Nutter'ed my 84 CJ7 2.5 today! - JeepForum.com
post #1 of 3 Old 10-10-2008, 09:15 PM Thread Starter
79cherokee
Hey all,
Been having trouble with my 84 CJ7 with the amc 2.5 with it not starting due to no spark. Replaced the module, tried different coils, even a new pick up coil. After replacing the pick up coil it ran. Now this Jeep has been in my garage for over a year so no miles were put on it because it was only in the last few months it was even together.(frame off rebuild). Well, it started up about 3 weeks ago, and went to start it up last week to take it outside to wash it after wet sanding in preperation for paint, and no spark again. . I was ready to rip the whole wiring harness out and start over. but instead I got online and got the details of the Nutter bypass and decided to give a try. Did it today and it fired right up and ran smoother than it did before (the few times it actually ran that is). Super easy mod to do. On the 6 cyl. version, the bypass talked about adjusting the stepper motor on the carb, but I don't think my carb for the 2.5 has one. Or does it? I can tell I need to fine tune the timing now, but overall I am super happy that I don't have to rewire this thing! I am now trying to convince my buddy who has a 90 YJ with the 258 to do the same thing. His has a once in a while engine dieing problem, and all the usual suspects have already been replaced. Thanks.
03 Liberty Sport 4x4 3.7 auto, stock
84 CJ7 2.5 4 speed , stock
79cherokee is offline
post #2 of 3 Old 10-10-2008, 11:07 PM
LostINohiO
the nutter bypass worked very well on my 258...
im a huge fan and advocate...
best mod i ever did for around 5 dollars in wire...
1985 cj7
LostINohiO is offline
post #3 of 3 Old 10-11-2008, 11:06 AM
Mike Romain
There may be a mixture control solenoid on your carb. It may look like a round can hanging down off the side of it?
If so, and I haven't had one apart to see, it may be electric or vacuum controlled. If there are no wires to this can, then I would just set the idle mix and timing and try it to see.
Mike
Mike Romain is offline
What did you do to your CJ today? woody-77 Jeep CJ Forum 21377 Today 05:34 AM
Got another CJ today!! fastas69 Jeep CJ Forum 9 03-01-2016 08:12 AM
What Did You Do To Your CJ Today? Renegade86 Jeep CJ Forum 4 08-01-2010 10:31 PM
I just got my first CJ5 today! bannings Jeep CJ Forum 12 08-11-2004 09:52 PM
got my cj-5 today....:D supersly_jones Jeep CJ Forum 11 06-17-2004 08:32 PM
