now i have an electrical problem... - JeepForum.com
post #1 of 4 Old 08-24-2002, 08:05 AM Thread Starter
onesojourner
Angry now i have an electrical problem...
well i fixed my brake problem it turned out to be just a broken line going up to the master cylinder. the new problem is electrical. the jeep runs fine but if you turn it off it wont start without a jump. the alternator looks the battery is 2 days old. when you put the jumper cables on they get kinda hot and i dont think thats normal. the problem is almost like im leaving the lights on but im not. and there doesnt seem to be any thing on.
onesojourner is offline
post #2 of 4 Old 08-24-2002, 09:44 AM
only in a jeep cj
One quick check is to turn everthing off ans disconnect anything that is on all the time such as a clock or memery for the radio. Dissconnect the positive batt post and wait a few minutes then watch/listen when you put it back and see it you get a spark or sign of current. If so, there should be a short somewhere. That would lead to the batt discharging over night.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 4 Old 08-25-2002, 08:07 AM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
Sounds like you have a bad ground to the engine/frame. Check out or replace your battery cables - I have found that they can appear to be fine but still won't pass sufficient current to get the job done.
Steve
OldJeepguy is offline
post #4 of 4 Old 08-27-2002, 08:17 PM
kyp
electeral
I use to be an elect. rebuilder, and in this case i would first check for a draw more than 1 amp is a draw. you could do this 2 ways the easy way is to disconnect the negetive cable and put a test light is series with the cable and post. is there a bright light or a dim light? If there is a bright light ( this takes 2 people) have someone hold the test light in series like you have it showing the light ON. then pull 1 fuse at the time until you get the light to go out. when the light goes out you have found the draw, just find what that fuse opperates and fix the problem. if the fuse opperates more than 1 item put the fuse back in and check each item 1 at the time until you have found the prob.
if you need any more help please feel free to contack me!!!
We have done so much for so long with so little, That now we are qualified to do anything with nothing.........
kyp is offline
electrical problem idaho elk Jeep CJ Forum 1 05-03-2008 09:58 PM
CJ7 Electrical Problem mcdaddytx Jeep CJ Forum 9 01-02-2006 06:18 AM
Electrical Problem pf1130 Jeep CJ Forum 23 12-01-2005 04:32 PM
Another CJ 7 Electrical Problem nozzleram Jeep CJ Forum 10 02-05-2005 08:29 PM
electrical problem v75vette Jeep CJ Forum 1 05-31-2004 11:39 AM
