Novak vs. Advance Adapters - JeepForum.com
post #1 of 3 Old 08-03-2007, 12:17 PM Thread Starter
gjohnson
OK, so I'm doing the 4.0 swap, and I am dropping in an AX-15 tranny, which I will be adapting to my Dana 300. The problem is that I can't decide which adapter to use. The novak adapter is cheaper at $118, but the AA adapter comes with an index retainer and is $173. Do I need the extra part? If anybody has any info, it would be helpful. Thanks.
Novak:
http://novak-adapt.com/catalog/kit_153.htm
AA:
http://72.20.96.178/commerce/ccpc107...03-50-8603.htm
gjohnson is offline
post #2 of 3 Old 08-03-2007, 04:15 PM
slacker92104
slacker92104's Avatar
I was very happy with the novak adapter. The "index retainer" looks like a new input bearing retainer for the t-case. I'm not sure what it does, or why you would use it.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #3 of 3 Old 08-03-2007, 08:55 PM
troy.j
the index retainer alows you to roll the case down for better driveline angles with out lowering the whole thing. depends on how much lift you will have and if you want it or not.
99 tj, 00 wj, 95 yj
...ask those who have bled of the cost of freedom and honor those who gave that others may have what we take for granted...
troy.j is offline
What's up with Novak? Rumpeltiltskin Jeep CJ Forum 2 06-13-2009 07:09 AM
Novak or Advanced adapters 78treehugger Jeep CJ Forum 1 12-03-2008 11:24 AM
novak vs advance trans adapters wjr Jeep CJ Forum 8 05-22-2006 07:41 PM
Advance Adapters Chain Clutch Linkage Prospect62 Jeep CJ Forum 6 04-04-2006 08:58 AM
Advance Adapters FS jeepsaremything Jeep CJ Forum 0 08-02-2001 01:58 PM
