A novice's 1979 CJ5 restoration (The Beginning) - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > A novice's 1979 CJ5 restoration (The Beginning)
Get 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-29-2013, 10:22 AM   #136
rixcj
rixcj's Avatar
1979 CJ5
Did you push in the little button on the proportioning valve? It must be pushed in for the rear brakes to bleed.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline   Reply With Quote Quick reply to this message
Unread 12-29-2013, 04:49 PM   #137
Griffen24
1979 CJ5
Yes I had to use needle nose vice grips but I was able to press the little pin flat. But still no real bleed in the rear. I am thinking the value itself my be clogged. My reasoning is the the reed switch to trigger the Breaks warning light is triggered and the light is on. Also seeing no difference in bleed volume if pin is depressed. I think I saw a post for a value tear down and cleaning. Guess I can try that.
Griffen24 is offline   Reply With Quote Quick reply to this message
Unread 05-21-2014, 06:42 PM   #138
Griffen24
1979 CJ5
It has been a while since I posted so figured I would throw a quick update. Break issue was resolved, ended up being the bubble in the Master Cylinder, I can now lockup all 4 wheels.
Just stepping back to see the progress this old CJ has made brings much pride.
Here are some simple before and after shots.
Unread 05-21-2014, 08:51 PM   #139
Tfain
1978 CJ5
Did you ever decide to go with those halos?
Tfain is offline   Reply With Quote Quick reply to this message
Unread 05-26-2014, 06:55 PM   #140
Griffen24
1979 CJ5
No halos at the moment Tfain. It is just a back burner thought at the moment.
