Quantcast Nutter'ed my 84 CJ7 2.5 today! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Nutter'ed my 84 CJ7 2.5 today!
Free Shipping on TIRES at KrawlOff-RoadSpartan Lockers FREE SHIPPING Excellent PricesBlack Magic Brakes - 5% Off, No Minimum Purchase Required
Old 10-10-2008, 09:15 PM   #1
79cherokee
Hey all,
Been having trouble with my 84 CJ7 with the amc 2.5 with it not starting due to no spark. Replaced the module, tried different coils, even a new pick up coil. After replacing the pick up coil it ran. Now this Jeep has been in my garage for over a year so no miles were put on it because it was only in the last few months it was even together.(frame off rebuild). Well, it started up about 3 weeks ago, and went to start it up last week to take it outside to wash it after wet sanding in preperation for paint, and no spark again. . I was ready to rip the whole wiring harness out and start over. but instead I got online and got the details of the Nutter bypass and decided to give a try. Did it today and it fired right up and ran smoother than it did before (the few times it actually ran that is). Super easy mod to do. On the 6 cyl. version, the bypass talked about adjusting the stepper motor on the carb, but I don't think my carb for the 2.5 has one. Or does it? I can tell I need to fine tune the timing now, but overall I am super happy that I don't have to rewire this thing! I am now trying to convince my buddy who has a 90 YJ with the 258 to do the same thing. His has a once in a while engine dieing problem, and all the usual suspects have already been replaced. Thanks.
03 Liberty Sport 4x4 3.7 auto, stock
84 CJ7 2.5 4 speed , stock
79cherokee is offline   Reply With Quote
Old 10-10-2008, 11:07 PM   #2
LostINohiO
the nutter bypass worked very well on my 258...
im a huge fan and advocate...
best mod i ever did for around 5 dollars in wire...
[CENTER][B]1985 cj7[/B][/CENTER]
LostINohiO is offline   Reply With Quote
Old 10-11-2008, 11:06 AM   #3
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
There may be a mixture control solenoid on your carb. It may look like a round can hanging down off the side of it?
If so, and I haven't had one apart to see, it may be electric or vacuum controlled. If there are no wires to this can, then I would just set the idle mix and timing and try it to see.
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
