Novak Adjustable Release Bearing - JeepForum.com
post #1 of 16 Old 08-09-2012, 07:15 AM Thread Starter
BradWilson101
1975 CJ5
I've got a sb350 mated to an sm465. The tranny didn't come with the motor but I found the right bellhousing. I converted it to a Novak hydraulic clutch slave. I installed the clutch pack appropriate for the year motor including the release bearing. Come to find out the bearing was too short. I re-measured the length and installed a longer bearing. Turns out it was too long and the clutch was disengaged. The third bearing from NAPA didn't come with a carrier.
To make a long story longer the availability of bearings is now very limited. Novak offers an adjustable release bearing. Has anyone had the same issues? Has anyone used the Novak adjustable bearing? Any and all input is greatly appreciated. Thanks.
75 CJ-5 with 76 glass tub. 350 sbc with Edelbrock 600cfm, SM465, D20, D44 w/ 3:73, D30 w/ 3:73, Novak Hydro Clutch Convo. Turned into a frame off resto so it's still in progress.
BradWilson101 is offline
post #2 of 16 Old 08-09-2012, 10:54 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
bump
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #3 of 16 Old 08-10-2012, 05:20 AM
dfmcintosh
1981 CJ5
I am using that TO bearing in my CJ5 LS swap. After a month of running it I am dropping the tranny to see why I am having disengagement issues. It could have been installer (me) error or the adjustment part may have failed, I will update when I get in there. I did have the same issue as you with the throwout not being long enough. Summit sells an adjustable one by McCleod Racing #16515 that I may try if thats the issue.
Good luck!
dfmcintosh is offline
post #4 of 16 Old 08-10-2012, 05:42 AM Thread Starter
BradWilson101
1975 CJ5
Thanks df, I was beginning to think I was the only person out here that couldn't figure this out. I'd be real interested to hear what the "new" issue is. It's maddening to have to keep pulling stuff apart.
post #5 of 16 Old 08-10-2012, 06:02 PM
dfmcintosh
1981 CJ5
links to pictures of my TO bearing
http://i175.photobucket.com/albums/w...g?t=1344642282
http://i175.photobucket.com/albums/w...g?t=1344642384
I dont know how to imbed them sorry.
I dont know if I installed it wrong, but it worked trouble free for a while, and I'll admit it broke when I was driving it like it was a drag car, which it kinda feels like
It started off with the rear flange in the fork clips, then when I just pulled it, the clips were holding that middle/forward flange like it bound up while I was stomping on it and the fork bent the flange. I will call Novak on this one and see if they have experienced this before. What a PITA for a TOB.
post #6 of 16 Old 08-10-2012, 06:41 PM Thread Starter
BradWilson101
1975 CJ5
How do you secure the bearing once the length is determined? I'd be interested in Novak's reply.
post #7 of 16 Old 08-10-2012, 07:59 PM
dfmcintosh
1981 CJ5
There are two metal dowels that line up with holes through the assembly and then you drive them through once the length is established. I really can't wait to hear what they say either, even if its "hey idiot" I just don't want to have to pull the trans and tcase for a 3rd time anytime too soon!
post #8 of 16 Old 08-15-2012, 08:15 PM
dfmcintosh
1981 CJ5
Well not much to update with Novak, I emailed and called-left message. No response from email of phone call. That is disappointing considering I spent a bunch of money with them. So here is what I am going with this time... RAM clutches part # 495, its for 1 1/8 input shaft like my T176 not sure about the sm465. It is 1.9" long and I was around 1.8x" so I am going to get an adjustable ball pivot as well. I hope you figure yours out. http://www.summitracing.com/parts/RAM-495/
post #9 of 16 Old 08-15-2012, 09:15 PM Thread Starter
BradWilson101
1975 CJ5
Call them back at hit extension 20. That's Eric, the owner. It may take a day or two to get back to ya but he's real decent.
My new one came today but I'm still on the DL from hernia surgery. Hopefully soon.
Good luck and keep us posted.
post #10 of 16 Old 08-16-2012, 07:21 AM
dfmcintosh
1981 CJ5
I appreciate the extension. Rest up and let me know how that TOB works for you. I am doing a complete rebuild of my T177, so it will be a while before I get the jeep totally back together.
post #11 of 16 Old 08-17-2012, 12:25 PM
dfmcintosh
1981 CJ5
To update, Eric from Novak called me today and he is sending me a new TOB so all is good, hopefully that was just a fluke and not something I did wrong.
post #12 of 16 Old 08-17-2012, 01:38 PM Thread Starter
BradWilson101
1975 CJ5
At least they stood behind the product. I hope it was either something you did wrong or a defect in 'that' TOB. I say that cause I don't want the same thing to happen to me. Either way I'm glad you got some resolution. I knew they'd stand behind the product, that's why I stick with them. Good luck and keep us posted.
BTW, did you measure the distance from the front of the carrier to the front of the bearing face, once it was adjusted?
post #13 of 16 Old 10-13-2013, 11:53 AM
sclose55
1974 CJ5
I am haveing the same problem Have a 1974 cj5 with an tpi out of a vette and sm465 trans an a dana 300.Mine is doing the same thing.Please let us know if all comes out ok I am thinking of use the novak throwout bearing also.
Thanks
sclose55 is offline
post #14 of 16 Old 10-13-2013, 12:15 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Thanks
I put an SM465 behind a 258 earlier this year on a 1982 CJ7.
Used the adjustable throwout bearing from Novak with no issues, it worked great.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #15 of 16 Old 10-13-2013, 02:36 PM
sclose55
1974 CJ5
Thanks I am going to give it a try.thanks for the help
sclose55 is offline
