OEM air cleaner for 258 - Page 2 - JeepForum.com
post #16 of 37 Old 01-07-2014, 08:17 PM
chucker2
1981 CJ7
not trying to high jack your thread, but will one of these work on my 4.0l? what is the diameter of this thing? what are cjs running that have a 4.0l ?
chuck
chucker2 is offline
post #17 of 37 Old 01-07-2014, 08:25 PM
bligon64
1974 CJ5
I've put a motorcraft 2bbl on mine with a holley high intake filter.
bligon64 is offline
post #18 of 37 Old 01-08-2014, 05:21 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Originally Posted by chucker2 View Post
not trying to high jack your thread, but will one of these work on my 4.0l? what is the diameter of this thing? what are cjs running that have a 4.0l ? chuck
Chuck
If you can find one, AMC put 4-bbl carbs, and air cleaners, on some FSJs with 360s and 401s.
IIRC, the hole diameter is 5-1/8" for most 4-bbl carb air cleaners.
Matt
Matt1981CJ7 is offline
post #19 of 37 Old 01-08-2014, 09:21 AM
wm69
Originally Posted by VACJ7 View Post
It is less than perfect but I used it for several yrs. The heat door opens with my finger, do not know if the vacuum can will open it. Several ports on the back have been sealed. Couple ports have been capped or plugged with rubber stoppers. The neck where it sits on the carb was modified by the previous owner. He cut it shorter for some reason but it still worked. I don't have the bracket that attaches to the valve cover that the air clearner sits on. Ha, the more I describe it the crappier it sounds!
I cut my neck down on mine too, so it would fit on the 32/36 Weber I was running with an adapter.
Sounds like it's perfect for the OP's needs!
wm69 is offline
post #20 of 37 Old 01-08-2014, 10:55 AM
jrnewt
chuck
If you have a 4.0 with fuel injection, it will likely not work. These sit on the carb to filter the air going in to them. The 4.0 engines have a stock air cleaner that sits on top of a plastic box and moves air in to the throttle body.
jrnewt is offline
post #21 of 37 Old 01-08-2014, 11:13 AM Thread Starter
jason400
That looks good VACJ7, whats the asking price?
jason400 is offline
post #22 of 37 Old 01-08-2014, 11:15 AM Thread Starter
jason400
I don't think I need all of the vacuum ports, my CJ has been nuttered and I am running a weber 32/36. If I need to modify something then I will.
jason400 is offline
post #23 of 37 Old 01-08-2014, 04:12 PM
chucker2
1981 CJ7
Yeah, I just looked around the web and found the chrysler (made from 97 to 04) air box and long hose that travels over the valve cover to the passenger fender works. looks kinda funky though.
chucker2
chucker2 is offline
post #24 of 37 Old 01-08-2014, 04:15 PM
Matt1981CJ7
1981 CJ7
Chuck,
My apologies. I mis-read your earlier post and thought you had a 401, not a 4.0. My bad.
Matt
post #25 of 37 Old 01-08-2014, 05:17 PM
capt205
1983 CJ7
capt205 is offline
post #26 of 37 Old 01-08-2014, 05:49 PM
keith460
Jeep. There's Only One
keith460's Avatar
Originally Posted by jason400 View Post
VACJ7, I would like to see it. Please post some pics. I am currently running a new Weber 32/36 with the breather that came with it. I am going to buy an adapter and use the oem style cleaner. No inspections issues, just a little more protection and cooler air in the warm months.
You never did say if you had manual or power brakes. The air cleaner assemblies are different for each application.
I converted my CJ-7 back in 1988 to power brakes and bought the correct air cleaner from the dealer with all parts associated with it including all mounts, upstream and downstream hoses and fittings for $115.00 new.
I now use the same air cleaner assembly on a 32/36 Weber I bought during a restore and had to buy the Weber adapter and raise the the air cleaner assembly by 1 inch.
1984 CJ-7 Renegade
keith460 is online now
post #27 of 37 Old 01-08-2014, 07:07 PM Thread Starter
jason400
power brakes. I picked up a used 258 from a coworker for $100. It is a 83 CJ7 with 93k miles that his dad purchased new. He said he may have the original air cleaner to go with it but his didn't have power brakes, what is the difference in the cleaners?
jason400 is offline
post #28 of 37 Old 01-08-2014, 07:27 PM
chucker2
1981 CJ7
keith460, I think I can fab this 258 air cleaner to fit my 4.0l. it will look a lot better and have the accordian tube connected to the grill. do you see any reason this would not work.
chucker
chucker2 is offline
post #29 of 37 Old 01-08-2014, 08:18 PM
VACJ7
VACJ7's Avatar
I don't really have a need for it. How about 25.00 plus shipping? Let me dig around, may have the accordian tube somewhere to hook it to grille. As for the actual mount part, I fabbed my own. If I can find it, you can have it.
The difference between the manual and power brake cleaner is where it sat. Manual brakes it sat right on top of the carb. With power brakes there is no room so it was an offset model like I have.
'84 CJ-7 |
VACJ7 is offline
post #30 of 37 Old 01-08-2014, 08:40 PM
VACJ7
VACJ7's Avatar
OK, you are in luck. I found both pieces. The bracket is home made. I used nylon spacers under it and screws cut to length to raise it to the proper height when attached to the top of the valve cover. If you want to kick in a few bucks for my awesome fab skills that's cool. hahahahaha.
'84 CJ-7 |
VACJ7 is offline
258 , 4.2 liter , air cleaner
