A novice's 1979 CJ5 restoration (The Beginning) - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > A novice's 1979 CJ5 restoration (The Beginning)
Awesome Open box items at OPENBOXOFFROAD.COMIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.com
Unread 01-30-2013, 02:58 PM   #76
commadore64
commadore64's Avatar
1980 CJ5
Nice build Griffen... been watching your progress. Thats a real bonus to have access to the sandblaster, power coating and paint booth... makes for a quality job.
1980 CJ-5
My build thread: http://www.jeepforum.com/forum/f8/bo...j-5-a-1290405/
"For evil to flourish, all that is needed is for good people to do nothing."
commadore64 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2013, 08:59 PM   #77
Griffen24
1979 CJ5
Indeed Commadore64, I am very appreciative of my cousin for the use of his time and equipment. I don't think I would have attempted this size of restoration without knowing I could count on him... Much love to cousin Jamie!! Needless to say he is a very busy man and I only wish I had his skills and trade in place of being a computer jockey.
Welcome aboard dubya.
Thanks - Lifeisgood.
Griffen24 is offline   Reply With Quote Quick reply to this message
Unread 02-06-2013, 09:27 PM   #78
Griffen24
1979 CJ5
Tonight I took on the take of brake lines... Picked up a 25' roll of the Poly-Armour PVF Steel Brake Line and the 3/8" 24 brake line nuts/fittings. Borrowed a friends tube bender, cutter, and double flaring kit. Then proceeded to bend me some tubing. There is a little be of a learning curve to it but it is not to hard to do. most of the line i was able to thumb bend without crimping the line. also learned a trick, i zip tied the old line to the new as i bent it this kept it in form and help me identify where i needed to do little tweaks at the end and ensures a near prefect duplicate bend each time.
also please note the the cost benefit of beginning your own line far out ways the time and effort learning to do it your self, saved over $200 bending the line at home vs. the prevent kits. Which is good, as I think my shocks are shot... compressed all four of then all the way last night and still fully compressed tonight... ahh they were looking pretty rough to boot..
Unread 02-06-2013, 10:45 PM   #79
rixcj
rixcj's Avatar
1979 CJ5
Nice job with the brake lines!
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 08:22 AM   #80
CjHouch
CjHouch's Avatar
1976 CJ5
^^ I agree!!
Greg
CjHouch is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 01:31 PM   #81
7CJ5White6
1976 CJ5
WOW i love this thread. I have a 76 CJ5 and will be doing all the same as you. Might take me a bit longer since cash is tight after buying a house but i have the entire garage to use just for my Jeep.
One question. What size bolts did you use to connect the engine to the stand?
7CJ5White6 is offline   Reply With Quote Quick reply to this message
Unread 02-07-2013, 02:19 PM   #82
Griffen24
1979 CJ5
Thank guys...
7cj5white6, not sure off hand on the size, just know I took one original bell housing bolt to tractor supply and matched up the thread in a schedule 8 bolt not sure if I went 3 1/2" or larger. Will let you know once i drop her back in within the next few weeks.
Unread 02-23-2013, 08:34 AM   #83
Griffen24
1979 CJ5
Life's been busy so the jeep project has been on hold. Wife resigned from her job so just my income now.. Kinda slows the restoration pace a little bit. but still moving forward. Got the Brake lines roughly laid in place. Also repainted and installed the sway bar last night. planning to install the steering stablizer and new fuel tank this next week. Then clean up, paint, and install the fuel lines.
Unread 02-23-2013, 09:15 AM   #84
Skerr
You're doing a GREAT job Griffen. Nice work on the brake lines. Sorry to hear about your wife quitting... that must have been a tough decision. Keep on Truckin...
Kerrdog
Go Fish! <*////><
Skerr is offline   Reply With Quote Quick reply to this message
Unread 04-20-2013, 05:58 PM   #85
Griffen24
1979 CJ5
OK I am back in action after a bit of a break.
Status update. Pic's to follow.
Installed all new break and fuel lines. Installed new fuel tank, fuel sender, fill hoses, tank skid pan.
Rebuilt the T150 (seals, bearings, gaskets, new fluid, and new back up light switch). Blasted it and repainted the transmission, transfer case, and bellhouseing nice pretty black.
Reinstalled the clutch to the flywheel
Then today I, Reinstalled the I6-258, T150, and D20 back into the nice shiny frame had to take a moment to cherish the moment, the motor has been out for quite some time and seeing it back in place felt real good. Over the next few weeks I plan to get all the accessories put back in place. Starter, exhaust, fan, and pulleys. Also going to get serious about the body work this week too. going to check out the current status of the tube and start the body filling process to get her all nice and strait again.
Looking for any great tips on necessary tools and tricks of the trade for body work. I know it's time to go shopping again for this leg of the process. Going to be using body filler on the uneven spots to make it nice and smooth again prior to paint work.
Unread 04-20-2013, 06:16 PM   #86
Griffen24
1979 CJ5
Before:
After:
getting all prep'ed:
Then all done for the day... ahhhh
Unread 04-20-2013, 08:09 PM   #87
HALOjmpr
You want what, when?
HALOjmpr's Avatar
1982 CJ7
Hello "neighbor". Great work on the jeep so far. Much faster progress than me. My first plan of action is just reliable and safe for mine. A full tear down resto will happen later. Keep up the good work! Suscribed!
"It's not about how hard you can hit, it's about how hard you can get hit and keep moving forward!"
My jeep project "Rustful Dead"
HALOjmpr is offline   Reply With Quote Quick reply to this message
Unread 04-21-2013, 08:56 AM   #88
fiddy5cj5
1955 CJ5
fiddy5cj5 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2013, 08:58 AM   #89
fiddy5cj5
1955 CJ5
What size are those pro comp mts they look real good and great work on the 5, I wish I had your cousin Jamie in my family lol
Unread 04-22-2013, 06:01 PM   #90
Griffen24
1979 CJ5
The tires are Pro Comp Extreme M/T 35's. Just visited Jamie tonight and picked up some of the smaller bits and pieces.
the tub is full of all the little stuff like my mirror mounts, hood hinges, windshield hardware and pedal assemblies. it's funny but the tub is the color the jeep is going to be painted. so form the paint light bezels you can see how the black trim will pop when she is all done.
here is the teaser pic...
