'Nuther T176 question - JeepForum.com
post #1 of 2 Old 01-09-2012, 01:38 PM Thread Starter
shum8
1980 CJ7
Sorry for all the questions - And I couldn't find the answer using the search either. Here goes: All my previous Jeeps had T4 or T5 trannies - this is my first T176, so I'm still learning. Will be replacing the entire shift lever assy (Top threads are gone, lotta slop while in gear, etc), and I don't know whether to replace just the 2 shift lever pins, or go ahead and replace the shift cover as well. I have a hose clamp holding the shift lever pins in, so something is FUBAR'd, but since I don't know how they are supposed to be held in place, I'm not sure which part is fried. Was hoping to have all necessary parts on hand when the trans. / transfer case came down. If the shifter housing is wearing a hose clamp, it's time to be retired, yes?
Thanks
Rob
shum8 is offline
post #2 of 2 Old 01-09-2012, 01:58 PM
agear
go here
http://www.jeepforum.com/forum/f8/84...manual-860642/
and click on the link in the thread there. Page E-32 has a exploded view of the shift control housing or whatever it's called. Page E-33 is instructions on disassembling and reassembling. It says clean and inspect all components. Replace anything that is nicked , cracked, broken or excessively worn.
1984 jeep cj7, 258 I6, rebuilt T176,rebuilt Dana 300, amc 20 , dana 30, 4.10's Trac-lok in rear , 4.10's detroit soft locker in dana 30, 2.5 inch bds suspension lift, 1 inch polyurethan body mount lift. Line ex. weber carburetor. factory tach. factory clock ,oem replacement speedomter cluster, and oil pressure gauge, factory volt gauge.
agear is offline
T176 question! Mlaughlin8 Jeep CJ Forum 13 12-13-2011 02:35 PM
'nuther engine swap question..... GADJIT98 Jeep CJ Forum 1 12-06-2010 10:10 PM
Strange T176 mounting question danheit Jeep CJ Forum 4 02-08-2010 11:22 AM
T176 leak question WayneMeuir Jeep CJ Forum 19 10-28-2009 05:28 AM
T176 Rebuild question hogbed Jeep CJ Forum 13 04-23-2009 08:18 PM
