Official 4.0 swap thread - Page 13 - JeepForum.com
post #181 of 429 Old 09-08-2008, 05:44 PM
Last Boyscout
1979 CJ7
and the e-mail notification (new post, pm, ect...) is none existent.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
Last Boyscout is offline
post #182 of 429 Old 09-20-2008, 09:55 PM
noriegaramon
Originally Posted by kconnor123 View Post
Great idea getting a manual 91-95 cherokee for the swap, but that manual tranny'd 91-95 cherokee's are extremely hard to find. I've been looking...I think they must have built about 10 over that 5 year span....
And if you try to find a wrangler from 91-95 for cheap cheap, good luck, everyone who owns a wrangler from those years think they are worth at least 5 grand no matter how rusty and beat down they are. Supra how much did you pay for your donor wrangler?
Well I finally came across a 1992 4.0 manual jeep cherokee!
I'll start my swap in a few weeks, i bought the whole car for 800!!
it runs great but has body damage! haha!!
I wanna know how much of it I can use on my CJ7~
Transfer case, differentials, engine, tranny, light wiring, etc.
Thank you guys for all ur info! it's helped me a lot!
Greetins from Cabo San Lucas!
noriegaramon is offline
post #183 of 429 Old 09-21-2008, 08:36 AM
Last Boyscout
1979 CJ7
With out heavy fab work you can use the engine, tranny, engine wiring, and power steering gear box. Based on how much fabrication you want to do you can use all the XJ wiring and steering column and instrument cluster (that's what I did.) The t-case is little use to you unless you are going to swap the axles. And that would require a ton of fab work. Just step back and take a look at the XJ axles and see if you could clean and weld perches to resemble the CJ's. They are wider and the front diff pumpkin might be in a position where you can not get a perch on it. you would probably have to spring out the front and I would save that for stronger axle up grade. You might need and adapter for the tranny to t-case. Check www.novak.com in their knowledge base to figure that out.
And by the way CABO! You suck. Mas Tequila Por Favor!
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
post #184 of 429 Old 09-23-2008, 06:37 AM
Last Boyscout
1979 CJ7
You only use the 4.0 starter if you are useing the 4.0 fly wheel. If you are keeping your original fly wheel, clutch, and tranny then you need to use the 4.2 starter.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
post #185 of 429 Old 10-09-2008, 04:12 PM
Last Boyscout
1979 CJ7
what happened? we lost our sticky statis.
STEP 1: BUILD IT!
STEP 2: BREAK IT!
STEP 3: REPEAT!!!!!
post #186 of 429 Old 10-11-2008, 08:23 PM
Kman1983
1983 CJ5
Just got an ECU or PCM as it's seems called both for a '95 Cherokee 4.0 auto...hope it works out with my "93 engine and harness and manual tranny.
Kman1983 is offline
post #187 of 429 Old 10-11-2008, 10:57 PM Thread Starter
supraman1990
supraman1990's Avatar
1980 CJ5
They are all the same. Unless for some reason you have cruise. ON another note, I'm going to check with Eddie about the sticky status.
80 CJ5 in the process of a frame up resto
96% complete.
The little stuff will kill me.
On the back burner for college.
supraman1990 is offline
post #188 of 429 Old 10-12-2008, 09:14 AM Thread Starter
supraman1990
1980 CJ5
Running well. I am the originator of the thread. MY info wouldn't put very much confidence in you guys if mine didn't run either would it?
96% complete.
post #189 of 429 Old 10-14-2008, 01:54 PM
ttrem
so i dont have enough room in the engine cab after my swap for the airfilter housing. My budget is pretty low due to wife agro, what can I use as a relatively cheap replacement?
1986 CJ-7 w/ 4.0HO FI, 4" lift, 1" body lift on 35" Super Swampers, AX-15, and a girly sounding horn =(
ttrem is offline
post #190 of 429 Old 10-14-2008, 06:22 PM
Kman1983
1983 CJ5
Received my E-bay wiring harness today... it's for a 4 cylinder not a 4.0 as it was advertised....
Kman1983 is offline
post #191 of 429 Old 10-14-2008, 06:27 PM
Kman1983
1983 CJ5
Anyone know where I can get the wiring and connectors to add 2 more injector wires?
Kman1983 is offline
post #192 of 429 Old 10-14-2008, 08:53 PM Thread Starter
supraman1990
1980 CJ5
As far as I know you really cant. The connectors are the same, but I wouldn't trust adding in. Contact the seller and tell them you want a full refund.
96% complete.
post #193 of 429 Old 10-18-2008, 07:19 PM Thread Starter
supraman1990
1980 CJ5
You can get a CJ manual, but their are so few wires you need from CJ, that I didn't get one. As far as your air filter, I went simple. I honestly just took a K&N cone filter that was the correct inside diameter and slipped it directly over my throttle body. It works, and keeps the clutter down very well.
96% complete.
post #194 of 429 Old 10-25-2008, 08:45 PM
Kman1983
1983 CJ5
I received the 4.0 harness today...numerous cut wires...Really losing my faith in E-bay items...Might just stick with a carbed engine at this point.
Kman1983 is offline
post #195 of 429 Old 10-26-2008, 09:12 AM Thread Starter
supraman1990
1980 CJ5
How much are you willing to spend on one? I've got a guy that I purchased my engine from ad some other odd and end stuff on there that could probably set you up. PM me.
96% complete.
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-31-2016 12:57 AM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 07:29 PM
Official Engine/Assembly/everything else thread jagerlager Jeep CJ Forum 162 10-31-2010 09:30 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 06:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 08:59 AM
