Official 4.0 swap thread - Page 17 - JeepForum.com
post #241 of 429 Old 04-04-2009, 07:13 AM
Last Boyscout
1979 CJ7
Originally Posted by flashfludjr View Post
I only need those 5 wires you had said the harness will be a little thin.
The "5 to fire" refers to the wires you splice to run the donor motor. YOU NEED MORE THAN 5 WIRES.
When we talk about thinning the harness we are referring to features in the harness that will not be used. You must keep all the wiring related to the sensors to run the motor. Your motor is an 87 so it would be a Renix (not OBDI or OBDII). From what very little I've read about Renix swaps it should be simple and straight forward. I do not believe there is a lot you need to thin unless the donor was fully loaded. In 87 must of the "loaded" options wold be in the cab wiring harness.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
Last Boyscout is offline
post #242 of 429 Old 04-04-2009, 09:11 AM
coastiedennis
1953 M-38
Cam Position Sensor
If you do the 4.0L head swap do you still need the cam position sensor? or can you run it stand alone with a junk yard computer and wiring? I built a ford 360 with direct port and we made it stand alone with a stock early '90s f150 computer, but i can't remember if there was a cam sensor on it or not.
coastiedennis is offline
post #243 of 429 Old 04-21-2009, 10:16 PM
stoveguy01
Help
ok someone I need help. first a little history Ive got an 89 wrangler with the 4.2 that fairly fresh. just swaped the head for a 4.0 ho off a 92 cherokee along with the complete mpi setup. I used a 4.0 flywheel and a new cps sensor. My problem is when I try to start it it will start fow about a sec than die. Ive traced out all the wiring a dozen times all ground are hooked up neutral safety is grounded everything looks gd just cant get it to run. Ive tested the computer on a running cherokee and it works. Im stumped Ive done numerous fuel injection swaps using chevy engines this is my first chysler conversion. ANY HELP would be gratefull
stoveguy01 is offline
post #244 of 429 Old 04-29-2009, 01:20 PM Thread Starter
supraman1990
supraman1990's Avatar
1980 CJ5
If it had theft control it most likely wouldn't run in another cherokee either. Is it getting fuel? Check with a pressure tester at the valve on the rail. Should be 40ish PSI at idle on start up.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #245 of 429 Old 05-29-2009, 12:15 PM
Stan99
1978 CJ7
Just a couple quik questions. I am finally starting my wireing on my MPI setup. I have herd that the Hesco computer will run better than a stock and that was from a guy who sells the stock computer. If I do get a stock one what are the #'s that I should stay away from?
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline
post #246 of 429 Old 05-30-2009, 08:51 AM
Last Boyscout
1979 CJ7
Originally Posted by Kman1983 View Post
Stoveguy what is the number on your computer? It may be one of the computers with theft control. As I understand it that is what happens with the theft control computer.
I have to agree with Supra. If it was a SKIM issue with the ECM then it proably wouldn't work on another XJ. In the reading I've done I don't recall SKIM being an issue on OBDI.
Supra glad to see your back. It's summer finish that Jeep.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
post #247 of 429 Old 06-25-2009, 05:57 PM
Kdozier
1982 CJ7
Small problem, I have a '94 4.0l with an '82 T5 mated but cannot get the starter installed. It appears that the oil pan bolts are getting in the way. Has this been a problem for anyone else?? Can I just cut the bolts? Also I am using the CJ flywheel and CJ starter.
Kdozier is offline
post #248 of 429 Old 07-24-2009, 07:10 PM
Kman1983
1983 CJ5
My 4.0 is running!! I need to adjust the clutch in the morning but I should be driving it tommorrow!!
Kman1983 is offline
post #249 of 429 Old 08-06-2009, 12:22 PM
HeepToJeep
1982 CJ8
I'm planning a build and intend to use a 4.0/AW4 drivetrain.....the goal being to mix/match engine componants from the different years to get the most power out of it as possible. Here's what I'm thinking engine wise:
97+ Cherokee 4.0 shortblock
91-95 Cherokee Head
99-01 Cherokee Intake/Exhaust manifolds
91-95 Cherokee OBDI computer/harness
Anyone disagree or think I should be using Grand Cherokee parts instead? I'm just trying to figure out what the BEST model/model years parts donors are going to be since I'm starting from scratch....chime in guys, this will be very useful info!
I might stroke it with 258 internals if it can be done without affecting reliability, but, I have no intentions of changing the bore size.
Wm
82 Scrambler
89 Cherokee
85 Grand Wagoneer
HeepToJeep is offline
post #250 of 429 Old 08-13-2009, 01:00 PM
Stan99
1978 CJ7
Quik question, I am having trouble getting my engine to fire up. I have a 4.0 head, Mpi, AX15 tranny with the bellhousing CPS and a hesco wiring harness. It just back fires. Now I have checked and redone the dizzy and I am possitive it is installed correctly! So I think my problem lies with the computer or the CPS. The computer is throwing wierd codes and I am working on getting a code reader to get the codes that way.
My question is, when I mounted the flywheel was there a certain way for it to go on or does it just bolt up? Could my problem be there?
Please I need help!
Stan99 is offline
post #251 of 429 Old 08-17-2009, 01:52 PM
Stan99
1978 CJ7
The flywheel should only go on in one position, the bolt holes are drilled in a pattern so they only line up in one spot. Did you do your own bellhousing mod? Do you have pictures I could compare to mine? Mine is working fine but I swapped in a running 4.0. Check this write up on indexing the 4.0 distributor http://www.angelfire.com/my/fan/dist_index.html
Thats what I thought about the flywheel. I have read just about everything I could find on indexing the dizzy. It is in there right. I have checked it a million times! It is driving me nuts. I am trying to get a code reader, here are the #'s it throws when I check the codes.
1__2__3__5__7__3__3__5__4__1__ then 55 to end it.
I have checked this about 15 times, I've even had my wife, neighbor and my 9 year old son count it out, and it throws the same #'s everytime.
Stan99 is offline
post #252 of 429 Old 08-18-2009, 04:40 PM
Kman1983
1983 CJ5
So it's: 12, 35, 73(?), 35(again), and 41?
Kman1983 is offline
post #253 of 429 Old 08-19-2009, 10:56 AM
Stan99
1978 CJ7
Exactly. I dont understand it. Could it be because I am using a Led light instead of a regular light? I am lost!
Stan99 is offline
post #254 of 429 Old 08-19-2009, 06:59 PM
Kman1983
1983 CJ5
12 should be batterry disconnected in the last 50 key-on cycles, 35 should be an open or shorted condition detected in the radiator fan relay circuit, 73....I have NO clue???, 35 we covered and 41 should be an open or shorted condition detected in the generator field control circuit. I don't know if using an LED would change anything but I wouldn't think so.
Kman1983 is offline
post #255 of 429 Old 08-19-2009, 07:02 PM
Kman1983
1983 CJ5
Stan what did you pull the computer out of?
Kman1983 is offline
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-30-2016 11:57 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 08:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
