Nv4500 - JeepForum.com
post #1 of 3 Old 11-12-2003, 07:39 PM Thread Starter
bods7
1983 CJ7
Nv4500
I'm starting to put together my frame up resto and I ran onto an issue. I just installed my NV4500 in my 83 CJ-7. Once the transfrer case was on I realized that I have an extreame driveline (driveshaft) angle to compensate for. The transmission is almost horazoltal and the rear pinion is sticking up at about a 35 degree angle.
Now I did expet the driveline increase, especially with the 4 inch Skyjacker suspension lift, and the extended lenght of the NV4500. The lift came with a pinion shim adjustment that I thought would slove the problem. Just in case I also installed a 1" drop bracket for the tranny cross memeber. It's the fact that the tranny dosen't point down a little that is concerning me. Has anyone run into this situation doing a resto. I know one solution is a constant velocity (CV) shaft, and I plan on doing this, but even with the CV it looks as though I will need to do something else as well. I was wondering if the additional weight of the body and rest of the jeep will bring down the angle? My other option is to lower down the transmission crossmember more. Anyone use more than a 1" drop on their crossmember to get proper angles? Any thoughts or sugestions will help.
Thanks
Ryan
bods7 is offline
post #2 of 3 Old 11-12-2003, 07:45 PM
jadams68
jadams68's Avatar
Thanks
Ryan
You might want to call Tom Woods at tomwoods
Not only could he help you figure out your true pinion angle, but could also set you up with a CV shaft and or steeper shims.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 3 Old 11-15-2003, 02:24 PM Thread Starter
bods7
1983 CJ7
Nv
Thats a great site. I will have to call him when I can come up with the cash to put what i need thanks
bods7 is offline
Nv4500 spiderjeep Jeep CJ Forum 28 03-10-2010 09:33 AM
NV4500 GL-4 or 5?? again. . . . texasimport Jeep CJ Forum 2 01-09-2010 12:47 PM
Nv4500? andyp65 Jeep CJ Forum 18 07-13-2007 05:43 PM
304 V8<-->NV4500 gjohnson Jeep CJ Forum 0 03-14-2004 07:26 PM
Nv4500 bods7 Jeep CJ Forum 1 10-13-2003 11:59 PM
