Official 4.0 AX-15 swap thread - Page 4 - JeepForum.com
post #46 of 88 Old 01-23-2012, 05:35 PM
levergun
1979 CJ5
Originally Posted by contdevelop View Post
Please excuse the hijack. Do you know the part number for the slaver cylinder pictured or one that works with a thread line? Anyone? I already have a master cylinder installed in my Cj7 from when i did the hydraulic swap and have a braided line running to the old slave. Now that I am installing an AX15, I need to use a different slave and all the slaves I found have the goofy connection.
Part was purchased from autozone and is a duralast part # 12457. Quick search revealed that is is also a bendix part number. Application is a 1988-1991 c1500.
http://www.autopartswarehouse.com/de...lave_CylinderQ Q19881991QQBF12457.html?apwcid=E1209090014W48113fd eed4c3&apwkwd=Bendix+Clutch+Slave+Cylinder&id=8k54 qmru&source=pjn&subid=3663
http://www.rockauto.com/dbphp/x,cata...dix_12457.html
http://www.summitracing.com/parts/BEN-12457/
There are mods that have to be done but it's pretty simple and easy. I had to drill 2 new mount holes as you can see in the pic and I had to grind the inside of the slave mount to clearance the trans. Also I had to shorten the pushrod by about 2". It was well worth it IMO to not have the stupid wimpy plastic one lol.
1979 CJ5 408 AMC dana 60/14b, T18, d300, PSC hydro assist
1948 Willys CJ2a LS 4.8/sm465 scout 44's
levergun is offline
post #47 of 88 Old 01-23-2012, 05:50 PM Thread Starter
ymurf
1979 CJ7
Have a little hold up.While washing the inside of the transfer case out I noticed the back seal was leaking diesel that I was using to clean.So before I install it I am going to put a rear seal in it.Nobody around here has them in stock so I ordered it at local car quest.Suppose to be here Wednesday.
ymurf is offline
post #48 of 88 Old 02-03-2012, 03:14 PM Thread Starter
ymurf
1979 CJ7
Sorry no update in awhile.Got new seal in and got my buddies transmission jack and going to get the transfer case in one way or another.Will update later.
ymurf is offline
post #49 of 88 Old 02-04-2012, 10:10 PM Thread Starter
ymurf
1979 CJ7
Well another set back.I got the wrong clocking ring.I got a flipped ring and that's not what I need.Good people at Novak are sending me a new one out Monday and I will send this one back.Its always something.Guess I will get my fuel system finished while I wait.
ymurf is offline
post #50 of 88 Old 02-11-2012, 07:25 PM Thread Starter
ymurf
1979 CJ7
Another set back again.I got the new clocking ring in and put it on.Figured I would fill transfer case up before the install and fluid was a steady drip from the front output shaft seal.I called every parts store around and no luck finding one so now I have to order one monday.If its not one thing its another.
ymurf is offline
post #51 of 88 Old 02-16-2012, 05:24 PM
RockScar
what are you doing as far as a fuel pressure regulator?
Also, have you done the vss yet? I'm doing mine now, curious as to what you are doing to mate the 2 prong 91 VSS into the 3-prong harness.
Live free or die. Death is not the worst of evils.
RockScar is offline
post #52 of 88 Old 02-16-2012, 07:21 PM Thread Starter
ymurf
1979 CJ7
The 94 4.0 I am running already has it on the fuel rail.I may have to order the 3 prong to 2 prong adapter from Hesco for the VSS.I cant find one anyplace used.
ymurf is offline
post #53 of 88 Old 02-17-2012, 11:33 AM
RockScar
After I posted this, I went to the Napa site. They sell a connector, but it's $25!!! But looking at the picture of it there, it looks really similar to a lot of the male plugs that the 258 used. So, I'm going to look at my old harness to see if something will fit. Seems fairly likely that they would've used the same connector for multiple things. I'll let you know what I find.
RockScar is offline
post #54 of 88 Old 02-17-2012, 04:30 PM Thread Starter
ymurf
1979 CJ7
You have a part number for the one Napa has? The Hesco one is $17 plus shipping.
ymurf is offline
post #55 of 88 Old 02-18-2012, 11:00 AM
RockScar
I'll do you one better, here's the link.
Part Number: ECH EC165
Product Line: Echlin Ignition Parts
RockScar is offline
post #56 of 88 Old 02-18-2012, 11:04 AM
RockScar
Oh, and btw the hesco 'adapter' is not really an adapter, but a plug to splice in.
Another question, have you found anything regarding which two of the three wires are used and which on goes to which vss pin? I assume the third is a speedo signal...
RockScar is offline
post #57 of 88 Old 02-18-2012, 11:56 AM Thread Starter
ymurf
1979 CJ7
Thanks for the link. There is a thread on here some place but cant find it right at the moment that tells what two wires to use.
ymurf is offline
post #58 of 88 Old 02-18-2012, 05:05 PM Thread Starter
ymurf
1979 CJ7
Have another set back.Went to bolt the transfer case up and the shifter bracket wont clear the transmission.I have done lots of reading on this swap and dont remember anyone mentioning this problem.There is no way,The bracket is going to hit on the AX15.I made a thread asking for help from anyone that has done this swap but either I am the only one or nobody has read it yet.
ymurf is offline
post #59 of 88 Old 02-18-2012, 06:29 PM
RockScar
wont clear the tranny? or the tub? I'm trying to imagine where it hits...
It's the tcase aluminum shifter bracket, right? where is it hitting the tranny?
RockScar is offline
post #60 of 88 Old 02-18-2012, 07:16 PM Thread Starter
ymurf
1979 CJ7
Here is where its going to hit.I took a pic through the tunnel and I still need to go 1 1/2" to mount transfer case.
ymurf is offline
Official AMC V8 swap thread BLS33 Jeep CJ Forum 493 03-30-2016 11:57 PM
Official 4.0 swap thread supraman1990 Jeep CJ Forum 428 01-04-2016 06:34 PM
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Official AMC V8 swap thread/Need more imafishingfred Jeep CJ Forum 11 10-21-2007 05:43 PM
Official CJ Lift Thread webejpn01 Jeep CJ Forum 1 10-06-2006 07:59 AM
