Section 8W is all wiring diagrams and pinouts.
SLO_Ken is offline
post #306 of 429 Old 05-15-2013, 08:50 PM
Kman1983
1983 CJ5
You can buy brand new 4.0 flywheels from NAPA fairly cheap. You will also need flywheel to crank bolts as the flexplate bolts will be to short.
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl
"Good Girls and Dirty Jeeps" a song by Opal Justice
Kman1983 is offline
post #307 of 429 Old 05-16-2013, 04:31 PM
Skerr
YOU. ARE. THE. BOMB! Thank you so much...
Thanks, Kman. I picked up a new flywheel from AZ for $65! Blew me away!! Used ones on Ebay for $65 and up... go figure. I have the new flywheel and clutch set... now let's see if it will all bolt up to a T18. And thanks for the bolt reminder. Gotta do that tomorrow.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #308 of 429 Old 05-18-2013, 03:58 PM
4milechuck
1983 CJ8
Motor Mount Issue
Not ready for the FI part of my swap & hope that will come someday. 88 4.0 into my CJ-8 just this week (T-5/D300). Was told 258 motor mounts & frame brackets would bolt up to 4.0 block & my CJ frame. Had a 2.5 GM engine before & was told those mounts would not work nor the frame bracket. The 258 engine brackets & motor mounts fit fine, but after all are put together the frame bracket is about 3/4" too far to the rear of the rear of the vehicle to line up with 4 of the available frame holes. Same situation on both sides. As I live in an area where Jeep help is remote, I have totally relied on all you guys here at JF. Any help you can give is much appreciated.
4milechuck is offline
post #309 of 429 Old 05-18-2013, 06:39 PM
Skerr
Chuck, I haven't crossed that bridge yet, but I remember reading about an extra hole in the side of the block that you must utilize for the engine bracket. It moves the engine bracket forward a little. IIRC, it is a metric thread, and it is the only hole that has a metric thread. I hope this helps you, and I'm looking forward to your results.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #310 of 429 Old 06-22-2013, 06:38 AM
Skerr
We have the engine in the Jeep. It is bolted up to the T18. I had to get a new pilot bushing from Novak. Plugging Novak for their great service to me on the phone. I had issues with the metric bolt on the motor mount, but only because I live in a land where metric is not king, and it was hard to find the M12 bolt!
The engine harness is OBDI. This is a '97, and we converted everything to OBDI to make it easier to install. I am still at a loss on the "5 to fire"! I am clear on the principal. I have the FSM for a '94XJ. Am I to understand that I need only 5 wires from out of the entire bulkhead connector, and every single other wire in the bulkhead connector can be removed from the harness? No sensors go to the BH connector (I don't recall any sensors going there)? Take those lone 5 wires and plug them into the corresponding cavities in the CJ Bulkhead Connector, and that's pretty much it????? Rock-N-Roll time.
I need that assuring hand on my shoulder, saying, "Yes, Scott, you are going in the right direction!"
Thank you!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #311 of 429 Old 06-22-2013, 12:43 PM
Skerr
To continue beating this decomposing horse, my question relates to the pin out of the XJ bulkhead connector.
The first two pics are the same, one just bigger than the other. I have labeled the 2nd pic with the corresponding pinout scheme, as I understand it. The vertical lineup is plain (columns), but what about the horizontal line up (rows), as there are obviously pins that fall between rows? How do you, for sure, identify which pin belongs where? This is a very dirty bulkhead connector from a '94 XJ OBDI harness.
The third pic is the bulkhead connector on the firewall of my '79 CJ5.
The 4th pic is provided to me from another forum member. And it should correspond to the third pic.
The 5th pic shows all the wires coming from the XJ bulkhead connector, minus some that I have already cut out. Can I remove all but 5 of these?
Would somebody be kind enough to guide me through this step which is easy for you, but hard for me!?
Thanks, All.
IMG_0143_1.JPG   IMG_0160_1.JPG   IMG_0146_1.JPG   79BulkheadConnector655.jpg   IMG_0142_1.JPG
Kerrdog
Go Fish! <*////><
Skerr is offline
post #312 of 429 Old 06-22-2013, 07:15 PM
SLO_Ken
Scott,
I think you have the letters reversed on your XJ connector. There should be 7 contacts in the A row, and 6 contacts in the H row.
The numbers count up from the outside toward the center of the connector. So, on row D for example, the pin ID's are D1, D2, D4, D5. --- D3, D6, and D7 do not exist.
I'm looking through the '95 wiring diagrams now to try to help you identify which wires you need, and which can be tossed...
SLO_Ken is offline
post #313 of 429 Old 06-22-2013, 07:25 PM
Skerr
Scott,
Possibly Ken, but I am labeling it according to the drawing that was provided me (see pic). Thanks for the help.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #314 of 429 Old 06-22-2013, 07:56 PM
SLO_Ken
It looks like jeepwhore had it right... http://www.jeepforum.com/forum/f8/cl...l#post15506797
XJ -> CJ
position - size - color
E4 12ga RED (Batt +) -> 12A
H2 14ga YLW (Start) -> 13B
B6 12ga DB/YL (Ignition) -> 14B
If you retained the XJ Power Distribution Center, the fuel pump relay will be connected internally. If you ditched the PDC, the fuel pump relay will need to be triggered off 14B as well.
And you'll need to attach the grounds for your XJ harness as well. Not sure where they are on yours.... On mine, they were all terminated at a ring terminal near the ignition coil. Or, position G4 on the XJ bulkhead connector should work as well.
Here's the diagram I was using...
SLO_Ken is offline
post #315 of 429 Old 06-22-2013, 08:08 PM
SLO_Ken
Yeah, I saw that. In the photo of the "very dirty bulkhead connector," it wasn't very clear how many contacts are in the first and last rows. Regardless, both the XJ diagram I was referencing and the diagram you were using show 7 contacts in row A, and 6 contacts in row H.
SLO_Ken is offline
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-30-2016 11:57 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
