Official 4.0 swap thread - Page 18 - JeepForum.com
post #256 of 429 Old 08-20-2009, 10:36 AM
Stan99
1978 CJ7
Alright so here is a list of what I have and what its from. And everything came off of a running vehicle.
Head- 4.0 HO head 92 cherokee
Intake- same
Exhaust Manifold- same
ECU- 93 cherokee (bare bones, no power anything)
AX15 tranny and bell housing, 94 wrangler with CPS
Hesco Wiring Harness
I think I am going to go out and buy a new CPS this weekend and try that. What about the TPS. Could it make it not start? Also I still need to finish some evap lines and cap some other ones off.
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #257 of 429 Old 10-22-2009, 01:49 PM
vortec23
I'm taking a 94 ZJ 4.0 and putting it in a 84 CJ is the colors of the wires the same as an XJ
sticky
vortec23 is offline
post #258 of 429 Old 10-26-2009, 08:46 PM
vortec23
nobody comes to this thread any more
vortec23 is offline
post #259 of 429 Old 10-27-2009, 06:28 PM
Kman1983
1983 CJ5
I think the ZJ harness is different. My '93 Factory Service Manual covers YJ and XJ. I don't have any ZJ manuals. I have read about ZJ theft control issues, however I do have an XJ computer with theft control that won't work in my CJ with the YJ harness grafted in. Best bet would be to buy a factory service manual for the '94 ZJ.
Rolled Red Jeep Club Member #258
'83 CJ5, 4.0 MPFI swap, T18/D20, CenterForce II clutch, Dana44/30(73 CJ5) with 3.73's,'79 knuckles and 11" discs, sagged 4" lift, 2" BL, 34x9.50x15 Super Swamper Pizza Cutters
My wifes website The Vermont JeepGirl
"Good Girls and Dirty Jeeps" a song by Opal Justice
Kman1983 is offline
post #260 of 429 Old 10-27-2009, 09:56 PM
vortec23
I got the wiring its the cps now . Has anyone drilled the hole that can make a template? And what do you do to keep it in the hole since there is no bracket on my CJ trans? How can I tell what tranny is in my cj?
donor-94 ZJ with 42RE trans
The 42RE is for sale- 85K on trans
vortec23 is offline
post #261 of 429 Old 11-03-2009, 07:22 AM
wid2001
Originally Posted by supraman1990 View Post
I'd go with a 3rd option you haven't said. Find an XJ in a you pull it type yard and get the engine as well as the harness. Then thin your harness and piece together the rest of your swap. Thats the way I did it and I'm in roughly $600 with a 111K engine
I am also looking at doing a 4.0 Swap. For option 3 what Model and year Jeeps should I be looking for and is there anything I need to avoid. I have a 1985 CJ7 with the T5 Transmission. You mentioned XJ any particular years or will any of them with a 4.0 work? I also made the mistake of skipping around while I read this thread so sorry for the ignorant out of order questions. I am assuming finding a complete donor vehicle will be easiest. When swapping motors will it be necessary to replace the tranny? I am trying to piece together a list of everything I need to look for from the Junkyard/donor vehicle.
wid2001 is offline
post #262 of 429 Old 11-11-2009, 10:11 AM
vortec23
I ran into some problems my block on my donor is cracked so i am going with a 4.0 head swap but i dont know if the cps is still going to be a problem. What if i get a computer from a manual. Would that help
vortec23 is offline
post #263 of 429 Old 11-11-2009, 04:09 PM
KnacK
Thanks for the pics! I've got this planned (got the donor block and FI ready) and was stuck on how to get the cps mounted.
Chris
'88 YJ Laredo, Hardtop
Red
4.2L Auto 190k miles
3" Body Lift, Rancho Shocks, 31" Wranglers
Sagging springs
Bald tires
Blown tranny
Dead 4.2
Empty wallet
KnacK is offline
post #264 of 429 Old 11-11-2009, 05:26 PM
Kman1983
1983 CJ5
What are you guys running for harnesses?
Kman1983 is offline
post #265 of 429 Old 11-18-2009, 08:13 AM
vortec23
ok guys i did the 4.0 head swap i used 4.0 dist. now i am at the wiring i need to know about using the starter and alt. from my 4.2 how do i make it work i am getting the cps relocating kit
vortec23 is offline
post #266 of 429 Old 03-04-2010, 06:18 PM
BooostedSupra
Hey, a lot of really helpful info here, I was wondering if someone could help me with a question, I have a 1989 4.0 motor to replace my tired 258 w/5 speed trans behind it. With the engine I picked up the whore harness, ecu, cps and read all up on the cps mod to make it work with the bell housing. My question is, since I have the YJ flywheel and the clutch for it, do I just use my factory CJ throwout bearing and everything works and bolts together? Because the YJ throwout was hydro and obviously my 85 CJ7 is mechanical. Thanks in advance!
BooostedSupra is offline
post #267 of 429 Old 03-19-2010, 02:29 PM
likeshills08
Hey, is there any emmissions equipment (ie. egr, air pump) that need to be installed with the 4.0l head/harness/intake for a 4.0l head swap?
1985 cj7 - down to frame and drivetrain and getting ford powered.
1993 ranger 4x4 3.0l - DD
1980 f100 4.9l - jeep's home base (holds parts)
likeshills08 is offline
post #268 of 429 Old 03-21-2010, 10:04 AM
green89yj
Hey, I need help with wiring. I traced out the OBD2 port and got it all hooked up after buying one from the junkyard off the same model year XJ as my engine but there was an extra yellow wire with a black tracer that I don't know where it goes. I can see that it is in the OBD2 plug not the gauge plug.
Secondly on the wiring, I heard I need to rearrange some pins in the bulkhead connector to supply power to my PCM (computer thing). Is this true? Can I just clip them and put them on a switch?
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #269 of 429 Old 06-25-2010, 02:18 PM
Stan99
1978 CJ7
What Exhaust is everybody running in there CJ with the 4.0? Did anybody go custom? I just got a quote for $550-600 for complete exhaust system and I do not want to spen that much! Let me know.
Stan99 is offline
post #270 of 429 Old 06-27-2010, 10:56 AM
vortec23
I built my own used the 4.0 header and custom everything else very cheap..
The only thing i had to buy was the tailpipe.
vortec23 is offline
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-30-2016 11:57 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
