NP 435 swap - JeepForum.com
post #1 of 12 Old 10-07-2009, 08:35 PM Thread Starter
adamsclarke
NP 435 swap
So who has put a 435 behind a AMC motor...304,360 etc...
I picked up a 435 that was overhauled by novak with a dana 20 adapter. It's going behind a 304 in my 74 cj5. I know I need a T176 bellhousing and pilot bushing from novak....but what clutch should I use. Will my T15 clutch work? Should I go with a centerforce set up for a ford tranny, like a T18?
I'm thinking the 435 and 3:15 in teh dana 20 will put me around 90:1, which will be almost like driving and automatic
adamsclarke is offline
post #2 of 12 Old 10-08-2009, 08:27 AM
CSP
Your T15 clutch will not work as it's for a 1-1/8" 10 spline input shaft. The NP435 is a 1-1/16", 10 spline. You can use a clutch disc from any '76-79 CJ with either the T150 or T18. You'll also need a different clutch fork to go with the T150/T176 bellhousing. The '75 and older clutch forks are not compatible with the '76 and up bellhousings or throwout bearings.
CSP is offline
post #3 of 12 Old 10-08-2009, 08:38 AM Thread Starter
adamsclarke
Perfect! Exactly what info I was hoping for.
I have a T176 bellhousing and the trans, so it looks like I just need to get a clutch, throw out bearing and fork for the T176 or T150 now.
post #4 of 12 Old 10-08-2009, 01:36 PM
LibertyJeeper
I plan on doing the same. Let me know how it works out for you. I picked up a 435 but still want to rebuild it first.
Originally Posted by walkerhoundvm View Post
Just keep in mind: things are never as bad as they seem. These are jeeps, built by man and any problems you come across can be solved by man - even you! Best of luck.
Looking for axles 4.10's or higher
LibertyJeeper is offline
post #5 of 12 Old 10-08-2009, 02:45 PM
JavaTee
1979 CJ5
You guys probably already know this....The NP435 IS NOT a speed shifting tranny. Your main gain over other 3/4 speeds (ie T-150, T-176, T-4, SR4, etc) is a granny first gear (6.69 to 1). Otherwise you/I use it as a three speed for daily driving.
It's a very easy tranny to rebuild, Novak Adapters The New Process 435 Transmission - Novak Conversions has fantastic knowledge/parts for that task. I have a few pics I can post if you would like.
Later, T.J.
'79 CJ5 258 w/MC 2100 & Team Rushed, NP435/Dana300 <--twin sticked, NT Dana 44 (w/Aussie) rear, and NT Dana 44. 3" susp lift, Currie shackles, 1" body Lift, Durabaked tub inside & out.
Military members (current or completed service) check out
JavaTee is offline
post #6 of 12 Old 10-09-2009, 11:07 PM
LibertyJeeper
Later, T.J.
Would love the pictures the more info the better. Would like to have all my ducts lined up before I start shooting.
post #7 of 12 Old 10-10-2009, 03:37 PM
JavaTee
1979 CJ5
Here goes some. My work area was a controlled mess, but interestingly enough everything stayed clean.
The input shaft & retainer
Countershaft gears, associated bearings, and synchros
Tail shaft retainer
Cover and shifter forks (Note: If you will be using first gear in a pulling way - ie up steep grades/bumpy hillsides/rocky terrain - notch the first gear detent/slot to help hold it in gear)
Inside case
Novak kit part 1 - gaskets, bearings, etc
Novak kit part 2 Dana 300 adapter & mainshaft
Shaft installed
Front view
Installed on m CJ
Later, T.J.
JavaTee is offline
post #8 of 12 Old 01-16-2010, 12:52 PM
Joes_Mess
NP 435 to 4.2 bellhousing
I am ready to install my NP435 but the bellhousing does not line up - is this a common issue and what is the solution
Joes_Mess is offline
post #9 of 12 Old 01-16-2010, 02:10 PM
JavaTee
1979 CJ5
What tranny bellhousing do you have? Since I had a T-150 tranny, the Ford NP435 mounted right up to it.
Later, T.J.
JavaTee is offline
post #10 of 12 Old 01-17-2010, 09:46 AM
Joes_Mess
NP435 to 238 bellhousing
I have a T-5 bellhouosing which I have found out is different than the T150 for the the year (85) I have. So now I am on the hunt for a T150 jeep bellhousing what a bummer I was so looking forward to getting this thing to run, (and move for the 1st time since I have owned it) yesterday.
I am now searching all the normal used places I know.
Thanks for your repy
post #11 of 12 Old 01-18-2010, 08:16 AM
CSP
You can drill the necessary holes in the T5 bellhousing and make it line up.
CSP is offline
post #12 of 12 Old 01-18-2010, 08:10 PM
Joes_Mess
Bellhousing
found a t150 bellhousing that works great - thanks for all your help
Joe
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-12-2009 11:36 PM
Engine swap or engine and transmission swap Notplayn Jeep CJ Forum 3 07-13-2008 07:31 PM
350 swap help brypten Jeep CJ Forum 13 06-06-2006 02:36 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
