Official 4.0 swap thread - Page 20 - JeepForum.com
post #286 of 429 Old 04-08-2013, 11:07 PM
billybooster2
1983 CJ8
Originally Posted by supraman1990
Just thought I would poke in and say.....WOW. I never thought this thread would get like this, all these years later. I don't know where the info from CJ offroad went, as they had the best of everything. If people have specific questions they can PM me again. My jeep I did this to just sold a month or so ago, so I might do another soon, if I can find time to breathe.
Every great journey starts with one step! I went 4.0 head on 258 block + efi. Went well but but but the head gasket lining up was an issue. 7/16 head bolts vs 1/2 inch. It can allow the misplacement by 1-2 mm of the hg. Happened to me. Net result; slow demise of water used through cylinder #2. Got hot. Went bad had to rebore, repiston to 60'". Grrrrr other than that flawless and easy!
Thankyou supranan.
billybooster2 is offline
post #287 of 429 Old 04-09-2013, 05:19 AM
Kman1983
1983 CJ5
I have heard of people using short lengths of copper tubing around a couple of the bolts to center the 7/16" bolts in the head.
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl
"Good Girls and Dirty Jeeps" a song by Opal Justice
Kman1983 is offline
post #288 of 429 Old 04-09-2013, 07:38 AM
billybooster2
1983 CJ8
The head bolts can be centered that way ir by using bushings. That works totally well. Its the head gasket that cant be centered that way. It has to be eyeballed as the gasket holes are bigger than the 7/16 bolts. Thankfully for most, they have 1/2 inch head bolts so it doesn't present itself as a problem.
post #289 of 429 Old 04-09-2013, 02:14 PM
Colt44
1983 CJ7
Checking back in after seeing supraman's post. I last posted almost exactly 2 years ago after doing the 4.0 head swap and MPFI upgrade.
Still working fine and I haven't had to touch anything. Runs like a top. Love it, love it, love it and would never go back to the old setup!
A couple of notes after reading some of the later posts...
I bit the bullet and used the HESCO CPS kit and wiring harness. The CPS kit wasn't too bad but the harness was expensive. However.
It plugged right up and fit very well inside the engine compartment.
If you have the coin and don't want to spend untold hours modifying an OEM harness and/or fabbing up your own CPS mount, I recommend the HESCO pieces.
I did use the computer from a donor '94 Grand Cherokee and saved about $400. Other than the check engine light, my $27 CPU is fine.
(I even bought a spare in case of an EMP attack, but that's another story.)
Regarding head gaskets, bolts, etc. -
I used the 4.0 gasket and IIRC it had holes that matched up with the pins (dowels? not sure of the exact terminology) on the block so alignment wasn't too much of an issue.
Also, the block and tackle I rigged up allowed me to lower the head very gently and thus ensure the gasket was perfectly aligned.
Likewise the head bolts. The new head aligned on the pins, so the bolts only had to take tension, not side loads.
Anyhow, it's been two years of daily driving on/off road, interstate, etc. and not so much as a single issue (knock wood) so in my case all worked out well.
Finally, a question of my own: I used a standard throttle body from a Cherokee and it's fine. But can anyone say whether the 63mm Hesco unit brings anything worthwhile to the table?
"We are all of us in the gutter...
Some of us are looking at the stars."
~ Oscar Wilde via Chrissie Hynde
Colt44 is offline
post #290 of 429 Old 04-09-2013, 03:39 PM
jeepwhore
I can't comment about the TB but apparently swapping the jeep injectors out for ones from a neon is a big improvement. It's one of the add ons I'll be doing with my swap.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #291 of 429 Old 04-09-2013, 05:11 PM
Colt44
1983 CJ7
A Neon. Really? Please, do tell?
Colt44 is offline
post #292 of 429 Old 04-09-2013, 06:35 PM
jeepwhore
For example:
http://www.jeepforum.com/forum/f11/i...-4-0l-1224714/
post #293 of 429 Old 04-10-2013, 02:13 AM
billybooster2
1983 CJ8
Yes x2 on the injectors. 4 holes not 1. The 4.0 head and most 258 blocks were 1/2 inch bolts. There were 2 or 3 years where they went 7/16 thus allowing a bit of potential movement of the gasket!
post #294 of 429 Old 05-05-2013, 04:49 PM
Skerr
I have been reading this thread, trying to glean every speck of info I can! Getting ready to do this swap in my son's CJ5. We picked up a donor '97 XJ for $500. I haven't finished reading yet, and I know I'm jumping ahead, but the research is fresh in my mind. For anyone wanting clarification on the VSS, the specific VSS is for a '91 YJ with the 4.0 -OR- 1988 Dodge Dakota, 2WD, with the 3.9L. They are the same part number at AZ. Other late '80s model Dakotas may work, but you'd have to check.
