Not starting - JeepForum.com
post #1 of 6 Old 04-24-2013, 06:36 AM Thread Starter
dj5day
1973 DJ
Not starting
When I turn the key the solenoid buzzes. I replaced the starter, solenoid, coil, wires, and the battery. What is up? Thanks!
dj5day is offline
post #2 of 6 Old 04-24-2013, 07:48 AM
wblackm
Manual or Automatic? If Automatic, it could be a bad neutral lock out switch. I'm wondering if the buzz you are hearing is actually the fuel pump kicking on?
Also, check your grounds.
wblackm is offline
post #3 of 6 Old 04-25-2013, 07:47 AM Thread Starter
dj5day
1973 DJ
It's an automatic. The fuel pump is a mechanical one. It started today but now the alternator won't keep it running....
dj5day is offline
post #4 of 6 Old 04-25-2013, 08:11 AM
PROJECT 23
Remove the alt and have it tested at Auto Zone or another parts shop in your town. If it's a faulty alt, they'll be able to tell you. If it checks out good, then we move onto the next step in figuring this out....
PROJECT 23 is offline
post #5 of 6 Old 04-25-2013, 11:16 AM
Hawk4097
If your alternator is good check the wiring coming off of the solenoid to the alternator. someone could have done a crappy splice job that needs to be repaired
Hawk4097 is offline
post #6 of 6 Old 04-25-2013, 06:09 PM Thread Starter
dj5day
1973 DJ
The alternator is fine! Next step is the wiring....
dj5day is offline
