OBD Light - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > OBD Light
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenRight Offroad at CCOR! 706-207-4140Rough Country Lift Kits and Parts!
Unread 06-01-2006, 11:27 AM   #1
durkeeam
OBD Light
I have a 2003 CJ, 13000 miles on it. Check engine light came on today, and wouldn't you guess it...the last day on the warranty was yesterday!! i swear they have some sort of timer
I know that a lot of times when these lights come on, it just means something as simple as the gas cap isn't screwed in all the way, but you have to have a repair shop reset the light which can cost upwards of $100. Is there any way for me to find out on my own what the problem is? If it is the gas cap would possibly removing it, and then replacing the gas cap make the light go off or am I stuck with having a mechanic reset the light?
Thanks
durkeeam is offline   Reply With Quote
Unread 06-01-2006, 11:39 AM   #2
durkeeam
sorry, i definitely put this under the cj thread, when i meant to put it under tj thread
Unread 06-01-2006, 04:16 PM   #3
jadams68
For a minute there, I was very jealous of your "CJ"
I used to own a CJ....:-(
http://www.bustedjeep.com
AIM: Qsting68
jadams68 is offline   Reply With Quote
Unread 06-01-2006, 08:09 PM   #4
mxg342
you can pull the codes by cycling the key off on three times
off
on
off
on
off
on and leave it in the on position without ever hitting the start position.
Watch the check engine light
it will flash something like this
flash pause flash long pause flash pause flash pause flash
This would be code 23. Do an online search for codes or post on the TJ forum for some help.
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage
"when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp"
mxg342 is offline   Reply With Quote