Here are some more links for the injector swap as JW mentions. Lots of info in the Cherokee Tech forum regarding this. This is a very good upgrade, and you can find the injectors, cleaned and ready to go, on Ebay for about $100 a set of 6.
http://www.jeepforum.com/forum/f13/d...4-0-a-1145336/
http://www.ausjeepoffroad.com/forum/...ad.php?t=92236
http://www.jeepforum.com/forum/f13/d...p-how-1305456/
Kerrdog
Go Fish! <*////><
Skerr is offline
post #295 of 429 Old 05-06-2013, 12:02 AM
1986cj
Late 80s Dodge ramchargers have the vss also. They all still need the adaptor for the spedo cable end to go from 3/4" to 7/8" that the CJ uses. I get them both and screw the adaptor on it and they dont know it didnt come that way at the pick a part yard. I think I picked up 3 of them in one trip with the adaptors for 7.99 each.
1986cj is offline
post #296 of 429 Old 05-07-2013, 03:37 PM
Skerr
'86... please go into more detail about the adapter. I think I read that it comes from the cruise control, but my son didn't find anything today at the JY. He brought home an entire cruise control unit from an XJ! Exactly where do I find it?
Also, for clarification, since our 4.0 came from an automatic XJ, I have to find a flywheel from a manual 4.0??? This will bolt up to a T18.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #297 of 429 Old 05-07-2013, 03:46 PM
NelsonATC
1980 CJ7
I got mine here. It really wasn't worth my time to go junkyard hunting for a $10 part
http://www.speedometersolutions.com/
Mike
1980 CJ7
NelsonATC is offline
post #298 of 429 Old 05-07-2013, 11:38 PM
1986cj
Skerr, I was told from the old cj offroad boards that they were only on the early XJs with the Renix 4.0. I am lazy so I look for a Renix 4.0 (a easy way to tell a Renix is the throttle body only has 3 mounting bolts to the intake manifold, obd1 and obd2 has 4. I look for one that someone else has pulled the dash cluster out. Find the spedo cable and follow it down about 12" and it will unscrew from the cruse control sensor, the adaptor will be on the cable or on the sensor. Just a small black plastic adaptor that is threaded on the inside 3/4" and threaded on the outside 7/8". I just take it off and screw it on the speed sensor and they wont know that it is 2 parts. Hesco's is aluminum in the picture but you will see what the adaptor looks like. Easy to find around here as there are a lot of XJs in the yards in the Denver area. http://www.hesco.us/shop.asp?action=showpic&id=50392&header=false
1986cj is offline
post #299 of 429 Old 05-07-2013, 11:48 PM
1986cj
Skerr, you know that the 97 is obd2 right? more that likely a 97 will have a skim. Do a search on how to defeat it before you take the engine out if it is still in and running.
1986cj is offline
post #300 of 429 Old 05-08-2013, 06:30 PM
Skerr
Okay... thanks. Our yards are "Jeep poor", but I'll look closer and see if I can find one. If not, then I'll buy one from hesco.
A buddy bought the whole '97 XJ for the engine. He was going to put it in his YJ. He heard it run and pulled it. Then he decided to go SBC. I bought the XJ, minus the engine, for a parts car for another son's XJ build (I've got 4 sons!). When the 258 started pukin oil we decided to go 4.0, and I bought the engine. So I ended up with the whole car. We're prepping the engine to crank it on the trailer, where it's strapped down. I do know it's OBDII, but I WASN'T intimidated. Now we're trying to find the "5 to fire", and it ain't working out so well!
-SO-
Would life improve if I find an OBDI ECM?
Can I use the OBDII harness, or do I need to pull the harness as well?
Anybody have a diagram of the '97 XJ fuse/junction box... specifically the pin outs?
Do I have to find the flywheel from a manual 4.0?
TIA...
Kerrdog
Go Fish! <*////><
Skerr is offline
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-30-2016 11:57 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
