-   -   OEM Air Cleaner with headers (http://www.jeepforum.com/forum/f8/oem-air-cleaner-headers-1752698/)
Sherms-CJ7 11-03-2013 08:30 AM
2 Attachment(s)
Trying to get an OEM air-cleaner installed with lines run correctly. So far, I've found some great info here ...
http://www.jeepforum.com/forum/f8/ai...stions-864676/
http://www.jeepforum.com/forum/f8/he...-pics-1596457/
http://home.sprynet.com/~dale02/aircl.htm
http://home.sprynet.com/~dale02/vac-tac.htm
Great info, but I still have a few questions, mainly because years ago (as a young/dumb Jeeper ...wondering now if it was a mistake) I installed Hedman Headers to get a horse power boost. Now, trying to get the air-cleaner working, I don't see where I would "heated-air" from for the air-cleaner. The headman headers do have some sort of manifold with a valve that I don't know what to do with, but some how I doubt that's for the heated-air:
Pic with arrows showing manifold and valve:
Attachment 810690
Pic from different angle (looking down):
Attachment 810706
Wondering if the headman headers don't have the an output for heated air and thought I'd check with you guys to see if someone knows or has run into this problem ... or is this just something I have to live with, i.e. slow warm-up time. Any of your thoughts/input or idea's would be greatly appreciated.
Best regards - :cheers2:
John
Matt1981CJ7 11-03-2013 09:18 AM
1 Attachment(s)
John,
The "heat box" on the factory exhaust manifold is just a sheet metal enclosure with a round lip to attach the flexible heat tube. There is no opening to the exhaust. the breather simply sucks the heated air from around the manifold.
Hears a pic of some V8 manifolds that shows the heat box on the upper one.
Matt
fourbtgait 11-03-2013 09:29 AM
John,
I had the same problem as you, though mine was a stock cast iron exhaust which did not have the bolt castings in it as shown in the picture Matt supplied. I ended up with my own sheet metal enclosre around the exhaust, bolted to the block with the flex hose going from it to the OEM air cleaner I installed.
So it is possible to retrofit, just a pain.
Russell
Sherms-CJ7 11-03-2013 10:29 AM
Originally Posted by Matt1981CJ7 (Post 17393082)
John,
Matt
Thank you Matt!!
Yours was one of the more helpful postings on the topic, so Thanks very much again! Yeah, I was wondering if it was something like that ... I knew it couldn't be blowing exhaust back into the air-cleaner; that's just silly. But, I wasn't sure if there was some sort of special valve or whatever - I just didn't know ...
One more ... Thank You again for taking the time to respond!!
:cheers2:
John
Sherms-CJ7 11-03-2013 10:32 AM
Originally Posted by fourbtgait (Post 17393394)
John,
Russell
Thanks Russell! Really appreciate your input on this!
I will be doing something similar to what you're describing ... just one more project - right?
Thanks again - :cheers2:
John
swatson454 11-03-2013 11:43 AM
Hooker Headers used to make a bolt-on kit that had basically a little heat stove that bolted around one of the header tubes with an outlet that you'd attach to the air cleaner snorkel. I just did a quick search but came up empty. You might give Summit a call and see if the thing is still available.
Shawn
Spieg8 11-03-2013 02:27 PM
Aftermarket kits for this purpose used to be common back in the day, but with so many cars running EFI today, they seem to have gone the way of the dinosaur. You'll probably have to fabricate something to attach to a header tube (could probably just use a hose clamp to hold it in place).
Sherms-CJ7 11-04-2013 04:25 AM
Shawn
Thank you both - I'll try calling Summit, but I'll get ready for bad news. Have already been thinking about how to fab one.
Thanks much for taking the time to resond!
:cheers2:
John
Matt1981CJ7 11-04-2013 04:41 AM
Thanks much for taking the time to resond!:cheers2: John
Be sure to post what you come up with. I'm sure there are others in the same boat.
Matt
Sherms-CJ7 11-04-2013 04:42 AM
1 Attachment(s)
This looks very different, but wondering if it could be made to work ...
http://www.teamgrandwagoneer.com/air...-gw-1979-1991/
Attachment 813786
:cheers2:
John
Sherms-CJ7 11-04-2013 04:53 AM
2 Attachment(s)
Matt
Hey Matt!
Absolutely, I'll make sure I get back here to do so!!
BTW - if you don't mind, I have a quick question related to putting air-cleaner back in order ... since you're around. What is the fitting that goes in the air-cleaner to connect the PCV system? I can't find anything there???
Also, I'm a little confused - I think I need one PCV valve at the front of the engine, which is a T, since I have a 1982:
1982-1986 Jeep CJ with 6 Cyl T shape
Attachment 813794
... then the one for the rear of the engine would be the Elbow, Valve Cover Emissions:
1980-1992 Jeep CJ5, CJ7, CJ8, Wrangler YJ
Attachment 813802
Again - Thanks much for taking the time to impart your wisdom here ...
:cheers2:
John
Matt1981CJ7 11-04-2013 04:58 AM
John,
The rear intake hose connects to a similar sized nipple on the side of the air-cleaner housing.
Your PCV valve and elbow appear to be correct.
Matt
Sherms-CJ7 11-04-2013 05:11 AM
1 Attachment(s)
Originally Posted by Matt1981CJ7 (Post 17416810)
John,
Matt
Sorry, to need clarification ... I know you're busy, and I know you post Allot on the topic of air-cleaners etc. Do you have any idea where I might find a rear intake hose connector? Is that what you are calling out in this post for #6 ...
Attachment 813810
Originally Posted by Matt1981CJ7 (Post 16090625)
Kov,
1. See pic to help you with the TAC plumbing.
2. That's the thermal switch for the TAC system.
3. That's the Thermal Vacuum Switch (TVS) for the EGR system. (see diagram)
4. Thermal Electric Switch. It tells the computer when the air temp in the air cleaner is above 65 degrees.
5. Air supply tubes for the Pulse Air System.
6. PCV intake filter element. Can be cleaned and reused, or replaced. A chunk of a green Scotch Brite Pad works in a pinch.
Matt
Again, Thank You for your patience with this!! The air-cleaner thing and vacuum lines etc. is a real confusing mess, and I know you spend a good amount of time answering questions on the topic ... and, it is very, very much appreciated!!
:cheers2:
John
Matt1981CJ7 11-04-2013 05:50 AM
1 Attachment(s)
I'm not sure I understand your question.
The little square filter element goes inside the air-cleaner just opposite the nipple that the PCV intake hose connects to. The nipple is built into the air-cleaner housing.
You can see the setup in this pic.
Matt
Sherms-CJ7 11-04-2013 06:27 AM
Thank you Matt!!
I was just asking to make sure I understood the setup. The air-cleaner I have (bought off eBay) is missing the little square filter element and is also missing the nipple that's built into the air-cleaner housing. I've searched the usual sites, Quadratec.com, jeep4x4center.com, etc. and even teamgrandwagoneer.com, but no-luck. Really though, with your description and the picture that was posted, I should be able to rig something fairly easily. Then again, if you know of anywhere that I can find an OEM part, I'd love to be able to just order it.
... and, then again, maybe I'll get lucky and this is some super generic part that is sold in most auto parts stores, so I guess I should try that as well.
Thank You Again - :cheers2:
John
The time now is 07:28 PM.
