#1 | |
*note on blazer motor upgrade
Just a suggestion for anyone planning to do the heater motor upgrade: Try getting the heater from Advance. I believe they sell Factory Air brand heater motors. I bought a Siemens from Autozone and it turned out to be the one that is a bit too long. I already had my one and only ride torn all apart to put it in before I realized that it wouldn't fit, so I made some modifications and made it work. But, for any potential motor buyers, try the one from advance. Their's is $20.99. I opted for the heavy duty version (with A/C) from autozone and it was only $13.99. But I also compared it to the standard duty version ($15.99) and they were the same size. I'm betting the one at advance is the shorter one.
#2 |
It doesn't matter where you buy it from. There are two motors out there.......one with a short shaft and one with a long shaft. I bought mine at Autozone and it had the short shaft. I did my research properly before I bought it and made sure it was right before I paid for it. And by the way, I got mine for a Blazer with no A/C like all the websites I read said to do. The one with A/C isn't any more powerful. Just clearing things up.
"If stupidity got us into this mess, why can't it get us out?" -Will Rogers |
#3 | |
#4 |
How much of a differance does it really make?
1980 CJ 5. Hummer Yellow. SS dash, Rhino Lining 258 23 Gal gas tank Rock bumper Fnt & R. 8000# Ramsey Patriot Winch. Painless wiring. 411 gears OX rear Aussie front, dual batteries,Optima Red top, Firestone Destination M/T 33X 12.50 Sylvania Silver Star Head Lights, Rancho 9000, Superlift, Weber, KC off road lights, Cobra CB, DUI ignition etc $$$$. |
#5 | |
#6 |
http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESUL TS&MfrCode=FAA&MfrPartNumber=35587&PartType=117&PT Set=A
This is the right one I believe.
----------------------- I used to own a CJ....:-( http://www.bustedjeep.com AIM: Qsting68 |
#7 | |
Yep, I agree. That's the same one that Advance autoparts sells. Factory Air is the company that makes it. |
#8 |
I, too had troubles. However, I mistakenly ordered the PM 102. When I put it back togehter, everything seemed to fit, until I turned the fan on...then everything broke. After getting a new hampster wheel (fan blede), I went to Autozone and compared to the PM 105. The shafts are different lengths (your's may have been a return part?)... I have since done this a few more times and the PM 105 is the correct length. To be sure, make sure to compare shaft lengths with your motor prior to installation...
#9 | |
#10 |
Hey ya'll i have been reading about this upgrade for a while and finally decided to do it before another long cold winter. I went by what http://www.off-road.com/jeep/tech/body/heater.html said to get for a blower motor as they sem to best the best place with a write up. I was unaware up this whole shaft issue though. I got a 79' chevy blazer 350 with air like it said in the article from autozone. On the box it says it is a factory air and it has the number 35588. On the actual motor it says
11588 12v 04016. The only shaft that I see sticking out seems to look maybe jsut a little over an inch long. Does this seem to be the right one? By the way dont know if Ill ever need it but it came with a lifetime warranty and only costs $18.99. Sorry to sound so ignorant about this but just wanted to be sure. Thanks ya'll |
#11 |
From my experience there are two different shaft lengths, but that's not the problem from this thread. I got two PM102's (one for each jeep) and the shafts on those two were a little different. One went in with no problem and the other required a little shimming to make it work. Sounds to me like the quality control on these things isn't all that great and the tolarances on them leaves room for quite a bit of difference. As for the whole long shaft/ short shaft thing, the long shaft is supposed to be a LOT longer than the short shaft. Sounds like you guys are getting the right motor (you wouldn't be able to make the long shaft work with a few washers) but you are getting one with a little out-of-spec shaft on it. There's probably no real way to tell except to take your stock motor and measure several of the new ones until you get a match.
85 CJ7 258, borla header, jacobs ign, weber carb,optima batt, 135 amp alt, agr super box 2 & pump, T5 w/ B&M shifter, centerforce 2, superior 1 piece axles, warn hubs/ XD8000i, 2.5 in lift, 31" BFG MT 85 CJ7 "wife's ride" 258, A/C, T176, superwinch hubs, 3in lift 31" BFG AT/KO |
#12 |
Before I was aware of the shaft difference, I had bought one. The one I bought was the long shaft (not realizing this). To make it work, I had to shim the motor out of the housing by nearly 3/4 of an inch and then seal the gap. It worked, just wasn't as pretty...
#13 | |
Take a look at this guy's blower motor upgrade:
http://www.manoian.net/jeep/blower_fan.html Note the part number on the fan and his description of his problems. I think this must be what you encountered. And the PM105 must be the longer shaft motor. Quote:
#14 |
My toes are getting warm just thinking about doing this one!
85 CJ7-Holley Projection on a 258-Sport seats with 4 point harness-Sealed Battery-8000 lb winch with roller fairlead-Home fab front and rear bumpers-Stainless dress up stuff-31" Wild Country on Aluminum rims-Hard doors and top- [SIZE=2][COLOR=DarkRed]Soon to be 350 Chevy.[/COLOR].......[/SIZE] |
#15 |
blazer motor
http://www.manoian.net/jeep/blower_fan.html Note the part number on the fan and his description of his problems. I think this must be what you encountered. And the PM105 must be the longer shaft motor. You are exactly correct. I am in the middle of this conversion as we speak and I just picked up the blower motor from napa last night. I had the guy at napa pull out the PM105 and the PM102 and you can clearly see the difference in the shaft length. I compared the PM102 with my old jeep motor and they are exactly the same length. It even comes with a plug to fill the vent hole in the new motor! Well worth the $22!!! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
